asarangan(at)gmail.com Guest
Posted: Mon Dec 09, 2013 3:09 pm Post subject: What material is the thin yellow foam? |
Does anyone know what that thin (1/8"?) yellowish foam used
extensively on the aircraft? Searching through the archive, there was
a mention of it being PVC foam. Aircraftspruce and Wicks do not seem
to have anything that looks similar, The only 1/8" foam I could find
was Divinycell PVC foam, which is blue and has a density of 3 lb/ft3.
Fred Klein
Posted: Mon Dec 09, 2013 9:09 pm Post subject: What material is the thin yellow foam? |
On Dec 9, 2013, at 3:08 PM, Andrew Sarangan wrote:
| Quote: | Does anyone know what that thin (1/8"?) yellowish foam used
extensively on the aircraft? |
I believe it is "Last-a-Foam"...unsure of the type...feels and sand like urethane...very handy stuff...Fred
nigel_graham(at)m-tecque. Guest
Posted: Tue Dec 10, 2013 12:41 am Post subject: What material is the thin yellow foam? |
Hi Andrew,
The rigid foam is a cross-linked PVC polymer and is manufactured by
AIREX ag. in Switzerland.
Available in various thicknesses and cell coarseness, the one that was
used by Europa is 3.0mm - R63.80
I have no idea who retails this on your side of the pond but I can give
you details of a UK supplier if needed.
a.t.b.
Nigel
On 09/12/2013 23:08, Andrew Sarangan wrote:
dave.glowa(at)termrim.co. Guest
Posted: Tue Dec 10, 2013 12:54 am Post subject: What material is the thin yellow foam? |
Andrew
| Quote: | From memory the foam is Airex R63 available from IMPAG, it is a closed cell linear thermoplastic polymer with a density of 60kg, its is a long time since I bought some when I used to manufacture the wings and fuselages, Andy Draper at the LAA may be able to confirm. The wing componenets were 5mm thick foam and the fuselage components were 3mm foam.
Dave Glowa
Posted: Tue Dec 10, 2013 1:08 am Post subject: What material is the thin yellow foam? |
..... found it!
North America / South America:
Baltek Inc.
P.O. Box 16148, High Point, NC 27261
Office/Plant: 5240 National Center Drive
Colfax, North Carolina 27235, USA
Tel +1 336 398 1900
Fax +1 336 398 1901
corematerials.americas(at)3AComposites.com
On 10/12/2013 08:40, nigel_graham(at)m-tecque.co.uk wrote:
<nigel_graham(at)m-tecque.co.uk>
Hi Andrew,
give you details of a UK supplier if needed.
a.t.b.
Nigel
Posted: Tue Dec 10, 2013 8:24 am Post subject: What material is the thin yellow foam? |
Great, thank you for looking that up!
It is amazing how some of these things don't show up on any search engines.
On Tue, Dec 10, 2013 at 4:07 AM, nigel_graham(at)m-tecque.co.uk
<nigel_graham(at)m-tecque.co.uk> wrote:
..... found it!
Baltek Inc.
Tel +1 336 398 1900
Fax +1 336 398 1901
> Hi Andrew,
> The rigid foam is a cross-linked PVC polymer and is manufactured by AIREX
> ag. in Switzerland.
> a.t.b.
> Nigel
