etzimm(at)gmail.com Guest
Posted: Mon Aug 24, 2009 6:18 am Post subject: First Flight follow-up, |
On Aug 23, 2009, at 9:30 AM, John Hauck wrote:
| Quote: | | I have never flown a Kolb that could be flown with rudder alone, more than a very short time. When they begin to roll, rudder alone will not pick up tyhe wing. Because they lack any significant dihedral, if you lose aileron control, be nice to have a parachute. |
John,
I can fly indefinitely and pick up either wing in a bank with rudder only in my plane.
I believe it is due to the Hoerner type mod I have done to my wing tips.
None of the other kolb planes that I have ever flown, have had that capability.
Gene Z
Posted: Mon Aug 24, 2009 7:19 am Post subject: First Flight follow-up, |
Gene:Didn't you also add some additional dihedral to your wings?
I don't have a photo of your Kolb handy.
[quote] | Quote: | | I have never flown a Kolb that could be flown with rudder alone, more than a very short time. When they begin to roll, rudder alone will not pick up tyhe wing. Because they lack any significant dihedral, if you lose aileron control, be nice to have a parachute. |
John,
Gene Z
_________________ John Hauck
Titus, Alabama |
pj.ladd(at)btinternet.com Guest
Posted: Mon Aug 24, 2009 7:47 am Post subject: First Flight follow-up, |
find a regular storm of many outraged responses. >>
Hi Herb, get used to it. Some of the listers seem to have very short fuses. I have been accused of everything from having no experience to being anti American because I have explained that we do thinks differently this side of the pond. Not better, just differently.
But the majority are helpful, have more hours and miles under their wings than you could shake a stick at, and talk sound sense.
Perhaps you gave the wrong impression about how bad things were with your plane.
If your plane really wants to roll and takes a lot of stick to fly level look at your wing root attachments. There is room for a fair amount of adjustment by arranging the washers. I have mine full up on one side and full down on the other. If the plane rolls gently just because you are sitting on one side of the centre line a bungee round the stick to give a little leverage will suffice.
Ignore he diatribes, take the advice given, apply common sense to the suggestions made and you will be fine.
A couple of years ago I drove my brand new Mark3Xtra into a barn. Everyone was full of condolences and good wishes at the time but that doesn`t stop them occassionally reminding me that I was a bloody idiot . As if I need reminding!
Cheers
Pat
Posted: Mon Aug 24, 2009 10:10 am Post subject: First Flight follow-up, |
[img]cid:02E8ED0F-A811-48D7-9FDC-76F75B013671(at)gateway.2wire.net[/img]
[img]cid:3EB73288-70B7-4945-A45E-D3DBF54798A3(at)gateway.2wire.net[/img]
[img]cid:4F732969-C47D-4121-9E30-D495CC569329(at)gateway.2wire.net[/img]
[img]cid:1EF46A83-7A4C-44A2-9319-F04C79A68D92(at)gateway.2wire.net[/img]
[img]cid:C3CA1143-0A72-4678-A093-92F8CFF70F47(at)gateway.2wire.net[/img]
On Aug 24, 2009, at 10:33 AM, John Hauck wrote:
| Quote: | Gene:Didn't you also add some additional dihedral to your wings?
| Quote: | | Quote: | | I have never flown a Kolb that could be flown with rudder alone, more than a very short time. When they begin to roll, rudder alone will not pick up tyhe wing. Because they lack any significant dihedral, if you lose aileron control, be nice to have a parachute. |
John,
Gene Z
87.98 KB |
4998 Time(s) |
57 KB |
4998 Time(s) |
316.44 KB |
4998 Time(s) |
156.68 KB |
4998 Time(s) |
66.38 KB |
4998 Time(s) |
Posted: Mon Aug 24, 2009 10:27 am Post subject: First Flight follow-up, |
Looks good.
Glad it works.
Must be those tips.
Titus, Alabama |
Possums
Posted: Mon Aug 24, 2009 12:10 pm Post subject: First Flight follow-up, |
At 09:38 AM 8/24/2009, you wrote:
| Quote: | John,
capability.
Gene Z
Yep - I'll bet it's the tips.
70.45 KB |
4994 Time(s) |
158.32 KB |
4994 Time(s) |
94.53 KB |
4994 Time(s) |
_________________ Possum |
jbhart(at)onlyinternet.ne Guest
Posted: Mon Aug 24, 2009 12:23 pm Post subject: First Flight follow-up, |
in my plane. I believe it is due to the Hoerner type mod I have done to
my wing tips.
capability.
Gene,
Just some thoughts. There a couple of other factors that may help you. Your
lateral cg is centered and this puts equal load on each wing. Also, you
engine and propeller combination may weigh less than John's so your vertical
cg is lower. Both of these factors will promote increased lateral stability
given equal dihedral.
