Possible plans error - RV-10 FF4-2, Figure 4 (drain
Tim(at)MyRV10.com
PostPosted: Mon Jun 19, 2006 5:24 am    Post subject: Possible plans error - RV-10 FF4-2, Figure 4 (drain Reply with quote
Tim,
I can't remember 100% what I did on this, but I did at one point go
to the local hardware store and buy an insert. I think what
I did was buy the insert for the thinner walled tubing and used that,
since the compression fitting supplied that goes on the fuel pump
was the same as is used on other things I've done in the past
using plain poly tubing. You could probably do either, use
the thick wall and the insert supplied, or buy an insert (almost
any plumbing/hardware place will have them) and use the specified
tubing. That fuel pump shouldn't be putting anything out anyway
unless there is a problem with it. I suppose if there was a
major problem, it might be nice to have the larger ID to handle
the flow.
Marcus Cooper wrote:
Tim,
Hopefully not too simplistic, but I just used the tubing that fit the
insert and used the other tubing for the FAB drain line. I can't imagine
using thinner wall for the drain line would impact anything. I didn't even
notice the plans error.
Marcus
