pfstelwagon(at)earthlink. Guest
Posted: Wed Dec 11, 2013 9:30 pm Post subject: Cold Cylinder |
If you checked the lead for continuity it is more than likely ok. Use a high tension lead tester and connect one lead to the plug wire and the other to the ignition conduit. Most likely the wire has an insulation break and is firing to the conduit rather thatn the plug.
Frank
CJ-6A