I have never let go of the stick and tried to fly the FireFly with just
rudder and throttle. I have put it on the short list to try. I do know
that when I had the 15 inch chord ailerons on the FireFly and flew to my EAA
Chapter meetings at Painton, I could not level the wings at cruise speed. I
just had to wait for the FireFly to right its self, but most of the time I
kicked a rudder pedal to help lift the low wing. After changing to nine
inch ailerons, and adding VG's, all I had to do was apply a little side
pressure to keep the FireFly from rolling when passing a wing tip through a
thermal.
FWIW
Jack B. Hart FF004
Winchester, IN
Posted: Mon Aug 24, 2009 12:24 pm Post subject: First Flight follow-up, |
Very nice work both of you. There may be a bit more vortex induced
but the stabilizing effect is worth it.
I'll wait until I hit something before I go in there.
BB
On 24, Aug 2009, at 4:03 PM, possums wrote:
| Quote: | At 09:38 AM 8/24/2009, you wrote:
> John,
> wing tips.
> that capability.
> Gene Z
<0.JPG><5 IM002601.jpg><4.JPG>
Posted: Mon Aug 24, 2009 1:11 pm Post subject: First Flight follow-up, |
| Quote: | Yep - I'll bet it's the tips.
Damn, they're sprouting up all over.
Titus, Alabama |
JetPilot
Posted: Mon Aug 24, 2009 1:31 pm Post subject: Re: First Flight follow-up, |
| etzimm(at)gmail.com wrote: | wing in a bank with rudder only in my plane.
Gene Z
Gene Z,
That is a really great Modification you did to the wingtips ! The stock wingtips are very poor, one of the few things Kolb got really wrong in the design of the plane. I know John H will take offense to this, but no plane on the planet is designed perfectly from day one, and even the best planes ever produced have been improved over the years. The Kolb is no different, a good plane, but still can be made a lot better. Any plane design that is not improved over time is at risk of becoming outdated and ceasing production. Once I saw the new wingtips Kolb put on the MK III Xtra, I have been thinking about what to do about my old style and inefficient wingtips. As it is now, the last 1 1/2 foot of each wingtip has no good airfoil and is basically wasted. The air coming over this non airfoil wing tip for the last 1 1/2 feet cant be doing the aileron response much good either. I like the Droop tips that Kolb is now putting on the MK III's, but I do not do fiberglass work that well, and I still think I can do just as well with hoerner type wingtips.
I did a lot of research on wingtips and thier effect on airplanes, and decided to put Hoerner wingtips on my MK III Xtra. I have even gone as far as to buy all the parts needed to do this from Kolb, and have them sitting in my Workshop. It is just a matter of finishing another plane before I do this project on my Kolb. Did you change your wingtips on an existing plane, or did you build the plane with them from day one ??? I would really be interested to get your performance numbers and any other differences you notice in flight characteristics.
Mike
Kolb MK-III Xtra, 912-S |
Thom Riddle
Posted: Mon Aug 24, 2009 3:48 pm Post subject: Re: First Flight follow-up, |
I can't say what the Hoerner style wingtips will do for a Kolb wing but can tell you they make a world of difference on a Cherokee 140. Can't tell much difference at high cruise but slow flight lateral control and stability were much improved over the standard Cherokee wingtips.
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
Posted: Wed Aug 26, 2009 11:08 am Post subject: First Flight follow-up, |
On Aug 24, 2009, at 5:29 PM, Jack B. Hart wrote:
| Quote: | Gene,
you. Your
you
vertical
stability
Jack B. Hart FF004
Winchester, IN
Jack,
The position of the cg does have a significant effect on roll
performance. However on my plane with the modified hoerner type wing
tips the cg is significantly lower than on my Mark II. giving it more
pendulum effect which works to resist rolling. To roll out of a bank
angle with rudder only the hoerner type tips must over power this
greater pendulum stability.
My Firestar with the hoerner modified tips will pick up a wing with
rudder only. On my Mark II will not, But The Mark II does have a
noticeably quicker aileron roll response, I believe primarily because
the cg is closer to the center of the wing's roll axis.
Gene
Dana
Posted: Wed Aug 26, 2009 1:48 pm Post subject: First Flight follow-up, |
At 03:06 PM 8/26/2009, Eugene Zimmerman wrote:
| Quote: | My Firestar with the hoerner modified tips will pick up a wing with
That makes sense. The slanted underside of he Hoerner tips probably gives
a little dihedral effect, and it's dihedral (which stock Kolbs have little
or none of) that's necessary for rudder to induce roll.
-Dana
Lie ? Me ? Never! No, no, no, the truth is far too much fun!
