Posted: Tue Dec 03, 2013 6:39 pm Post subject: kitfox /rotax 912 wiring diagram (variation on Z-16) |
I thought about this a lot before I stuck all that stuff on the E-bus… strictly speaking I don’t need:
- Transponder/Alt encoder
- Autopilot
- AHRS
- Cigar Lighter 12V and USB supplies
But it’s nice to be able to have them (e.g. if you’re going to be landing in a field that’s new to you, you can have the A/P on while you look at the chart, etc), so I figured I would leave them there and turn them off if necessary (except for the AHRS but that only consumes 0.3A). Is this not advisable? (I’m a low time PPL so I’m completely open to suggestions in this area). |
Do the load analysis with a consideration of how
you would maximize the utility of the battery's
stored energy toward a design goal. First, how
long would you like to operate battery only?
A lot of design decisions are made with no
more conviction to an idea than "this is better
than that" . . . but without quantification
as to how all the "betters" add up to meeting
a design goal. Folks who buy/fly TC aircraft are
relieved (or should I say deprived?) of that duty.
Folks paid to worry have decreed that John Q.
Public pilot is not properly prepared to accept
such responsiblity . . . so they say, "Don't worry
. . . we've taken care of all that worry stuff . . .
just memorize the holy-watered pilot's operating
handbook and all will be right with the universe."
| Quote: | Consider re-assigning supply points for some
of the items on the avionics bus. |
Write you own 'stage play' or better yet 'cockpit
play' in which you are the star performer. Plan a
mission with the highest order of risk wherein loss of
engine driven electrical power would be the most perplexing.
It's interesting that MOST plane/pilot/mission
scenarios flown in both TC/OBAM aircraft seldom
elevate the importance of alternators and batteries
to levels of critical concern.
I cannot recall one instance in 33 years/1000+
hours as pilot where loss of an alternator was
more than an 'oh fooey!' event. I've personally experienced
one loss of alternator event on a cross-country
but completed both outbound and return legs battery-
only so the owner could deal with the broken alternator
on his own turf. That same trip also presented loss of
airspeed indicator (spider egg sack waaayyy back
in pitot tube). Both events presented a challenge
for assuming a new mode of operation. But both legs
were day-vmc ops in and out of uncontrolled
fields . . . I normally navigated with dual
AA powered, GPS315 receivers on the glare shield
. . . so no big deal.
I have conducted numerous long-leg ops at night over
unfriendly terrain but never suffered the indignity
for loss of alternator. NONE of the airplanes I
was flying featured anything like an e-bus. I had
absolutely no idea as to the health of the battery
beyond the fact that it cranked the engine.
My personal plan-b calls for me to arrive at airport
of intended destination whether the panel was 'lit up'
or not.
Nonetheless, Hollywood playwrights, dark-n-stormy
night stories in the journals and exciting anecdotes
over beers (combined with our terrestrial perceptions
of batteries in general) give rise to worries about
both alternators and batteries.
Getting back to your particular study of options,
it would be well to set some design goals. What
battery only endurance would you like to strive for?
Given what you know about how the airplane will be
used, you might start with some notion of just how
long you'd like to operate battery only. About 1/4
of my use of winged machines calls for burning off
most of a full fuel load . . . so personally, my e-bus
operations would shoot for 3-4 hours as a design
goal. Your's may be less.
My plan-b flight bag hardware consists of GPS
receivers (two actually . . . I use them full time),
hand-held transceiver with vor/loc capabilities,
and a flashlight. Something you can do in your airplane
that I didn't get with a TC rental is connection
for your hand-held to the external antenna.
For the way I use airplanes, I enjoy a high order
probability that I'll get where I want to
go . . . whether I'm using an A-36 with lots of
stuff that doesn't work or a J-3 that didn't
have any stuff to begin with.
Okay, what are your personal design goals? Which
items on your panel will address your needs for
continued flight battery-only until destination
airport is in sight? What are the energy demands
for those items? How long do you want to run them?
You can certainly have other things on the e-bus
but items not needed for the en route, endurance
mode of flight should be fitted with on-off switches
so that you can shed those loads.
By replaced, do you mean I should add a fuse between the Dynamo and the Voltage regulator? I don’t currently have a fuse on the b-lead, I don’t think. |
What passes for a "b-lead" on the PM/R-R
system is that wire that runs from OUTPUT
terminal of the R-R, through the control
relay and to the system. Since it ties
directly to a battery-fed, fat-wire it's
a good idea to protect it at some level
well above the output capability of the
alternator. 30A fuse is a good choice.
I’m confused… I thought the b-lead is wire that goes between the dynamo and the voltage regulator. How can it be connected to the battery contactor? |
No, the output from the dynamo is AC voltage
conducted to a controlled, full-wave rectifier
in the rectifier-regulator. The analogous
path in a wound-field alternator would be
wires between the stator windings and
a 3-phase rectifier array . . . all this
is INTERNAL to the legacy alternator.
I incorporated them following the suggestions on the Infinity Grip order form ( http://www.infinityaerospace.com/gripwire.pdf) and against the better judgment of my expert friend who helped me with the wiring. I thought it might be a good idea to have them handy in case of an engine failure in order to attempt a restart. But in hindsight, it was maybe not such a great idea. There is also the potential, any time the master is on on the ground, to accidentally hit the starter button and swing the prop. |
The more I think about it, the more I
dislike putting all those functions on
the stick. Non-standard "conveniences" can
translate into un-intended consequences.
Further, the likelihood that a start-button on
the stick will ever be critical to saving
the day is exceedingly low if not zero.
If the engine quits at altitude, you've
got plenty of time to manage the situation
with the legacy suite of controls. If you're
so low that mere seconds count, then fiddling
with the engine is a distraction from the
prime directive of the day . . . endeavor
to walk away.
In a TC aircraft you will find some combination
of following buttons on the wheel or stick.
Trim: UP, DN, LT, RT
Push to Transmit
Push to Intercom
and MAYBE . . .
Master Disconnect that removes power to all motors
that drive flight surfaces.
Inadvertent operation of any of theses switches
does not create a hazard to sheet metal or
bones . . . nor do they depart from legacy
cockpit behaviors that are the stock and trade
of most pilots.
We still need a list of electro-whizzies in
your airplane that use power . . . and
partitioning of scenarios for when they are
expected to be in service.
Bob . . . [quote][b]
uuccio(at)gmail.com Guest
Posted: Tue Dec 10, 2013 8:24 am Post subject: kitfox /rotax 912 wiring diagram (variation on Z-16) |
[…] my e-bus
Four hours sounds like a good number. Missions will be Day VFR only; some mountainous terrain and open waters.
and a flashlight.
I have an iPad which has aeronautical charts. It will be connected to the USB charger to keep it charged when the alternator is working and will serve as a backup GPS if the alternator stops working. My hand-held doesn’t have VOR/LOC capabilities, maybe I’ll pick one of those up next time I’m in the US (its’ cheaper there).
That’s definitely something I’m interested in; is there a good way to do it without installing a separate antenna?
OK, I’ll do that.
to walk away.
Yup, makes sense.
Push to Transmit
Push to Intercom
and MAYBE . . .
of most pilots.
I’ve revised my Load Analysis (see attached excel/pdf), and it indicates that with a 24Ah Batt at 70% capacity, I should get 4 hours electrical endurance…
Sacha
 Download |
| Filename: |
Load_Analysis_1.25.pdf |
25.29 KB |
| Downloaded: |
264 Time(s) |
 Download |
| Filename: |
Load_Analysis_1.25.xlsx |
32.69 KB |
| Downloaded: |
257 Time(s) |
