CHT
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> M14PEngines-List
ScottA
PostPosted: Mon Jun 19, 2006 7:46 pm    Post subject: CHT Reply with quote
I have CHT on #3, 6, and 9. #3 runs 20 to 25 C hotter than the other two.
Baffling is sealed up pretty good all around. It would seem 3 and 9 would
be similar as far as air flow. This is a Murphy Moose with the main outlet
on the bottom and two smaller air outlets on the side cheeks.
For starters what is the best way to test the CHT probe and make sure it is
not off?
Scott
- The Matronics M14PEngines-List Email Forum -
http://www.matronics.com/Navigator?M14PEngines-List
Claytonfly(at)comcast.net
PostPosted: Mon Jun 19, 2006 8:09 pm    Post subject: CHT Reply with quote
Scott
I would start by changing one of the probes on the #6 or #9 cylinders with
the one that is indicating hotter.
This should tell you if the probe is bad.
John
n395v
PostPosted: Tue Jun 20, 2006 3:48 am    Post subject: Re: CHT Reply with quote
Set up a pot of boiling water on a hot plate within reach of th probe and drop the probe in. It should read close to 212F or 100C.
If it is close in this ramge it is probably ok.
Alternatively you can get cooking oil up over 300 deg F if you have a good thermometetr to measure it.
Milt
dsavarese(at)elmore.rr.co
PostPosted: Tue Jun 20, 2006 4:02 am    Post subject: CHT Reply with quote
You can also use a laser temperature sensor and read the CHT's on each
cylinder with the probes exactly at the same point where the probes are
installed on each cylinder.
Dennis
ScottA
PostPosted: Tue Jun 20, 2006 8:24 pm    Post subject: CHT Reply with quote
Thanks for all the ideas.
Scott
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> M14PEngines-List All times are GMT - 8 Hours
