Matt Dralle Site Admin
Joined: 08 Nov 2005 Posts: 27562 Location: Livermore CA USA
Posted: Tue Apr 18, 2006 3:36 pm Post subject: Phatnoise Connection Problem - Help?! |
Cut the reset line on the cable. Sounds to me like the PB is holding that line down and never letting anyone else init.
Matt
At 04:27 PM 4/18/2006 Tuesday, you wrote:
Well, I went and tried every option I could think of within my resources, short of unhooking the 4000x and connecting the C30 directly to the C90, then from it split out to the 4000x, PB, and my changer and XM respectively. Here's a list of the attempts and their corresponding outcomes:
Phatbox (PB) plugged directly into the Changer Input of the 4000x: PB powers up fine and is recognized, 4000x disappears and the C90 only sees the PB.
XA-C30 plugged into the Changer Input of the 4000x, PB in Control 1 of C30: PB powers up fine and is recognized, 4000x disappears and the C90 only sees the PB.
XA-C30 plugged into the Changer Input of the 4000x, PB in Control 1 of C30, Changer in Control 2 of C30: PB powers up fine and is recognized, 4000x and Changer both disappear, C90 only sees the PB.
XA-C30 plugged into the Changer Input of the 4000x, PB in Control 1 of C30, XT-XM1 in Control 2 of C30: PB powers up fine and is recognized, 4000x and XM Radio both disappear, C90 only sees the PB.
XT-XM1 plugged into the Changer Input of the 4000x, PB plugged into input of XT-XM1: PB Powers up fine and is recognized, 4000x and XM Radio both disappear, C90 only sees the PB.
Both the Changer (CDX-848X) and XM radio work perfectly when connected into the system without the PB.
Basically anything that is run inline before AND after the Phatbox is shut down and ignored by the system. Power is cut to all connected units on both sides besides C90 and PB when the PB is plugged in. Bottom line, I didn't learn a thing from any of this and am no further ahead in figuring out what the problem is...lol
Matt, I may just take you up on your offer to test out my PB in your system, but before I go that route I'm going to try a couple more things. I'm going to have the cable modified one last time with a 10k resistor and the reset line cut. Plus I'm going to blow another $100 on a used but factory original PB cable from someone in Europe who is unable to tell me the origin (other than it was made by Phatnoise) or age of the cable so I don't know how recent it has been made (but given my recent luck I'm sure it'll be one of the old cables that were made before the modification was put in place.
I'm just glad I didn't have anything sharp or blunt near me after I finished all these tests, if there had been who knows what the outcome would've been! Ahhhh!
-------------- Original message --------------
> Well, if you're handy with a soldering iron, I would try both the higher
> resistor and the reset line options. Neither will hurt the equipment. Well,
> unless you miss wire something...
> The Phatbox has a bad habit of insisting on being the first CDChanger slave on
> the bus. Each class of accessory you can hook up the the Unilink Bus (UB) has a
> class that it falls into. Here are some Unilink device classes along with some
> examples:
> CD Changer: CD Changers, Phatbox, XA-300
> MD Changer: MD Changers, XM Radio (original Sony box)
> Tuners: TV Tuner, Internal AM/FM Tuner
> Processors: 210, 4000x, internal Bass/Treble
> On system start up, the Head Unit (HU) sends out a broadcast asking for each
> device class on the UB. Each device of the given class will respond with "I'm
> Here" and the HU will respond back to the an "dynamic" address for that
> particular device to use. The address is a combination of the device class
> (high nibble) and the device's assigned address on the UB (low nibble).
> An abbreviated version of this little "dance" occurs each time the HU is powered
> up. If the HU discovers that there is anything different (new or missing
> device) from the last time it started, it will reset the bus (both a protocol
> sequence as well as dropping the Reset wire) and start a whole new bus address
> negotiation.
> The actual address of the device is determined by its location on the bus. The
> closer a device is to the HU the lower its address will be. Basically what
> happens on startup is that the first device on the UB disables bus connectivity
> to all of the slaves down stream until it receives an address from the HU. On
> the XA-C30, logically each respective port looks like a device in the stream, so
> negotiation goes from Port 1 to Port 2 to Port 3.
> The Phatbox for some stupid reason, insists on being address 1 in the CD Changer
> class so you have to be really careful that it is either directly plugged into
> the HU or is on Port 1 of the first XA-C30 in the chain.
> That being said, this addressing limitation shouldn't be conflicting with the
> 4000x in your system since they are different classes of devices, but I wanted
> to point out the caveat with the Phatbox addressing since it took me a while to
> figure that out. I asked Mike Woo at Phatnoise why they hard coded the
> addressing that way, but I didn't really get an answer back. I've written an
> embedded processor Unilink Slave emulator that runs on an 8051-compatible
> microcontroller and I was able to write a negotiation routing that is 100%
> compatible with the master/slave addressing algorithm, so if I can do it, surly
> Phatbox could.
> If you'd like, you can send me your Phatbox and I can give it a try here on my
> two installations to see if the problem is the Phatbox or something else.
> Matt
> At 04:59 AM 4/18/2006 Tuesday, you wrote:
> >I actually do have one a XA-C30, and during my initial installation I tried
> using it with the Phatbox just to see if it had an effect. This last time I did
> not try it with it installed however so I'll give it another try.
> >So you don't think the reset line in your diagram or a higher value resistor
> could be the problem, huh?
