rv10rob(at)gmail.com Guest
Posted: Fri Nov 01, 2013 12:04 pm Post subject: Tires and tubes |
Based on feedback here, I think I'm going to stick with the Aero Classics tires, but switch to Michelan Airstop tubes. Anyone have an issue with this combination? Are there different valve stem angle options with these tubes? Thanks much...
-Rob
Rob Kochman
RV-10 Flying since March 2011
Woodinville, WA
http://kochman.net/N819K
Kelly McMullen
Posted: Fri Nov 01, 2013 12:54 pm Post subject: Tires and tubes |
This is what I have my -10 sitting on:
15/600-6 "Leakguard" Butyl Tube with the "New Easy Valve" for the
mains, and 500-5 "Leakguard" Butyl Tube with the TR-67 Valve for the
nose.
The tube for the mains was designed for Cirri, that have similar wheel pants access issues.
Leakguard is Desser's in-house branding of what is supposed to be same as Air Stop at lower cost. I think I put air in them once over past year to make moving fuselage easier.
On Fri, Nov 1, 2013 at 1:03 PM, Rob Kochman <rv10rob(at)gmail.com (rv10rob(at)gmail.com)> wrote:
| Quote: | Based on feedback here, I think I'm going to stick with the Aero Classics tires, but switch to Michelan Airstop tubes. Anyone have an issue with this combination? Are there different valve stem angle options with these tubes? Thanks much...
-Rob
Rob Kochman
Woodinville, WA
_blank">www.aeroelectric.com
="_blank">www.mypilotstore.com
ank">www.mrrace.com
tp://forums.matronics.com
- sent from the microchip implanted in my forearm
A&P/IA, EAA Tech Counselor
KCHD |
Jim Berry
Posted: Thu Nov 07, 2013 12:55 pm Post subject: Tires and tubes |
Isn't "leakguard" the stock tubes Van's sells? I'm still finding they lose about 10 psi over 2-3 months, so would rather go with something less leaky.
On Fri, Nov 1, 2013 at 1:54 PM, Kelly McMullen <apilot2(at)gmail.com (apilot2(at)gmail.com)> wrote:
| Quote: | This is what I have my -10 sitting on:
nose.
-Rob
Rob Kochman
Woodinville, WA
ank">www.mrrace.com
Rob Kochman
Woodinville, WA
Kellym
Posted: Thu Nov 07, 2013 4:49 pm Post subject: Tires and tubes |
Leakguard is what Desser Tire sells as lower cost equivalent to Michelin
Air Stop. I doubt that Vans supplies anything but the cheapest standard
variety tubes.
On 11/7/2013 1:54 PM, Rob Kochman wrote:
| Quote: | Isn't "leakguard" the stock tubes Van's sells? I'm still finding they
less leaky.
nose.
much...
-Rob
Rob Kochman
Woodinville, WA
_blank">www.aeroelectric.com <http://www.aeroelectric.com>
.com" target="_blank">www.buildersbooks.com <http://www.buildersbooks.com>
="_blank">www.homebuilthelp.com <http://www.homebuilthelp.com>
="_blank">www.mypilotstore.com <http://www.mypilotstore.com>
ank">www.mrrace.com <http://www.mrrace.com>
tp://forums.matronics.com <http://forums.matronics.com>
ank">www.mrrace.com
Rob Kochman
Woodinville, WA
KCHD |
Posted: Fri Nov 08, 2013 6:01 am Post subject: Tires and tubes |
Not in my kit. I just replaced all my tubes with the Leakguards. The ones I took off were not Leakguards. My experience has been the same with the non-leakguards. I will know in a few months whether the Leakguards are better.
Why did I replace them all? Because 1) I swapped tires for even wear and one is supposed to replace the tubes at that point as I understand it, and 2) I had a badly cracked front Matco wheel which I replaced.
Just FYI, I did replace the kit supplied wheel with the Matco WHLNW511.25 which as others have explained, is a better spec for this application.
http://www.mykitlog.com/users/display_log.php?user=MauleDriver&project=224&category=7984&log=180210&row=1
Bill "trying to conjure up a heat duct scheme for the rear heat vents so my copilot doesn't have to pack a blanket" Watson
On 11/7/2013 3:54 PM, Rob Kochman wrote:
[quote] Isn't "leakguard" the stock tubes Van's sells? I'm still finding they lose about 10 psi over 2-3 months, so would rather go with something less leaky.
nose.
-Rob
Rob Kochman
Woodinville, WA
Rob Kochman
Woodinville, WA
