Lynn Matteson
Posted: Wed Feb 03, 2010 10:08 am Post subject: Source for small diameter fire sleeve? |
You'll love silver soldering once you try it and are successful. The
whole trick is in getting the metal clean, and using the proper flux.
I would suggest not using the hardware store *kit* silver solder, but
use the welding store stuff. The brassy-looking stuff....about $16-20
per ounce...is real silver solder, the hardware store stuff that
looks grey and melts with almost any electric iron/gun is not, and I
don't think it's got the strength either. The flux is a damp paste
(that can be diluted with water if it dries out) that is applied to
the work (any ONLY where you want the solder to flow) then heated
with a propane torch and the solder applied. When heating the joint,
you'll see the flux bubble up and dry out, then turn watery again,
and that's when it's time to stick the solder into the flame and onto
the joint. It is very satisfying to see the solder flow (capillary
action) all around the joint, making a nice-looking fillet usually.
Have fun, Noel...SS'ing is a blast.
Lynn Matteson
Jabiru 2200, #2062, 845.1 hrs
Countdown to 1000 hrs~155 to go
Sensenich 62"x46" Wood (summer)
Sensenich 55.5" x 46" Wood (winter)
Rotec TBI-40 injection
Status: flying (and learning)
On Feb 2, 2010, at 7:18 PM, Noel Loveys wrote:
| Quote: | One of the things I wished we did in technical college was silver
soldering.
I'm not too bad with regular solder but that's another game all
together.
We did get some experience on the English wheel.. Watch the fingers!
Students were not allowed to use the lathes for some reason.
Welding was
also out even though all the equipment was there.
Noel
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Float Flyr
Posted: Wed Feb 03, 2010 3:52 pm Post subject: Source for small diameter fire sleeve? |
I take it there is a special tip used for silver soldering.
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Lynn Matteson
Posted: Wed Feb 03, 2010 7:28 pm Post subject: Source for small diameter fire sleeve? |
Special tip? Are you thinking this is a job for an electric soldering
iron or gun? The real silver solder I'm talking about needs 1370-1550
° F. to melt. Maybe I was using the term "soldering" too loosely, but
that's what everyone calls it....silver soldering. Now I'm finding
that the proper term is "silver brazing". Here we go again with
people (me included) using terms from 100 years ago, while the rest
of the world has caught on to the new lingo. So silver brazing is the
"in" term, and it requires something on the order of a propane mini-
torch or butane torch to melt it. I just used a butane torch to be
sure I knew what I was talking about, and yes it melted it, and I'm
pretty darn sure that you won't find an electric tool that will melt it.
The stuff I use is Safety-Silv 45, and contains 45% silver, 30%
copper, and 25% zinc. The hardware store stuff that I have contains
2% silver and 98% tin, and melts at 450°...(alphametals is the brand
name). That's why I say the hardware store stuff is not really up to
the task...ok, secretly I call it junk. I just did a google search
for Safety-Silv 45 and found, among others, a site at Home Depot
where a kit costs $28.07 and zooming in on their picture I see that
this kit has a small bottle of paste flux containing 1.75 ounces of
flux, and they show a small amount of coiled silver alongside of the
flux. I'm guessing that's 1 ounce of silver, so you can see the stuff
isn't cheap. But it goes a long way.
Lynn Matteson
On Feb 3, 2010, at 5:31 PM, Noel Loveys wrote:
Noel
N369LM |
Pat Reilly
Posted: Thu Feb 04, 2010 10:18 am Post subject: Source for small diameter fire sleeve? |
Tom, Do you have a paper McMaster Car catelog? I can't get them to send me one and I definitely prefer the hard copy over online catelogs.
Pat Reilly
On Wed, Feb 3, 2010 at 8:29 AM, Tom Jones <nahsikhs(at)elltel.net (nahsikhs(at)elltel.net)> wrote:
Pat Reilly
Mod 3 582 Rebuild
Rockford,IL
Tom Jones
Joined: 12 Mar 2006 Posts: 752 Location: Ellensburg, WA
Posted: Thu Feb 04, 2010 10:32 am Post subject: Re: Source for small diameter fire sleeve? |
| Quote: | Tom, Do you have a paper McMaster Car catelog? I can't get them to send me one and I definitely prefer the hard copy over online catelogs.
Pat Reilly |
Pat, the last McMaster Carr catalog I have...if I can even find it...is at least 12 years old. Yes. their on line version is somewhat cumbersome to find things.
_________________ Tom Jones
Classic IV
Ellensburg, WA |