> >From: Matt Dralle
> >> Do you have an XA-C30 multiplexer? On both of my installations, I am plugging
> >> the Phatbox into the system using one of these. Basically
> >> C90->4000->C30->Phatbox. I don't know if I've ever tried plugging the Phatbox
> >> directly into a 4000. Seems like I must have tried that at some point, but I
> >> can't remember for sure. You might be able to talk me in to loaning you a
> >> XA-C30 if you promise on your mama's grave to return it...
> >> Matt
> >> At 08:05 PM 4/17/2006 Monday, you wrote:
> >> >What do you know about the reset line being cut in your diagram? This is the
> >> only other difference shown in your diagram that wasn't done in the
> modification
> >> of the cable. Here's what they guy that's been doing the work on the unit for
> >> me wrote after I contacted him the last time about the 4.7k resistor not
> >> working:
> >> >Well its a pulldown resistor so any value of several k or so should do the
> job
> >> 5 vs 10 should not matter but I could be wrong. The other thing was that in
> the
> >> diagram you showed me the reset line seemed to be cut. I didnt do this
> because
> >> lower down it seemed that they fixed that with a firmware update? Im not sure
> >> if that would help but you might want to ask Matt. Does it still work when
> >> directly connected to the head unit?
> >> >Does this sound like something that could cause a problem?
> >> >From: bobbybraun(at)comcast.net
> >> >> Yes, and I even reinstalled the firmware and did a complete system reset
> >> >> afterwards, all to no avail. So frustrating, the C90 knows the Phatbox is
> >> >> there, and can control it just fine, but the 4000x just shuts down
> whenever
> >> it's
> >> >> plugged in. I find it odd that the Phatbox can still be recognized and
> >> >> controlled since it is plugged into the 4000x which is shut down when the
> >> >> Phatbox is plugged in... I just don't know what to do...
> >> >> From: Matt Dralle
> >> >> > Are you running the 7.0 version of the Sony Phatbox firmware?
> >> >> > Matt
> >> >> > At 07:27 PM 4/17/2006 Monday, you wrote:
> >> >> > >Well I had the cable modified with the 4.7k ohm resister installed as
> >> >> suggested
> >> >> > and the problem is still there... as soon as the Phatbox is plugged in
> my
> >> >> 4000x
> >> >> > powers down, the system resets and the C90 only communicates with the
> >> Phatbox.
> >> >> > Still wondering if that resistor should've been 10k ohms instead of 4.7k
> >> since
> >> >> > there seemed to be a conflict of information.
> >> >> > >Anyone out there with a working spare Sony Phatbox cable they're
> willing
> >> to
> >> >> > part with for some cash, or a photo of the bottom of a Sony PB that
> someone
> >> >> > wouldn't mind me using to get myself a cable direct from the factory?
> I'm
> >> >> > running out of options here. Can anybody help?
> >> >> > >From: Matt Dralle
> >> >> > >> Okay, here's some help on this cable issue. Below are two links to
> some
> >> >> > >> information on how the Phatbox-Sony cables are wired. Note that you
> >> *will
> >> >> > need*
> >> >> > >> the 4.7k ohm resistor between ground and the blue wire. Note the
> color
> >> >> coding
> >> >> > >> and what not might be different depending on the version of cable you
> >> have.
> >> >> > The
> >> >> > >> links are for reference only and you might find you need to
> interpolate
> >> a
> >> >> > little
> >> >> > >> with respect to colors and pin numbers and what not:
> >> >> > >> What Matt Found on his cable:
> >> >> > >> http://www.matronics.com/xdp4000x/Unilink-To-Phatbox-Cable-Rev1.pdf
> >> >> > >> What Phatbox Said:
> >> >> > >> http://www.matronics.com/xdp4000x/SonyCable5.pdf
> >> >> > >> Depending on what version of cable you have, things might be a little
> >> >> > different.
> >> >> > >> Use the drawing that matches best your installation.
> >> >> > >> Are you using version 7.0 Sony firmware on your Phatbox? If you are
> >> using
> >> >> > >> anything else, you are going to have operational issues with the
> >> xdp-4000x.
> >> >> > >> Make sure you're using 7.0 Sony firmware (upgradeable through
> >> PhatManager).
> >> >> > >> Matt Dralle
> >> >> > >> For reference, here is a message from Mike Woo at Phatnoise way back
> >> when:
> >> >> > >> "We changed cable manufacturers since Matt purchased his system. The
> >> >> > >> connections are the same but the colors are different. You want to
> >> connect
> >> >> a
> >> >> > >> 10k resistor between the blue (bus master) and orange (ground) wires.
> I
> >> >> have
> >> >> > >> attached a PDF with a detailed description of the connections
> >> >> > (SonyCable5.pdf).
> >> >> > >> The numbers can not be seen on the Sony connector. They can be seen
> on
> >> the
> >> >> > >> PhatBox connector.
> >> >> > >> An unmodified cable should work when directly connected to a head
> unit.
> >> >> > >> Firmware 5.00 and an unmodified cable works with simple multi-device
> >> >> > >> configurations. I'm not sure if firmware 6.00 and an unmodified cable
> >> will
> >> >> > work
> >> >> > >> with any multi-device configurations.
