gyoung
Joined: 09 Jan 2006 Posts: 211 Location: Republic of Texas
Posted: Fri Nov 15, 2013 7:59 am Post subject: Dual Trim wiring |
I need to hook up the trim wiring on my -6 and am looking for relay/controller options. I’ve got trim switches (ail & elev) on both sticks. I picked up a Ariel mixer box some time ago that will isolate the dual trim. I just discovered it’s too big to mount between the seat ribs where I’d like to mount it. It also doesn’t address speed control. I’ve got a couple Matronics speed control modules and could wire them with the mixer but it gets to be a bit of a rats nest of wiring. So I’m looking for other options. I know about TCW Safety-Trim but it looks like it’s only set up for one stick. What else is out there? Thanks.
Greg Young
denis.walsh(at)comcast.ne Guest
Posted: Fri Nov 15, 2013 8:26 am Post subject: Dual Trim wiring |
I have used a matronics module for my elevator trim using two switches and it has worked very well for sixteen years. I have never used the speed control function. I find the trim is too slow at approach speeds and too fast at cruise. Just takes a little getting used to.
It seems to me you could scrap the other box and use the two matronics boxes in your system. You can use as many trim switches as you want with the matronics, without relay decks. There is no need for a mixer, whoever trims first wins. Those little boxes can go anywhere. Mine is glued on the airplane side near the pilot's left leg.
BEWARE if you do this. Note that the wiring of the stick switches is dramatically different for matronics than for using relays. Just follow Matronics directions. You know how I learned this.
Disclaimer. I know nothing about the mixer you describe, or the TCW unit. I do feel it is important to have a really quick way to disable the trim system. I have a pullable circuit breaker for this. One for each side would might be better.
DLW
On 15Nov, 2013, at 8:58 , bigdog(at)bentwing.com (bigdog(at)bentwing.com) wrote:
[quote]I need to hook up the trim wiring on my -6 and am looking for relay/controller options. I’ve got trim switches (ail & elev) on both sticks. I picked up a Ariel mixer box some time ago that will isolate the dual trim. I just discovered it’s too big to mount between the seat ribs where I’d like to mount it. It also doesn’t address speed control. I’ve got a couple Matronics speed control modules and could wire them with the mixer but it gets to be a bit of a rats nest of wiring. So I’m looking for other options. I know about TCW Safety-Trim but it looks like it’s only set up for one stick. What else is out there? Thanks.
Greg Young
style="color: purple; text-decoration: underline;">www.aeroelectric.com
href="http://www.buildersbooks.com/" style="color: purple; text-decoration: underline;">www.buildersbooks.com
style="color: purple; text-decoration: underline;">www.homebuilthelp.com
style="color: purple; text-decoration: underline;">www.mypilotstore.com
style="color: purple; text-decoration: underline;">www.mrrace.com
style="color: purple; text-decoration: underline;">http://www.matronics.com/contribution
style="color: purple; text-decoration: underline;">http://www.matronics.com/Navigator?RV-List
purple; text-decoration: underline;">http://forums.matronics.com
rnewman(at)tcwtech.com Guest
Posted: Fri Nov 15, 2013 8:50 am Post subject: Dual Trim wiring |
Our TCW trim controller works with two sticks, no extra wiring/relays required. All switches just wire in parallel.
Bob
TCW.
On Nov 15, 2013, at 10:58 AM, "bigdog(at)bentwing.com (bigdog(at)bentwing.com)" <bigdog(at)bentwing.com (bigdog(at)bentwing.com)> wrote:
[quote] <![endif]--> <![endif]-->
Greg Young
ctric.com
| Quote: | www.buildersbooks.com
uilthelp.com
otstore.com
cs.com
Posted: Fri Nov 15, 2013 9:41 am Post subject: Dual Trim wiring |
Best approach – use the Safety Trim unit and add a switch on the panel to toggle the common wire to the stick top hat between Pilot and Copilot. This establishes:
<![if !supportLists]>· <![endif]>Installed backup if the pilot switch jams/sticks. The panel switch then isolates the failed pilot stick top hat and you continue as normal using the co-pilot stick top hat.
<![if !supportLists]>· <![endif]>Allows for you to not have a non-pilot in the co-pilot seat mess with the trim.
Use a DPDT switch and put the flap common wire on the other terminal to get the same benefits. In other words the one switch transfers both flap and trim control between the pilot and co-pilot.
Carl
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of bigdog(at)bentwing.com
Sent: Friday, November 15, 2013 10:58 AM
To: rv-list(at)matronics.com
Subject: Dual Trim wiring
Greg Young
| Quote: | | <======================</ -- Please Support Your Lists This Month nbsp; (And Get Some AWESOME FREE November is the Annual List Fund Raiser. Click below to find out more Free Incentive Gifts bsp; * AeroElectric www.aeroelectric.com<www.buildersbooks.comwww.homebuilthelp.comwww.mypilotstore.comwww.mrrace.com | http://www.matronics.================[/b][/quote]http://forums.matronics.com[/url]=====[/b][b]
gyoung
Posted: Fri Nov 15, 2013 12:59 pm Post subject: Dual Trim wiring |
Thanks. I forgot that the Governor had that relay function. It’s been a long time since I looked at it and I was just thinking of the speed control. I should RTFM.
Greg Young
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Denis Walsh
Sent: Friday, November 15, 2013 10:26 AM
To: rv list matronics.com
Subject: Re: Dual Trim wiring
DLW
Greg Young
0 1 ==============[/b][/quote] sts This Month --[/b][/quote] And Get Some AWESOME FREE Gifts!)[/b][/quote] ick on[/b][/quote] t[/b][/quote] d[/b][/quote] aeroelectric.com">www.aeroelectric.com[/b][/quote] http://www.buildersbooks.com">www.buildersbooks.com[/b][/quote] .homebuilthelp.com">www.homebuilthelp.com[/b][/quote] w.mypilotstore.com">www.mypilotstore.com[/b][/quote] ww.mrrace.com">www.mrrace.com[/b][/quote] bution">http://www.matronics.com/contribution[/b][/quote] b>[/quote] bsp; -Matt Dralle, List Admin.[/b][/quote] ==============[/b][/quote] V-List Email Forum -[/b][/quote] >[/b][/quote] :p>[/b][/quote] /o:p>[/b][/quote] tor?RV-List">http://www.matronics.com/Navigator?RV-List[/b][/quote] ==============[/b][/quote] bsp; - MATRONICS WEB FORUMS -[/b][/quote] :p>[/b][/quote] tp://forums.matronics.com[/b][/quote] ==============[/b][b]
gyoung
Posted: Fri Nov 15, 2013 1:10 pm Post subject: Dual Trim wiring |
OK, so it’s wired like the Matronics Governor. I did RTFM for TCM and didn’t see any reference to multiple switches. So I guess it’s now an extra features/extra $$ choice. Any other vendors out there?
Greg Young
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Tcwtech
Sent: Friday, November 15, 2013 10:50 AM
Subject: Re: RV-List: Dual Trim wiring
Bob
TCW.
Greg Young
| Quote: | | ===================================ctric.com>www.buildersbooks.comuilthelp.comotstore.com matronics.com/contribution=================================== | 0 1 2 3
| 4 5 6 7 8 9 | Quote: | | =================================== | 0 | Quote: | | =================================== | 1 | Quote: | | =================================== | 2 | Quote: | | =================================== | 3 | Quote: | | =================================== | 4 | Quote: | | =================================== | 5 | Quote: | | =================================== | 6 | Quote: | | =================================== | 7 | Quote: | | =================================== | 8 | Quote: | | =================================== | 9 0 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5
