Front Tire Installation
vernon.franklin(at)gmail.
PostPosted: Sat Nov 02, 2013 11:23 am    Post subject: Front Tire Installation Reply with quote
Has anyone run into this situation? Either my U-1009 Axle is to
short, or my U-1023 spacers are to long. You can see by the attached
pictures that I am about 1/8" short on the axle.
When I went to install the wheel, and torqued the AN6, the wheel
didn't turn very well. All of the pressure appears to be placed on
the spacers as opposed to the axle.
I verified the wheel halves are tight against each other.
Any ideas?
Vernon Franklin
 Filesize:  90.85 KB
 Viewed:  2650 Time(s)
 Filesize:  87.85 KB
jesse(at)saintaviation.co
PostPosted: Sat Nov 02, 2013 1:46 pm    Post subject: Front Tire Installation Reply with quote
That is the way it is supposed to be. The spacers are supposed to put a preload on the bearings so the axle doesn't turn. In the past I have turned down the axle w little to increase the preload. The wheel will not turn very freely, but you want to make sure the spacers do NOT turn, but rather the wheel turns while the bearings don't.
Jesse Saint
I-TEC, Inc.
jesse(at)itecusa.org
www.itecusa.org
www.mavericklsa.com
C: 352-427-0285
O: 352-465-4545
F: 815-377-3694
On Nov 2, 2013, at 3:22 PM, Vernon Franklin <vernon.franklin(at)gmail.com> wrote:
Any ideas?
Vernon Franklin
<20131102_135338.jpg>
<20131102_135324.jpg>
Kelly McMullen
PostPosted: Sat Nov 02, 2013 9:47 pm    Post subject: Front Tire Installation Reply with quote
Easily cured with a Matco axle in place of Van's home brew solution.
Lets you set preload on bearings independent of the nose gear forks.
On Sat, Nov 2, 2013 at 12:22 PM, Vernon Franklin <vernon.franklin(at)gmail.com (vernon.franklin(at)gmail.com)> wrote:
Any ideas?
Vernon Franklin
- sent from the microchip implanted in my forearm
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
bill.peyton
PostPosted: Sun Nov 03, 2013 6:49 am    Post subject: Re: Front Tire Installation Reply with quote
I would definitely order the Matco axle. It allows you to pre-load the bearings independent of tightening the axle nut. I think you will find a thread in regards to this issue either here or on VAF.
Bill
WA0SYV
Aviation Partners, LLC
PostPosted: Mon Nov 04, 2013 7:51 am    Post subject: Front Tire Installation Reply with quote
Thank you. Found it, and ordered the Matco axle and spacers.
Next question, on the main's bearings, is it advised to grease up the
felt dust covers or leave them dry?
What is the best practice with these?
Vernon
On Sun, Nov 3, 2013 at 8:49 AM, bill.peyton <peyton.b(at)sbcglobal.net> wrote:
Bill
WA0SYV
http://forums.matronics.com/viewtopic.php?p=411996#411996
Vernon Franklin