> >> >> > >> The problem is with the bus master signal. It is an input. It is used
> >> for
> >> >> > >> arbitration during device initialization. Without the pull-down the
> >> signal
> >> >> > >> stays high (+5V) at all times. Thus the PhatBox has trouble knowing
> when
> >> is
> >> >> > the
> >> >> > >> right time to initialize itself.
> >> >> > >> After the PhatBox is connected, it will boot and then shutdown. The
> >> PhatBox
> >> >> > >> should then force a reset after a few seconds. However, you should
> >> listen
> >> >> to
> >> >> > >> Matt regarding pushing reset. He would know best about using the C90.
> >> >> > >> Regards,
> >> >> > >> Mike"
> >> >> > >> Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551
> >> >> > >> 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email
> >> >> > >> http://www.matronics.com/ WWW | Featuring Products For Aircraft
> >> >> suggested
> my
> >> >> 4000x
> >> >> > powers down, the system resets and the C90only communicates with the
> >> Phatbox.
> >> since
> willing
> >> to
> someone
> I'm
> >> >> > >From: Matt Dralle dralle(at)matronics.com
> >> >> > > -- XDP4000X-List message posted by: Matt Dralle
> some
> *will
> >> >> > need*
> >> >> > > the 4.7k ohm resistor between ground and the blue wire. Note the color
> >> >> coding
> >> have.
> >> >> > The
> interpolate a
> >> >> > little
> >> >> > > What Phatbox Said:
> >> >> > > http://www.m
> >> >> > > atroni
> >> >> > different.
> using
> >> xdp-4000x.
> >> PhatManager).
> >> >> > > Matt Dralle
> >> when:
> >> connect a
> I
> >> have
> >> >> > (SonyCable5.pdf).
> >> >> > > y conn
> >> >> > >ector. They can be seen on the
> >> >> > > PhatBox connector.
> unit.
> >> will
> >> >> > work
> for
> >> signal
> when
> >> is
> >> >> > the
> >> PhatBox
> listen
> >> to
> >> >> > > Regards,
> >> >> > > Mike"
> >> >> > > BR>>
> >> there,
> >> >> and can control it just fine, but the 4000x just shuts down whenever it's
> >> >> controlled since it is plugged into the 4000x which isshut down when the
> >> Phatbox
> >> >> Matt
> >> >> -- XDP4000X-List message posted by: bobbybraun(at)comcast.net
> >> suggested
> >> >> and the problem is still there... as soon as the Phatbox is plugged in my
> >> 4000x
> >> Phatbox.
> >> since
> >> >> Anyone out there
> >> >> with
> >> >> a working spare Sony Phatbox cable they're willing to
> someone
> >> >> wouldn't mind me using to get myself a cable direct from the factory? I'm
> >> >> From: Matt Dralle
> >> >> Okay, here's some help on this cable issue. Below are two links to some
> >> >> information on how the Phatbox-Sony cables are wired. Note that you *will
> >> >> need*
> coding
> have.
> >> >> The
> >> >> you n
> >> >> eed to interpolate a
> >> >> little
> >> >> different.
> >> >> Are you using version 7.0 Sony firmware on your Phatbox? If you are using
> xdp-4000x.
> PhatManager).
> >> >> Matt Dralle
> >> >> &g
> >> >> t;
> >> >> For reference, here is a message from Mike Woo at Phatnoise way back when:
> >> >> connections are the same but the colors are different. You want to connect
> a
> >> >> 10k resistor between the blue (bus master) and orange (ground) wires. I
> have
> >> >> (SonyCable5.pdf).
> >> >> The numbers can not be seen on the Sony connector. They can be seen on the
> >> >> PhatBox connector.
> >> >> An unmodified cable should work when directly connected to a head unit.
> >> >> configurations. I'm not sure if firmware 6.00 and an unmodified cable will
> >> >> work
> >> >> igurat
> >> >> ions.
> >> >> The problem is with the bus master signal. It is an input. It is used for
> >> >> arbitration during device initialization. Without the pull-down the signal
> >> >> stays high (+5V) at all times. Thus the PhatBox has trouble knowing when
> is
> >> >> the
> PhatBox
> >> >> should then force a reset after a few seconds. However, you should listen
> to
> >> >> Regards,
> >> >> Mike"
> >> >> gt; http://www.matronics.com/ WWW | Featuring Products For Aircraft
> >> suggested
> >> 4000x
> Phatbox.
> >> since
> >> >> Anyone out there with a working spare Sony Phatbox cable they're willing
> to
> someone
> >> >> From: Matt
> >> >> Drall
> >> >> need*
> coding
> have.
> >> >> The
> >> >> links are for reference only and you might find you need to interpolate a
> >> >> little
> >> >> What Phatbox Said:
> >> >> http://www.m
> >> >> atroni
> >> >> cs.com/xdp
> >> >> 4000x/
> >> >> SonyCable5.pdf
> >> >> different.
> xdp-4000x.
> PhatManager).
> >> >> Matt Dralle
> a
> have
> >> >> ons > R> (SonyCable5.pdf).
> >> >> y conn
> >> >> PhatBox connector.
> >> >> work
> is
> >> >> the
> PhatBox
> >> >> sho
> >> >> uld th
> >> >> en force a reset after a few seconds. However, you should listen to
> >> >> Regards,
> >> >> Mike"
> >> >> BR
> >> >> &g
> >> >> t;
> >> only other difference shown in your diagramthat wasn't done in
> themodification
> me
> working:
> job
> the
> because
> if
> directly
> >> > there, and can control it just fine, but the 4000x just shuts down whenever
> >> it's
> >> > From: Matt Dralle
> >> > he Son
> >> >y Phatbox firmware?
