Engine Heaters
bcarlson57(at)gmail.com
PostPosted: Sun Nov 24, 2013 12:19 pm    Post subject: Engine Heaters Reply with quote
I couldn't start my 601 with a Jabiru 3300 yesterday. OAT 35 degrees. The plane is new to me and I learned the Jabiru engine does like the cold.
I find the Tanis engine heater is recommended.
Do these come with installation instructions?
Bruce Carlson,
Hermiston, Oregon
Ron Lendon
PostPosted: Fri Nov 29, 2013 8:59 pm    Post subject: Re: Engine Heaters Reply with quote
FYI,
I use a 100 watt rough service bulb in a trouble light under the lower cowl and a quilt blanket on the upper cowl in the hangar here in Michigan. This morning at 17F oat and about 30F in the hangar it was 60F for the engine.
The trick is in placing the quilt close the air inlets so there are not chimneys for the warm air to escape. I just stuff the quilt in the holes. The light just stays on during the winter and gets inserted from below at the cowl exit.
It starts right up. I take the quilt and some bungee cord to secure it when I fly out for breakfast. Two hours later it still has enough heat to start right up.
Ron Lendon
CH 601 XLB
N601LT - Flying
Corvair Engine Prints:
