In flight Adjustable Trim
Goto page Previous  1, 2
williamtsullivan(at)att.n
PostPosted: Thu Feb 18, 2010 7:12 am    Post subject: In Flight Adjustable Trim Reply with quote
Ellery- GM electric window regulators are used in a lot of equipment, but I don't know about the relative weight.
      Bill Sullivan
      Windsor Locks, Ct
      FS 447
      38 degrees, sunny
icrashrc
PostPosted: Fri Feb 19, 2010 3:44 am    Post subject: Re: In flight Adjustable Trim Reply with quote
That actuator has 2" of travel and normally moves at 1/2" per second at full load. It's rated for 150 lbs of force while moving, 300 lbs. holding. It can be slowed down to about 10 seconds for full travel if needed. I have a off the shelf 3 position driver that will be set for the same 3 positions you could get with the stock handle. I may build or buy a infinite adjustable driver in the future but i wanted to start with the 3 known flap positions.
John Hauck wrote:
You mean like this?
http://www.ill-eagleaviation.com/electric_flap_drive.htm
Scott
Scott/Gang:
How fast is the actuator through full travel?
The MKIII doesn't like to climb with full or half flaps. Climbs much better
clean.
I like the almost instantaneous capability of going from full flaps in
landing configuration to climbing out clean in a go around situation.
Infinite adjustment of flap angle might be fun to play with in the air.
Global warming is ruining my flying. My airplane needs to be washed when
the ice in the bucket and the hose thaws.
john hauck
Scott
www.ill-EagleAviation.com
PostPosted: Fri Feb 19, 2010 6:14 am    Post subject: In flight Adjustable Trim Reply with quote
That actuator has 2" of travel --------
Scott
Scott/Gang:
Is there a provision for the actuator to return to the zero degree position
(flaps clean) should the system malfunction?
john hauck
lucien
PostPosted: Fri Feb 19, 2010 6:30 am    Post subject: Re: In flight Adjustable Trim Reply with quote
John Hauck wrote:
Scott/Gang:
john hauck
FWIW, if it's like mine and it looks like it is, it's stuck where it is if the actuator fails or otherwise goes offline. For that reason, I don't dump full flaps until I have the landing spot made or otherwise don't go into a configuration that I can't recover from if it's likely I'd have to (training from the C150 days).
Wish I had manual flaps too. Tho if I go Kolb again my model won't have em....
LS
LS
Titan II SS
lucien
PostPosted: Fri Feb 19, 2010 6:35 am    Post subject: Re: In flight Adjustable Trim Reply with quote
BTW, that is just darn cool. My compliments to your engineering, looks very well done....
LS
LS
Titan II SS
by0ung(at)brigham.net
PostPosted: Fri Feb 19, 2010 8:25 am    Post subject: In flight Adjustable Trim Reply with quote
John
Instead of mounting the actuator fixed on the root tube, mount it on a
slide, reverse the direction of the flap handle movement. So if the
actuator gets stuck, you can pull the flap handle to go to a clean config.
Or kiss
Boyd
Scott/Gang:
john hauck
slyck(at)frontiernet.net
PostPosted: Fri Feb 19, 2010 8:42 am    Post subject: In flight Adjustable Trim Reply with quote
Personally I like the feeling of feedback pressure when I pull down on the flap handle. It's also
good to be able to release it smoothly at your discretion during climbout.
At first there was a little groping for the handle, located above my right shoulder, but soon the location
became automatic. Fortunately I don't have any joint pain in that action.
It feels the same as the way I slow my old driveway snowplow (no brakes), lower the blade.
BB
On 19, Feb 2010, at 11:22 AM, b young wrote:
John
Or kiss
Boyd
Scott/Gang:
john hauck
PostPosted: Fri Feb 19, 2010 8:46 am    Post subject: In flight Adjustable Trim Reply with quote
Or kiss
Boyd
Boyd Y/Gang:
The MKIII standard flap actuation system works well for me in my airplane,
primarily because I fly right seat, stick in right hand, left hand on
throttle or flap handle when necessary.
It is a little more difficult to pull flaps when flying left seat in a
single center mounted stick MKIII because I have to twist to the right to
hold the control stick, then pull the flap handle.
The electric actuator would be a plus for pilots that have difficulty
pulling the handle because of age and/or lack of physical ability to pull
it.
john hauck
PostPosted: Fri Feb 19, 2010 8:52 am    Post subject: In flight Adjustable Trim Reply with quote
lower the blade.
BB
I had forgotten about the air brake action of the flaps on the MKIII.
When I first started flying the MKIII the amount of drag induced by flap
deployment was readily noticeable. Seemed like it would throw me into the
harness.
Now, I am not aware of that deceleration, but I know it is still there.
Really helps me to lose altitude without gaining excessive airspeed when I
need it.
john hauck
PostPosted: Fri Feb 19, 2010 9:47 am    Post subject: In flight Adjustable Trim Reply with quote
john hauck
that is part of the reason I installed an inverted L on the center stick,
it can be reached very easily with the left hand, for flying,(give my right
arm a rest), making adjustments to throttle flaps etc. I am sure it is not
as convenient as dual controls, but it was much easier and quicker to build.
Boyd Young
MKIII
PostPosted: Fri Feb 19, 2010 9:59 am    Post subject: In flight Adjustable Trim Reply with quote
I am sure it is not
Boyd Young
Boyd Y/Gang:
If Brother Jim had not designed and built my dual controls (the first for a
MKIII) in 1991, I'd being flying with a single center mounted stick. I
transitioned into the Factory MKIII with a center mounted single stick.
I'd also be flying left seat, instead of right.
john hauck
titus, alabama
MKIII
russkinne(at)mac.com
PostPosted: Fri Feb 19, 2010 10:13 am    Post subject: In flight Adjustable Trim Reply with quote
John
Interesting thread about the use of Kolb flaps. Do you normally
deploy flaps going into your strip? Full flaps?
Russ K
brakes),
lower the blade.
BB
flap
into the
harness.
there.
when I
need it.
john hauck
PostPosted: Fri Feb 19, 2010 10:46 am    Post subject: In flight Adjustable Trim Reply with quote
Do you normally
Russ K
Russ K/Gang:
The only time I do not use full flaps is when the wind is mixed up and
strong, especially a cross wind. I am referring to winds most folks don't
normally fly Kolbs.
To stay current in my airplane I occassionally shoot clean approaches.
There is a considerable change in glide and also an attitude change between
clean and full flaps in the MKIII.
Unlike some on the Kolb List, I do not have a problem with flaps and
MKIII's. The MKIII does not instantly quit flying with our without flaps,
unless the pilot quits flying the aircraft. It may not float like an
Aeronca Champ, but the pilot should fly the MKIII according to the MKIII's
glide characteristics. Unless pilot input dictates, the MKIII performs
nicely through a full flare to a three point landing. The standard MKIII
will usually hit tailwheel first, but the pilot can also control the
attitude of the MKIII to prevent this maneuver from becoming exagerated.
With the different main gear and true three point stance of my MKIII, I
still occassionally overcompensate and hit tailwheel first. My MKIII does
not complain when I get overly aggressive. Sometimes it is necessary to get
my MKIII on the ground now to get the brakes working.
People who do not and will not use full flaps on the MKIII have never
learned to fly the airplane. They have mastered only part of this fine
little airplane's capabilities.
Not that difficult to set the MKIII landing up, clean or full flaps, to land
to a point you pick on the ground, just like shooting an approach in a
helicopter.
john hauck
joepilot503
PostPosted: Sat Feb 20, 2010 11:23 pm    Post subject: Re: In flight Adjustable Trim Reply with quote
I installed in flight trim wheel from Rans, works great. here is a photo. Brian.
 Filesize:  270.35 KB
 Viewed:  11840 Time(s)
elleryweld(at)aol.com
PostPosted: Sun Feb 21, 2010 6:37 am    Post subject: In flight Adjustable Trim Reply with quote
I purchased one of them a while ago and built it into my panel I wasn't happy with it , it is two slow moving & not enough travel you could never land with it if you ever had an elevator cable break unless you had a two mile runway and 800 mile aproach , so I built a new panel and am working on another set up
Ellery Batchelder Jr.
PostPosted: Sun Feb 21, 2010 6:43 am    Post subject: In flight Adjustable Trim Reply with quote
anyone need a trim wheel setup  like Brian's that fits a Rans I have one to get rid of it works good but not to my satisfaction
lucien
PostPosted: Sun Feb 21, 2010 6:50 am    Post subject: Re: In flight Adjustable Trim Reply with quote
Speaking of that, what are the elevator stick forces like in the Mark III? I remember on my FS II the controls were so light I'd just hold the stick to keep a desired trim. Even on an xcountry I hardly even noticed it lol.
But seriously yeah I did occasionally want a trim system anyway as my FS II wanted to fly around 70mph hands-off which was a little hotter than I liked for the engine....
LS
LS
Titan II SS
PostPosted: Sun Feb 21, 2010 7:35 am    Post subject: In flight Adjustable Trim Reply with quote
for the engine....
LS
Folks:
Stick forces in a MKIII depend on a lot of variables:
-Airspeed.
-Load.
-One or two up.
When the MKIII is trimmed correctly, the fore and aft control stick forces
are light, as with all the other Kolb models. To increase sensitivity,
reliability, and make elevator control input more precise, I installed 1/8"
up elevator control cable when I built my mkIII in 1991. At the time, I did
not realize how much the 3/32" stretched when flying, especially with a
passenger. Many years later, while flying the initial tests on the newest
Kolb MKIIIx, I discovered up elevator control cable stretch once again. We
changed up to an 1/8" elevator cable and the problem with excessive up
elevator control stick travel went away. There is a lot of load on the up
elevator cable with pilot only, which goes up quite a bit more when we add a
passenger.
Untrimmed stick forces qickly become quite evident during cross country
flight. One's hand and arm will tell you, plus difficulty maintaining a
constant heading and/or altitude. Local flying, one normally will not pick
up on slight untrimmed stick forces.
If one is flying "a little hotter than I liked for the engine..." I'd reduce
power.
Any kind of cross country with untrimmed stick pressure would be very
difficult, uncomfortable, and unenjoyable.
john hauck
Page 2 of 2