> >> > Matt
> >> > suggested
> >> > 4000x
> >> Phatbox.
> >> since
> >> > Anyone out there with a working spare Sony Phatbox cable they're willing to
> >> > part with for some cash, or a photo of the bottom of a Sony PB that someone
> >> > From: Matt Dralle
> >> > need*
> >> > coding
> >> > and what not might be different depending on the version of cable you have.
> >> > The
> >> > little
> >> > Wha
> >> > t Matt
> >> > Found on his cable:
> >> > different.
> >> > anything else, you are going to have operational issues with the xdp-4000x.
> >> > Make sure you're using 7.0 Sony firmware (upgradeable through PhatManager).
> >> > Matt Dralle
> >> > from M
> >> > a
> >> > have
> >> > (SonyCable5.pdf).
> >> > PhatBox connector.
> >> > work
> >> > &g
> >> >t; with any multi-device configurations.
> >> > stays high (+5V) at all times. Thus the PhatBox has trouble knowing when is
> >> > the
> >> > After the PhatBox is connected, it will boot and then shutdown. The PhatBox
> >> > to
> >> > Regards,
> >> > Mike"
> >> > Matt G Drall
> >> > e | Ma
> >> > suggested
> >> > 4000x
> Phatbox.
> >> since
> >> >gt; wouldn't mind me using to get myself a cable direct from the factory?
> I'm
> >> > need*
> >> > coding
> >> > The
> >> > little
> >> > numbe
> >> >rs and what not:
> >> > What Phatbox Said:
> >> > http://www.m
> >> > atroni
> >> > different.
> >> > Matt Dralle
> >> > Fo
> >> > r refe
> a
> have
> >> > (SonyCable5.pdf).
> >> > y conn
> >> > PhatBox connector.
> >> > work
> >> > gt; &g
> >> > the
> to
> >> > Regards,
> >> > Mike"
> >> > BR
> >> > 94551
> >> there,
> >> > pl
> >> > ugged
> >> Phatbox
> >> > Matt
> >> suggested
> >> 4000x
> Phatbox.
> >> > s inst
> >> >ead of 4.7k since
> >> > Anyone out there
> >> > with
> >> > From: Matt Dralle
> >> > need*
> coding
> >> > The
> >> > links are
> >> > for re
> >> > you n
> >> > little
> >> > different.
> >> > Matt Dralle
> >> > g
> >> > t;
> >> > gt; > >R> "We changed cable manufacturers since Matt purchased his system.
> The
> a
> have
> >> > (SonyCable5.pdf).
> >> > PhatBox connector.
> >> > work
> >> > igurat
> >> > ions.
> >> > stays
> >> > high
> >> > the
> to
> >> > Regards,
> >> > Mike"
> >> suggested
> >> 4000x
> >> > ommuni
> >> >cates with the Phatbox.
> since
> >> > From: Matt
> >> > Drall
> >> > need*
> coding
> >> > BR>>
> >> >; and what not might be different depending on the version of cable you
> have.
> >> > The
> >> > little
> >> > What Phatbox Said:
> >> > http://www.m
> >> > atroni
> >> > cs.com/xdp
> >> > 4000x/
> >> > SonyCable5.pdf
> >> > different.
> >> > Matt Drall
> >> > e
> a
> have
> >> > ons > > R (SonyCable5.pdf).
> >> > y conn
> >> > PhatBox connector.
> >> > work
> >> > t is a
> >> > the
> >> > sho
> >> > uld th
> >> > Regards,
> >> > Mike"
> >> > BR
> >> > g
> >> > t;
> >> > matron
> >> >ics.com/xdp4000x-list/download
| | - The Matronics XDP4000X-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?XDP4000X-List |
_________________ Matt Dralle
bobbybraun(at)comcast.net Guest
Posted: Tue Apr 18, 2006 7:14 pm Post subject: Phatnoise Connection Problem - Help?! |
Ok, I went ahead and clipped the reset wire and now the PB actually works in my system without shutting everything off! BUT... and this is a big but, my processor is not accepting analog audio at the analog changer input any longer (and it used to just fine)... I did test and there is audio at the outputs of the PB, but it doesn't sound right at all, tinny and flat, no bass, dull highs.
I threw my cd changer back in to see if my processor would accept analog audio from that and the analog outputs of that piece are not working any longer either... (I can't say for 100% that they worked before hand since I always used the digital output of the changer, and never tested the analog outputs)
I have yet to try my XM unit, which I know the analog outs used to work on since those are the only outputs it has and I used it for about 6 months in my system, but that will have to wait till daylight tomorrow since it's late and I don't have the time to wire anything else in tonight.
So I guess the good news is, the PB works now, well sorta. I'm partially convinced that something is wrong with it's audio outputs because like I said before it sounds really bad, and now I'm worried that something is broken inside of my processor as well, but no need to jump to conclusions until I can check everything out properly tomorrow. At least I made some progress...
Matt
is...lol
Ahhhh!
>From: Matt Dralle
on
a
some
>> examples:
powered
address
>> negotiation.
