lgdavid2(at)verizon.net Guest
Posted: Sun Jul 08, 2012 4:15 pm Post subject: KIS-List |
Limp home destroyed my plane and slightly damaged George Moore's plane. The limp home problem will occur under a variety of conditions when the ECU logic thinks the engine will be damaged. This feature is active when the sensors think the "car" is in "neutral" or "park." The solution is to simply ground the pins associated with "park" and "neutral." There was an article in Contact Magazine in 2006 or 2007 explaining which pins needed to be grounded. I don't remember which pins to ground so if anyone needs this information, they should search the archives of Contact Magazine and get the right information.
Larry David
former KIS TR1 #45
On 7/8/2012 7:44 AM, Bill Schertz wrote: | Quote: | Another thing to have him check is on the ECU, if the ‘limp home’ mode has been disabled. KIS Tr-1 owner had a Subaru and it went into ‘limp home’ mode when temps got high, and he didn't have enough power to stay airborne and lost the plane.
Bill Schertz
KIS Cruiser #4045
N343BS
Phase one testing Completed
Sent: Sunday, July 08, 2012 9:20 AM
Subject: Re: KIS-List
THANKS! I will pass this on to him so he can make a "informed" decision. I am "old school" that still relies on engines designed for aircraft. I am not an experimenter when it comes to engines.
Galin
On Sun, Jul 8, 2012 at 7:55 AM, Graham Brighton <gbrighton(at)skymesh.com.au (gbrighton(at)skymesh.com.au)> wrote:
| Quote: | Galin,
Have only seen the masses of VERY mixed opinions of the Eggenfellner set up ... Your friend should do LOTS of hmwork on this idea . There was an entire Forum running, of dissatisfied Eggenfellners owners who got together to try and get their FWF combos sorted ...!! The challenge is to harness the advances of modern technology and apply this to aviation use . Single lever engine control ... stable engine temps through climb/decent ... ignition timing optimizing power and fuel efficiency (knock control) ... are the main gains ...
The task involves three major items ..Engine .. ECU (engine computer) ... and the Redive ( gearing of engine speed to Prop speed .... The three units of course have to work in concert ...sounds easy enough .. But each one has its own index of special complexities ... and marrying this up is the 'holy grail' ..that aero/auto folks strive for ... as yet its still an untamed beast and not suited to the faint hearted ...!!!
Cheers
Graham
Sent: Sunday, July 08, 2012 1:44 PM
A friend of mine is thinking about buying an RV-9 with an Eggenfelder/Subaru engine and I know some here have experience with this set up. Is there anything he should be looking for or wary about with this engine?
Galin
On Fri, Jul 6, 2012 at 12:46 AM, Graham Brighton <gbrighton(at)skymesh.com.au (gbrighton(at)skymesh.com.au)> wrote:
href="http://www.matronics.com/Navigator?KIS-List">http://www.matronics.com/Navigator?KIS-List
| | - The Matronics KIS-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
