smokey_bear_40220(at)yaho Guest
Posted: Thu Jun 01, 2006 8:21 am Post subject: Wood Prop Advice |
Hi John,
Sounds like good performance to me.
I have CAP prop which uses Warp blades, but can`t
match your performance - yet. Part of the problem is
that my ROC gauge is faulty. Got it at the limits of
adjustment and it shows 125 ft/min descent in level
cruise. More off as it goes above zero.
I forget the results of my timed climbs, but not
1500'/min. I usually climb at over 60 knots so I can
see anyway.
How do you determine 75% and 80%?
I think I use 50% or less at 85 knots based on fuel
flow. Produces a better true with altitude. I
probably use 80% for takeoff. Never twice exactly the
same without a pitch gauge on an adjustable prop.
I agree that a wood prop would look nice too, but
better on the round cowl.
Kurt S.
--- John Anderson <janderson412(at)hotmail.com> wrote:
| Quote: | Well I can't say and I have to respect your opinion.
I've only flown one
Fox (mine) and behind a 3 blade 72" ground
adjustable Warpdrive and one up
and 1/2 fuel, 1500' per min at 55kts 80% power and
97kts cruise at 75%
(after tweeking the pitch to suit) is pretty good to
me. John A.
redbowen(at)hotmail.com Guest
Posted: Thu Jun 01, 2006 8:32 am Post subject: Wood Prop Advice |
Props Inc is great to work with. If you do not achieve the RPM performance
you want they will adjust the pitch until you are satisfied.
[quote]From: "Randy Daughenbaugh" <rjdaugh(at)rapidnet.com>
Subject: RE: Wood Prop Advice
Date: Thu, 1 Jun 2006 08:58:35 -0600
Is it true that the finish on wood props doesn't stand up to flying in
rain?
I wouldn't want to feel restricted from flying in rain.
Maybe I am being too practical,,,,,,
Randy
Michel
Posted: Thu Jun 01, 2006 10:18 am Post subject: Wood Prop Advice |
On Jun 1, 2006, at 4:58 PM, Randy Daughenbaugh wrote:
| Quote: | Is it true that the finish on wood props doesn't stand up to flying in
rain?
Well, I believe there are several type of wood props, Randy. Some are
epoxy coated some are ... coated with something else, I don't know. But
I have a Jabiru prop because I have a Jabiru engine and direct drive
engines should have a wood prop because of the vibrations, I am being
told.
I asked my Jabiru dealer about the effect of the rain and his words
are: If you fly in rain, reduce RPM to 2,400 (3,000 being my level WOT
RPM). I can live with that. My prop has a rubbery leading edge and I
understand that it could be damaged if it spins for a longer time at a
higher RPM. I guess the intensity of the rain has also something to
say, as the size of the raindrops. I have been flying in thin drizzle
rain with not effect on the prop. I guess when it's the big rain shower
type of weather, I'll try to fly around it. Often showers are only very
local.
Michel
_________________ Kitfox 3 - Jabiru 2200 |
janderson412(at)hotmail.c Guest
Posted: Thu Jun 01, 2006 11:54 pm Post subject: Wood Prop Advice |
Yes Kurt, I tend to climb faster too but for the test result I've put it
through the paces. 5000max, 4600 (at)55kts BRC speed 1500'pm (just one up of
course) and 4300 97kts level. Ive settled at 4000 for cruise as runs
smoothest there and 90. I notice quite a boost drop from 4300 down to 4000.
I've very pleased with how well it has turned out (touch wood), as you know
I have EFI, intercooler, EA82 turbo, strut fairings, speedster tail, elv gap
seals and spring gear mounting fairings
From: kurt schrader <smokey_bear_40220(at)yahoo.com>
Date: Thu, 1 Jun 2006 09:17:16 -0700 (PDT)
Hi John,
see anyway.
Kurt S.
I've only flown one
97kts cruise at 75%
me. John A.
Read the latest Hollywood gossip (at) http://xtramsn.co.nz/entertainment