The
connectivity
so
Changer
into
wanted
to
surly
>> Phatbox could.
my
>> Matt
did
>> >From: Matt Dralle
plugging
Phatbox
I
>> >> Matt
the
>> modification
for
>> >> working:
the
>> job
in
>> the
>> because
sure
reset
is
>> whenever
>> >> it's
the
>> >> >> From: Matt Dralle
>> >> >> > Matt
as
>> >> >> suggested
in
>> my
>> >> >> 4000x
>> >> Phatbox.
4.7k
>> >> since
>> willing
>> >> to
>> someone
>> I'm
>> >> >> > >From: Matt Dralle
>> some
you
>> >> *will
>> >> >> > need*
>> color
>> >> >> coding
you
>> >> have.
>> >> >> > The
>> interpolate
>> >> a
>> >> >> > little
little
>> >> >> > different.
are
>> >> using
>> >> xdp-4000x.
>> >> PhatManager).
>> >> >> > >> Matt Dralle
back
>> >> when:
The
>> >> connect
>> >> >> a
wires.
>> I
>> >> >> have
>> >> >> > (SonyCable5.pdf).
seen
>> on
>> >> the
>> >> >> > >> PhatBox connector.
>> unit.
multi-device
cable
>> >> will
>> >> >> > work
used
>> >> for
the
>> >> signal
knowing
>> when
>> >> is
>> >> >> > the
The
>> >> PhatBox
>> >> listen
>> >> >> to
C90.
>> >> >> > >> Regards,
>> >> >> > >> Mike"
as
>> >> >> suggested
in
>> my
>> >> >> 4000x
>> >> Phatbox.
4.7k
>> >> since
>> willing
>> >> to
>> someone
>> I'm
>> some
>> *will
>> >> >> > need*
color
>> >> >> coding
you
>> >> have.
>> >> >> > The
>> interpolate a
>> >> >> > little
>> >> >> > > What Phatbox Said:
>> >> >> > > http://www.m
>> >> >> > > atroni
little
>> >> >> > different.
>> using
>> >> xdp-4000x.
>> >> PhatManager).
>> >> >> > > Matt Dralle
back
>> >> when:
The
>> >> connect a
wires.
>> I
>> >> have
>> >> >> > (SonyCable5.pdf).
>> >> >> > > y conn
>> >> >> > > PhatBox connector.
>> unit.
multi-device
cable
>> >> will
>> >> >> > work
used
>> for
>> >> signal
>> when
>> >> is
>> >> >> > the
>> >> PhatBox
>> listen
>> >> to
C90.
>> >> >> > > Regards,
>> >> >> > > Mike"
>> >> >> > > BR>>
reset
is
>> >> there,
it's
the
>> >> Phatbox
>> >> >> Matt
>> >> suggested
my
>> >> 4000x
>> >> Phatbox.
4.7k
>> >> since
>> >> >> Anyone out there
>> >> >> with
>> someone
I'm
>> >> >> From: Matt Dralle
*will
>> >> >> need*
>> coding
>> have.
>> >> >> The
>> >> >> you n
>> >> >> little
>> >> >> different.
using
>> xdp-4000x.
>> PhatManager).
>> >> >> Matt Dralle
>> >> >> &g
>> >> >> t;
when:
connect
>> a
>> have
>> >> >> (SonyCable5.pdf).
the
>> >> >> PhatBox connector.
will
>> >> >> work
>> >> >> igurat
>> >> >> ions.
for
signal
when
>> is
>> >> >> the
>> PhatBox
listen
>> to
>> >> >> Regards,
>> >> >> Mike"
>> >> suggested
my
>> >> 4000x
>> Phatbox.
4.7k
>> >> since
willing
>> to
>> someone
I'm
>> >> >> From: Matt
>> >> >> Drall
*will
>> >> >> need*
>> coding
>> have.
>> >> >> The
a
>> >> >> little
>> >> >> What Phatbox Said:
>> >> >> http://www.m
>> >> >> atroni
>> >> >> cs.com/xdp
>> >> >> 4000x/
>> >> >> SonyCable5.pdf
>> >> >> different.
using
>> xdp-4000x.
>> PhatManager).
>> >> >> Matt Dralle
when:
connect
>> a
>> have
>> >> >> y conn
>> >> >> PhatBox connector.
will
>> >> >> work
for
signal
when
>> is
>> >> >> the
>> PhatBox
>> >> >> sho
>> >> >> uld th
>> >> >> Regards,
>> >> >> Mike"
>> >> >> BR
>> >> >> &g
>> >> >> t;
the
>> themodification
for
>> me
>> working:
the
>> job
in
>> the
>> because
sure
>> if
>> directly
is
whenever
>> >> it's
the
>> >> > From: Matt Dralle
>> >> > he Son
>> >> >y Phatbox firmware?
>> >> > Matt
>> >> > suggested
my
>> >> > 4000x
>> >> Phatbox.
>> >> since
to
someone
I'm
>> >> > From: Matt Dralle
*will
>> >> > need*
>> >> > coding
have.
>> >> > The
a
>> >> > little
>> >> > Wha
>> >> > t Matt
>> >> > Found on his cable:
>> >> > different.
using
xdp-4000x.
PhatManager).
