danny shepherd
Joined: 27 Jan 2006 Posts: 117 Location: north Wales, United Kingdom
Posted: Sat Dec 07, 2013 7:28 am Post subject: oil problem |
Hi All,
I have just completed the five year hose replacement. carried
out a check flight and all seems well. oil pressure 4 bar t's and p's
good. no leeks found. today I went to the airfield, checked the oil and
found it took a pint of oil to top it up. tried to start the engine but
it woud'nt start. I checked the plugs and found them all oiled up.
All the oil hoses are correctly fitted, and can't see any kinks. the
engine has only done 90hrs.
All help much apreciated.
Cheers Danny. G-ceri
alanb(at)dpy01.co.uk Guest
Posted: Sat Dec 07, 2013 7:47 am Post subject: oil problem |
First thing.
When you refilled the engine did you follow the procedure to get oil round the engine, cooler and filter before starting or just fill the oil tank and then start.
Alan
GOBJT
Sent from my iPad
| Quote: | On 7 Dec 2013, at 15:26, danny shepherd <danny(at)mcwalterscafe.co.uk> wrote:
Hi All,
I have just completed the five year hose replacement. carried out a check flight and all seems well. oil pressure 4 bar t's and p's good. no leeks found. today I went to the airfield, checked the oil and found it took a pint of oil to top it up. tried to start the engine but it woud'nt start. I checked the plugs and found them all oiled up.
All the oil hoses are correctly fitted, and can't see any kinks. the engine has only done 90hrs.
danny shepherd
Posted: Sat Dec 07, 2013 8:05 am Post subject: oil problem |
sure did, got the gurgle.
Danny
On 07/12/2013 15:46, Alan Burrill wrote:
First thing.
Alan
GOBJT
Sent from my iPad
> Hi All,
Checked by AVG - www.avg.com
pete(at)lawless.info Guest
Posted: Sat Dec 07, 2013 8:45 am Post subject: oil problem |
Hi Danny
I don't know if this would cause the symptoms, but have you got the
connections to the oil tank the right way round? It's very easy to connect
them outlet to the inlet and vice versa! I did it when fitting an oil
thermostat but picked it up before starting. It sounds like you have had a
head of oil draining back into the engine.
Good luck.
Pete
G-RMAC Classic 912ul
danny shepherd
Posted: Sat Dec 07, 2013 9:23 am Post subject: oil problem |
Hi Pete,
thinking I've been a muppet, thats the first thing I
checked. . all is correct.
Cheers Danny.
On 07/12/2013 16:44, Pete Lawless wrote:
Hi Danny
Good luck.
Pete
klinefelter.kevin(at)gmai Guest
Posted: Sat Dec 07, 2013 9:27 am Post subject: oil problem |
Did you purge the air from the oil system by pressurizing the oil tank?
On Dec 7, 2013, at 8:44 AM, "Pete Lawless" <pete(at)lawless.info> wrote:
Hi Danny
Good luck.
Pete
danny shepherd
Posted: Sat Dec 07, 2013 9:47 am Post subject: oil problem |
Hi Kev,
sure did. I've done this before without a problem.
cheers |Danny.
> Hi Danny
> Good luck.
> Regards
> Pete
Posted: Sat Dec 07, 2013 9:58 am Post subject: oil problem |
Hi Danny
Be interested to hear what you eventually find - if you can do it so can I!!
It's got to be something simple as all was well before the job was done.
Pete
danny shepherd
Posted: Sat Dec 07, 2013 10:08 am Post subject: oil problem |
I'll keep you posted.
Danny.
On 07/12/2013 17:57, Pete Lawless wrote:
Hi Danny
Pete
