What's the nose and main wheels required tire pressure?
Goto page Previous  1, 2
rv10flyer
PostPosted: Tue Apr 23, 2013 3:30 am    Post subject: Re: What's the nose and main wheels required tire pressure? Reply with quote
If moisture is present it contributes to a greater change in pressure simply because at lower temperatures water condenses to become a liquid. The liquid form of water occupies very little volume and contributes only a negligible pressure to the tire. But at higher temperatures, such as those in a running tire, water evaporates inside the tire and becomes a gas which increases pressure in the tire.
Wayne G.
rv10flyer
PostPosted: Tue Apr 23, 2013 3:32 am    Post subject: Re: What's the nose and main wheels required tire pressure? Reply with quote
1% Water Vapor and Other Gases – Escapes up to 250 times faster than Nitrogen
21% Oxygen – Escapes 3-4 times faster than Nitrogen
78% Nitrogen – The largest molecule in
air, dry, non-flammable.
Wayne G.
Bob Turner
PostPosted: Tue Apr 23, 2013 1:30 pm    Post subject: Re: What's the nose and main wheels required tire pressure? Reply with quote
Wayne,
I believe what you are quoting are not "escape rates" but rather the diffusion coefficients of O2 and N2 thru rubber, in units of "number of molecules per thickness per area per partial pressure difference".
To get the diffusion rate you need to multiply these numbers by the difference in partial pressures (inside to outside). For a typical plane tire (filled to 45 psig, or 60 psi absolute) the difference in partial pressures are 36 psi for N2, 9 psi for O2; so in fact the rate of loss (assuming the diffusion coefficient for O2 is 4 times higher) is the same for both. Now, because there is less oxygen, a given number loss results in a larger fractional loss, so this will result in a net loss of total pressure which is faster than pure N2, and can be seen in carefully controlled laboratory experiments, but it is nowhere near 4 times faster. Furthermore, as has been pointed out, after one or two re-fills of air the tire has become enriched with N2 and depleted of O2, and is essentially similar to the original all N2 tire, which will have O2 leaking in from the outside until it has 3 psi (absolute) of O2 inside.
Bob Turner
RV-10 QB
johngoodman
PostPosted: Wed Apr 24, 2013 5:22 am    Post subject: Re: What's the nose and main wheels required tire pressure? Reply with quote
I can't resist jumping into this one. I have 106 landings on the original Van's tires. I have only filled them once - when I built them. They still have 42 in the mains and 40 in the nose. I don't have wheel pants (hate 'em). Here is a photo. Notice no uneven wear.
John
 Filesize:  36.88 KB
 Viewed:  8950 Time(s)
jfrjr(at)roadrunner.com
PostPosted: Wed Apr 24, 2013 11:51 am    Post subject: What's the nose and main wheels required tire pressure? Reply with quote
John Goodman: I understand you don't like wheel pants but in my 10 they make a huge difference in airspeed. I took mine off before flying from KLVK to KSNS for painting. After reaching cruise altitude (8.5K) I noted a 12K drop from my usual IAS after double checking all my settings. I also had removed the main gear fairings but not the nose wheel. After the paint job and with the fairings and pants back on the IAS were back to the former "normals". In fact I may have gained a knot or two (? clear coat?). Jay Rowe N333GR
On Apr 24, 2013, at 6:22 AM, "johngoodman" <johngoodman(at)earthlink.net> wrote:
John
#40572 Phase One complete and flying.
http://forums.matronics.com/viewtopic.php?p=399274#399274
http://forums.matronics.com//files/rv10tire_566.jpg
johngoodman
PostPosted: Wed Apr 24, 2013 12:27 pm    Post subject: Re: What's the nose and main wheels required tire pressure? Reply with quote
Did you remove the wheel pant brackets? Probably not. I have all the fairings, but no pants. My hubcaps probably give me a knot, as well. I'm guessing that the lack of pants costs me 5 knots, max. The ability to pre-flight the wheel every time is worth it - form follows function.
John
Bob Turner
PostPosted: Wed Apr 24, 2013 2:47 pm    Post subject: Re: What's the nose and main wheels required tire pressure? Reply with quote
I think you're both right. Like Jay, I noticed something like a 12 knot gain between fairings and no fairings. But I also noticed, as Vans has said, that most of the gain was due to the gear leg fairings, not the wheel pants.
Bob Turner
RV-10 QB
rv10flyer
PostPosted: Wed Apr 24, 2013 4:13 pm    Post subject: Re: What's the nose and main wheels required tire pressure? Reply with quote
I can believe 5 kts like Bob. A round tube has 9 times the drag of a airfoil shape.
John, you started out with 42 psi and one year later ended with 42 psi? You have some super rubber there! Or maybe every time you fly with your tires exposed, the 160 kt air molecules are keeping the pressure maintained.
I do love the looks and speed of my pants. Exposed tires/brakes were really nice for rentals. On mine, my preflight consist of ensuring they are not flat and that I have good brake pressure.
Wayne G.
Tim Olson
PostPosted: Wed Apr 24, 2013 4:33 pm    Post subject: What's the nose and main wheels required tire pressure? Reply with quote
I really wouldn't be hard to get rid of the ugly exposed wheels by putting the fairings on, but install a Camlok or similar latch right over the brakes if you really wanted the speed, efficiency, AND ability to do a full preflight of the wheels often. There is middle ground.
Tim
On Apr 24, 2013, at 7:13 PM, "rv10flyer" <wayne.gillispie(at)gmail.com> wrote:
Wayne G.
SB 12/01/2009-12/01/2011
TT= 103
http://forums.matronics.com/viewtopic.php?p=399310#399310
johngoodman
PostPosted: Thu Apr 25, 2013 4:25 am    Post subject: Re: What's the nose and main wheels required tire pressure? Reply with quote
Actually, I don't think the wheels are ugly. I guess it's just my background. I learned to fly in the Navy and on every airplane I ever flew, you could see the tires. Now that I'm long retired from the Navy and Northwest Airlines, I have finally seen airplanes with pants. I just plain don't like the looks of them. The RV-10 looks like it has watermelons where the tires should be.
I understand the drag thing, but it was pretty obvious that you are only loosing a couple of knots per wheel. I cleaned up the wheels as much as I could and added hubcaps to the mains - painted to look like the wheel of an AF-18. I actually experimented with a small airfoil directly behind the tire but never had the guts to test them. I was concerned about vibration and harmonics.
I'm happy with the results. Besides, think of all the money I saved by not having painted watermelons...(g)
John
 Filesize:  42.63 KB
 Viewed:  8899 Time(s)
Mike Whisky
PostPosted: Thu Apr 25, 2013 7:33 am    Post subject: Re: What's the nose and main wheels required tire pressure? Reply with quote
I just love this forum thanks to all who answered my question and I will start as per plans and see how things develop from there.
Mike
RV-10 builder (flying)
#511
rv10flyer(at)live.com
PostPosted: Thu Apr 25, 2013 8:16 am    Post subject: What's the nose and main wheels required tire pressure? Reply with quote
just make sure the gap around the wheelpants and wheels are wide enough,
lower psi than you initially put in will cause the tire sides to bulge and
rub against the wheel pants, especially on landings. 1"gap all around is a
good start.
rv10flyer
PostPosted: Thu Apr 25, 2013 10:06 am    Post subject: Re: What's the nose and main wheels required tire pressure? Reply with quote
I left 3/4" all the way around. I have had 42 plus or minus 5 psi in the mains with many full load/firm landings and no evidence of rubbing the red paint as of last week.
Wayne G.
Page 2 of 2