>> >> > Matt Dralle
>> >> > from M
connect
>> >> > a
>> >> > have
>> >> > (SonyCable5.pdf).
the
>> >> > PhatBox connector.
will
>> >> > work
>> >> > &g
for
signal
is
>> >> > the
PhatBox
listen
>> >> > to
>> >> > Regards,
>> >> > Mike"
>> >> > Matt G Drall
>> >> > e | Ma
>> >> > suggested
my
>> >> > 4000x
>> Phatbox.
>> >> since
to
someone
>> I'm
*will
>> >> > need*
>> >> > coding
have.
>> >> > The
a
>> >> > little
>> >> > numbe
>> >> >rs and what not:
>> >> > What Phatbox Said:
>> >> > http://www.m
>> >> > atroni
>> >> > different.
using
xdp-4000x.
PhatManager).
>> >> > Matt Dralle
>> >> > Fo
>> >> > r refe
connect
>> a
>> have
>> >> > (SonyCable5.pdf).
>> >> > y conn
>> >> > PhatBox connector.
will
>> >> > work
>> >> > gt; &g
for
signal
is
>> >> > the
PhatBox
listen
>> to
>> >> > Regards,
>> >> > Mike"
>> >> > BR
>> >> > 94551
is
>> >> there,
it's
>> >> > pl
>> >> > ugged
>> >> Phatbox
>> >> > Matt
>> >> suggested
my
>> >> 4000x
>> Phatbox.
>> >> > s inst
>> >> >ead of 4.7k since
>> >> > Anyone out there
>> >> > with
someone
I'm
>> >> > From: Matt Dralle
*will
>> >> > need*
>> coding
have.
>> >> > The
>> >> > links are
>> >> > for re
>> >> > you n
>> >> > little
>> >> > different.
using
xdp-4000x.
PhatManager).
>> >> > Matt Dralle
>> >> > g
>> >> > t;
when:
system.
>> The
connect
>> a
>> have
>> >> > (SonyCable5.pdf).
the
>> >> > PhatBox connector.
will
>> >> > work
>> >> > igurat
>> >> > ions.
for
signal
>> >> > stays
>> >> > high
>> >> > the
PhatBox
listen
>> to
>> >> > Regards,
>> >> > Mike"
Posted: Tue Apr 18, 2006 7:22 pm Post subject: Phatnoise Connection Problem - Help?! |
Great news!
Couple of things come to mind with respect to your new audio woes. Digital vs Analog input on the 4000x is only negotiated on reset (button on C90), so with all the plugging around, make sure that you set things up like you want, then press that reset button.
Second, the "tinny" sound might be because you've selected an unprogrammed EQ/Xover setting on the 4000x. The default setting has some of the Xover settings off or highly attenuated.
Plug your PC back into the 4000x and double check all of your EQ and XO memory locations, and then make sure you select the right ones on the HU.
Almost there!
Matt
At 08:13 PM 4/18/2006 Tuesday, you wrote:
> Matt
> is...lol
> Ahhhh!
> >From: Matt Dralle
> on
> a
> some
> >> examples:
> powered
> address
> >> negotiation.
> The
> connectivity
> so
> Changer
> into
> wanted
> to
> surly
> >> Phatbox could.
> my
> >> Matt
> did
> >> >From: Matt Dralle
> plugging
> Phatbox
> I
> >> >> Matt
> the
> >> modification
> for
> >> >> working:
> the
> >> job
> in
> >> the
> >> because
> sure
> reset
> is
> >> whenever
> >> >> it's
> the
> >> >> >> From: Matt Dralle
> >> >> >> > Matt
> as
> >> >> >> suggested
> in
> >> my
> >> >> >> 4000x
> >> >> Phatbox.
> 4.7k
> >> >> since
> >> willing
> >> >> to
> >> someone
> >> I'm
> >> >> >> > >From: Matt Dralle
> >> some
> you
> >> >> *will
> >> >> >> > need*
> >> color
> >> >> >> coding
> you
> >> >> have.
> >> >> >> > The
> >> interpolate
> >> >> a
> >> >> >> > little
> little
> >> >> >> > different.
> are
> >> >> using
> >> >> xdp-4000x.
> >> >> PhatManager).
> >> >> >> > >> Matt Dralle
> back
> >> >> when:
> The
> >> >> connect
> >> >> >> a
> wires.
> >> I
> >> >> >> have
> >> >> >> > (SonyCable5.pdf).
> seen
> >> on
> >> >> the
> >> >> >> > >> PhatBox connector.
> >> unit.
> multi-device
> cable
> >> >> will
> >> >> >> > work
> used
> >> >> for
> the
> >> >> signal
> knowing
> >> when
> >> >> is
> >> >> >> > the
> The
> >> >> PhatBox
> >> >> listen
> >> >> >> to
> C90.
> >> >> >> > >> Regards,
> >> >> >> > >> Mike"
> as
> >> >> >> suggested
> in
> >> my
> >> >> >> 4000x
> >> >> Phatbox.
> 4.7k
> >> >> since
> >> willing
> >> >> to
> >> someone
> >> I'm
> >> some
> >> *will
> >> >> >> > need*
> color
> >> >> >> coding
> you
> >> >> have.
> >> >> >> > The
> >> interpolate a
> >> >> >> > little
> >> >> >> > > What Phatbox Said:
> >> >> >> > > http://www.m
> >> >> >> > > atroni
> little
> >> >> >> > different.
> >> using
> >> >> xdp-4000x.
> >> >> PhatManager).
> >> >> >> > > Matt Dralle
> back
> >> >> when:
> The
> >> >> connect a
> wires.
