EZ Heat engine block heater
flysrv10(at)gmail.com
PostPosted: Sun Dec 08, 2013 4:12 am    Post subject: EZ Heat engine block heater Reply with quote
couple of pictures of my installation just in case someone is planning the same.
The installation instructions are conceptual and not directly related to IO540. Basically, place the pads where you they fit.
The throttle body and the cable bracket had to come out to accommodate the installation. Of course easiest installation during the building process.
Have not fired it up yet, 24 hrs needed to cure. Costs $185 including shipping from AS.
Do not archive.
 Filesize:  31.04 KB
 Viewed:  5885 Time(s)
 Filesize:  31.76 KB
 Filesize:  27.65 KB
Tim Olson
PostPosted: Mon Dec 09, 2013 8:22 am    Post subject: EZ Heat engine block heater Reply with quote
I'm not sure if this is compatible or not, but, my Reiff preheater works
very well and it
uses a similar sump pad (although it's more of a metal pad?)
But, it adds the addition of cylinder base band-type heaters (like a
long skinny
hose clamp) to the engine. I find those actually work very very well.
I'm not sure if you could potentially add their cylinder band heaters to
your
sump heater, but if you live in a very cold area, it may be worth it.
I find that with my Reiff, I can go fly when it's 10 degrees out and my
cylinders
will still be near 90F. I can't remember for sure, but it seems that even
on the coldest days they're still in the 70's or 80's minimum, and you get
a more even full-engine heat that way. You wouldn't want sludgy oil
in the more external passages.
The only part I don't have is their oil filter heater. I have been
contemplating
adding that one too. For sure, if I were flying today here in Wisconsin I
would prefer it....but I haven't splurged yet.
Tim
Do not archive.
PostPosted: Mon Dec 09, 2013 10:26 am    Post subject: EZ Heat engine block heater Reply with quote
I will be testing mine during Xmas at temps about 20. My operation areas do not have the Wisconsin sub zero temps. That's the reason I settled for the pads.
They heat up to 300 but keep the oil temps at 165 with a thermostat.
Will give a report next year. Thanks for the comparison.
Rob Kermanj
On Dec 9, 2013, at 11:21 AM, Tim Olson <Tim(at)MyRV10.com> wrote:
I'm not sure if this is compatible or not, but, my Reiff preheater works very well and it
But, it adds the addition of cylinder base band-type heaters (like a long skinny
I'm not sure if you could potentially add their cylinder band heaters to your
I find that with my Reiff, I can go fly when it's 10 degrees out and my cylinders
The only part I don't have is their oil filter heater. I have been contemplating
Tim
> Do not archive.
rleffler
PostPosted: Mon Dec 09, 2013 10:59 am    Post subject: EZ Heat engine block heater Reply with quote
I have the same Reiff heaters that Tim mentioned. I'm getting similar results. It was in the twenties this weekend and the temps were in the nineties at start. I turned on the heat with my cell about four hours before the flight. A much nicer arrangement that I had with my Cherokee using propane heaters.
Bob Leffler
N410BL - Phase I
http://mykitlog.com/rleffler
schmoboy
PostPosted: Mon Dec 09, 2013 12:11 pm    Post subject: EZ Heat engine block heater Reply with quote
Tell me more about this turning on via cell phone thingy.
-Sean #40303
rleffler
PostPosted: Mon Dec 09, 2013 12:36 pm    Post subject: EZ Heat engine block heater Reply with quote
Switchboxcontrol.com
It's got a built in T-Mobile cell phone that can receive and send SMS messages. It's a prepaid device and the minimum you can load is $10. $10 over three months gives you more texts than I'll ever need. You can let it go dormant over the summer.
Works pretty well. I'm sure that you seen Phillips threads on VAF. He also supplies a simple iOS and/or android app for those that don't want to learn the SMS syntax
-Sean #40303
Bob Leffler
N410BL - Phase I
schmoboy
PostPosted: Mon Dec 09, 2013 1:03 pm    Post subject: EZ Heat engine block heater Reply with quote
That's awesome. Now I need to figure out how to hook it up to my hangar
heater thermostat to get the hangar from 46 to 64 degrees before I
arrive. Smile
-Sean #40303
saolesen(at)sirentel.net
PostPosted: Mon Dec 09, 2013 8:03 pm    Post subject: EZ Heat engine block heater Reply with quote
Here is a schematic for those of you in cold areas who would like to preheat your engine or hangar by SMS texts. It uses a Waferstar SMS relay with 7 available relays. It's available through DHGate on the web. The rest of the parts are Radio Shack DPDT 12v switching 110v relays and about 1.5a 12v source. The SMS relay will send a text message to you telling you that the requested action was done. I used an SMA connector to RG-58 coax to make an antenna going out the wall of my metal hangar. I stripped the exterior braid the length of the factory antenna and that yields a signal strength of under 10 out of 32 which seems to be good enough. I use an H2O Wireless card from Best Buy at $10 for 3 months. Texts are $.05 and there will be 4/use.
I use it to turn of the engine heater or the furnace and ceiling fans either together or singly. Any combination of the seven relays is possible. The timer section of the schematic is used when I want to leave early in the AM and don't want to getup the send the message 2-3 hours ahead of time. The timer is preprogrammed for any day with a start time of 3AM and turns off at 9AM. The system is wired so that heater, furnace and fans can all be turned on by hand at the hangar.
There was no electrical inspection done this so I have no clue if it would pass.
I probably got a little carried away with this project but I really like it.
Sheldon Olesen
N475PV 527hrs
On Dec 9, 2013, at 3:03 PM, Sean Stephens <sean(at)stephensville.com> wrote:
That's awesome. Now I need to figure out how to hook it up to my hangar heater thermostat to get the hangar from 46 to 64 degrees before I arrive. Smile
> Sent from my iPhone
> -Sean #40303
 Filesize:  36.55 KB
 Viewed:  5856 Time(s)
