Tundra10
Joined: 14 Jun 2010 Posts: 102 Location: Scarborough, Ontario
Posted: Wed Nov 13, 2013 7:44 pm Post subject: Carling G-Series switch configuration |
Here is the link to the Carling G-Series toggle switch data:
http://www.carlingtech.com/sites/default/files/documents/Carling-TS-G-Series-Ext.pdf
I find the switching descriptions unclear.
I believe a 2GH51-73 is a standard toggle switch, with quick connect
terminals that operates as an AeroElectric 2-10. Can anyone confirm
that ?
And how would the 2GG switch actually operate ?
Jeff Page
Dream Aircraft Tundra #10
Posted: Thu Nov 14, 2013 9:43 am Post subject: Carling G-Series switch configuration |
At 09:42 PM 11/13/2013, you wrote:
The 2GH switch is form, fit and function equivalent
to the 2-10 switch. Carling just has a funny (?)
way of describing it's operation which should be
simply described as 2-pole, on-on-on, progressive
transfer.
[img]cid:.0[/img]
The isn't clear as to which of the 6 tab positions
on the switch are populated. I'm thinking that a
2GG switch is a 2GH with three of the six tabs simply
left off. Another variation on the theme is the
2GE switch having only 4 tabs . . . two are jumpered
together to fabricate a SP3T operation out of the
box. My guess says you can do any of these three
functions using a GH switch with simple choices
of how the terminals are wired (or not).
I wrote to them about this probably 20 years
ago . . . no response.
Hmmm . . . maybe they did respond and just didn't
tell me about it. Just found this document on Carling
that
http://tinyurl.com/mxv8g2l
This document confirms the suppositions cited
above.
50.08 KB |
4092 Time(s) |
Posted: Fri Nov 15, 2013 5:38 am Post subject: Re: Carling G-Series switch configuration |
2GH _ _ _ _CIRCUIT 1 ON_ _ _ _2 CIRCUITS ON_ _ _ _ CIRCUIT 2 ON
2GG _ _ _ 2 CIRCUITS ON _ _ _ CIRCUIT 1 ON _ _ _ OFF
The above is quoted from the Carlingswitch data sheet.
I interpret this to mean that 2GH is always on, either circuit 1 or circuit 2 is on, or both are on.
And 2GG is similar to the 2-10 switch. It can be off, or circuit 1 on, or both circuits 1 & 2 on.
It is hard to know for sure without having the switch in hand.
Joe
_________________ Joe Gores |
Tundra10
Posted: Wed Nov 20, 2013 8:55 am Post subject: Re: Carling G-Series switch configuration |
Hmm.
It looks from the diagram that the 2GE switch is the one with all six terminals.
Does anyone have any of these to confirm the switches are actually what the diagrams show ?
Circuit 1 on, Circuit 2 on are painfully useless descriptions when a two different connections can be made for each pole.
Jeff Page
77.29 KB |
4050 Time(s) |