> >> I
> >> >> have
> >> >> >> > (SonyCable5.pdf).
> >> >> >> > > y conn
> >> >> >> > > PhatBox connector.
> >> unit.
> multi-device
> cable
> >> >> will
> >> >> >> > work
> used
> >> for
> >> >> signal
> >> when
> >> >> is
> >> >> >> > the
> >> >> PhatBox
> >> listen
> >> >> to
> C90.
> >> >> >> > > Regards,
> >> >> >> > > Mike"
> >> >> >> > > BR>>
> reset
> is
> >> >> there,
> it's
> the
> >> >> Phatbox
> >> >> >> Matt
> >> >> suggested
> my
> >> >> 4000x
> >> >> Phatbox.
> 4.7k
> >> >> since
> >> >> >> Anyone out there
> >> >> >> with
> >> someone
> I'm
> >> >> >> From: Matt Dralle
> *will
> >> >> >> need*
> >> coding
> >> have.
> >> >> >> The
> >> >> >> you n
> >> >> >> little
> >> >> >> different.
> using
> >> xdp-4000x.
> >> PhatManager).
> >> >> >> Matt Dralle
> >> >> >> &g
> >> >> >> t;
> when:
> connect
> >> a
> >> have
> >> >> >> (SonyCable5.pdf).
> the
> >> >> >> PhatBox connector.
> will
> >> >> >> work
> >> >> >> igurat
> >> >> >> ions.
> for
> signal
> when
> >> is
> >> >> >> the
> >> PhatBox
> listen
> >> to
> >> >> >> Regards,
> >> >> >> Mike"
> >> >> suggested
> my
> >> >> 4000x
> >> Phatbox.
> 4.7k
> >> >> since
> willing
> >> to
> >> someone
> I'm
> >> >> >> From: Matt
> >> >> >> Drall
> *will
> >> >> >> need*
> >> coding
> >> have.
> >> >> >> The
> a
> >> >> >> little
> >> >> >> What Phatbox Said:
> >> >> >> http://www.m
> >> >> >> atroni
> >> >> >> cs.com/xdp
> >> >> >> 4000x/
> >> >> >> SonyCable5.pdf
> >> >> >> different.
> using
> >> xdp-4000x.
> >> PhatManager).
> >> >> >> Matt Dralle
> when:
> connect
> >> a
> >> have
> >> >> >> y conn
> >> >> >> PhatBox connector.
> will
> >> >> >> work
> for
> signal
> when
> >> is
> >> >> >> the
> >> PhatBox
> >> >> >> sho
> >> >> >> uld th
> >> >> >> Regards,
> >> >> >> Mike"
> >> >> >> BR
> >> >> >> &g
> >> >> >> t;
> the
> >> themodification
> for
> >> me
> >> working:
> the
> >> job
> in
> >> the
> >> because
> sure
> >> if
> >> directly
> is
> whenever
> >> >> it's
> the
> >> >> > From: Matt Dralle
> >> >> > he Son
> >> >> >y Phatbox firmware?
> >> >> > Matt
> >> >> > suggested
> my
> >> >> > 4000x
> >> >> Phatbox.
> >> >> since
> to
> someone
> I'm
> >> >> > From: Matt Dralle
> *will
> >> >> > need*
> >> >> > coding
> have.
> >> >> > The
> a
> >> >> > little
> >> >> > Wha
> >> >> > t Matt
> >> >> > Found on his cable:
> >> >> > different.
> using
> xdp-4000x.
> PhatManager).
> >> >> > Matt Dralle
> >> >> > from M
> connect
> >> >> > a
> >> >> > have
> >> >> > (SonyCable5.pdf).
> the
> >> >> > PhatBox connector.
> will
> >> >> > work
> >> >> > &g
> for
> signal
> is
> >> >> > the
> PhatBox
> listen
> >> >> > to
> >> >> > Regards,
> >> >> > Mike"
> >> >> > Matt G Drall
> >> >> > e | Ma
> >> >> > suggested
> my
> >> >> > 4000x
> >> Phatbox.
> >> >> since
> to
> someone
> >> I'm
> *will
> >> >> > need*
> >> >> > coding
> have.
> >> >> > The
> a
> >> >> > little
> >> >> > numbe
> >> >> >rs and what not:
> >> >> > What Phatbox Said:
> >> >> > http://www.m
> >> >> > atroni
> >> >> > different.
> using
> xdp-4000x.
> PhatManager).
> >> >> > Matt Dralle
> >> >> > Fo
> >> >> > r refe
> connect
> >> a
> >> have
> >> >> > (SonyCable5.pdf).
> >> >> > y conn
> >> >> > PhatBox connector.
> will
> >> >> > work
> >> >> > gt; &g
> for
> signal
> is
> >> >> > the
> PhatBox
> listen
> >> to
> >> >> > Regards,
> >> >> > Mike"
> >> >> > BR
> >> >> > 94551
> is
> >> >> there,
> it's
> >> >> > pl
> >> >> > ugged
> >> >> Phatbox
> >> >> > Matt
> >> >> suggested
> my
> >> >> 4000x
> >> Phatbox.
> >> >> > s inst
> >> >> >ead of 4.7k since
> >> >> > there seemed to b
Posted: Tue Apr 18, 2006 7:35 pm Post subject: Phatnoise Connection Problem - Help?! |
Yes, I've thought about all that already, but here is the thing, I can't get any audio to be recognized by the 4000x through it's Analog Changer Inputs. The only reason I know it sounds bad is because I hooked a set of headphones up to the phatbox to test if any audio was present and when I listened it sounded horrible, (if not mono). I listened to the same exact mp3 file that was being played on the PB back inside on my computer through the same headset using the crappy non 24bit burr brown outputs of my laptop and it sounded 1000x more full and realistic, so that worries me. And the fact that I can't get any audio to play back when plugged into the analog changer inputs worries me even more, I really hope this thing didn't somehow damage my 4000x, there is no way I want to send it off to Sony and let them hack away at it like they did with my last C90 I sent them...
I have done a full reset from the C90 and still nothing. I'll test out my other equipment that I know was working beforehand tomorrow and then I'll know more, but that still doesn't change the issue with the terrible sound output of the PB.
Great news!
Almost there!
Matt
>From: Matt Dralle
line
>> Matt
short
it
PB
PB.
disappear,
the
down
problem
>> is...lol
to
it
that
>> Ahhhh!
>> >From: Matt Dralle
Well,
slave
>> on
has
>> a
>> some
>> >> examples:
each
"I'm
>> powered
protocol
>> address
>> >> negotiation.
>> The
>> connectivity
On
stream,
>> so
>> Changer
>> into
the
>> wanted
while
>> to
an
>> surly
>> >> Phatbox could.
on
>> my
>> >> Matt
tried
I
>> did
resistor
>> >> >From: Matt Dralle
>> plugging
>> Phatbox
but
>> I
a
>> >> >> Matt
is
>> the
>> >> modification
unit
>> for
not
>> >> >> working:
>> the
>> >> job
that
>> in
>> >> the
>> >> because
not
>> sure
when
>> reset
Phatbox
>> is
>> >> whenever
>> >> >> it's
and
when
>> the
>> >> >> >> From: Matt Dralle
>> >> >> >> > Matt
installed
>> as
>> >> >> >> suggested
plugged
>> in
>> >> my
>> >> >> >> 4000x
the
>> >> >> Phatbox.
of
>> 4.7k
>> >> >> since
>> >> willing
>> >> >> to
that
>> >> someone
factory?
>> >> I'm
>> >> >> >> > >From: Matt Dralle
to
>> >> some
>> you
>> >> >> *will
>> >> >> >> > need*
the
>> >> color
>> >> >> >> coding
cable
>> you
>> >> >> have.
>> >> >> >> > The
>> >> interpolate
>> >> >> a
>> >> >> >> > little
>> little
>> >> >> >> > different.
>> are
>> >> >> using
the
>> >> >> xdp-4000x.
>> >> >> PhatManager).
>> >> >> >> > >> Matt Dralle
>> back
>> >> >> when:
system.
>> The
to
>> >> >> connect
>> >> >> >> a
>> wires.
>> >> I
>> >> >> >> have
>> >> >> >> > (SonyCable5.pdf).
>> seen
>> >> on
>> >> >> the
>> >> >> >> > >> PhatBox connector.
head
>> >> unit.
>> multi-device
>> cable
>> >> >> will
>> >> >> >> > work
is
>> used
>> >> >> for
>> the
>> >> >> signal
>> knowing
>> >> when
>> >> >> is
>> >> >> >> > the
>> The
>> >> >> PhatBox
should
>> >> >> listen
>> >> >> >> to
the
>> C90.
>> >> >> >> > >> Regards,
>> >> >> >> > >> Mike"
installed
>> as
>> >> >> >> suggested
plugged
>> in
>> >> my
>> >> >> >> 4000x
the
>> >> >> Phatbox.
of
>> 4.7k
>> >> >> since
>> >> willing
>> >> >> to
that
>> >> someone
factory?
>> >> I'm
to
>> >> some
you
>> >> *will
>> >> >> >> > need*
>> color
>> >> >> >> coding
cable
>> you
>> >> >> have.
>> >> >> >> > The
>> >> interpolate a
>> >> >> >> > little
>> >> >> >> > > What Phatbox Said:
>> >> >> >> > > http://www.m
>> >> >> >> > > atroni
>> little
>> >> >> >> > different.
are
>> >> using
>> >> >> xdp-4000x.
>> >> >> PhatManager).
>> >> >> >> > > Matt Dralle
>> back
>> >> >> when:
>> The
to
>> >> >> connect a
>> wires.
>> >> I
>> >> >> have
>> >> >> >> > (SonyCable5.pdf).
>> >> >> >> > > y conn
>> >> >> >> > > PhatBox connector.
head
>> >> unit.
>> multi-device
>> cable
>> >> >> will
>> >> >> >> > work
>> used
>> >> for
the
>> >> >> signal
knowing
>> >> when
>> >> >> is
>> >> >> >> > the
The
>> >> >> PhatBox
should
>> >> listen
>> >> >> to
>> C90.
>> >> >> >> > > Regards,
>> >> >> >> > > Mike"
>> >> >> >> > > BR>>
>> reset
Phatbox
>> is
>> >> >> there,
>> it's
and
>> the
>> >> >> Phatbox
>> >> >> >> Matt
as
>> >> >> suggested
in
>> my
>> >> >> 4000x
the
>> >> >> Phatbox.
>> 4.7k
>> >> >> since
>> >> >> >> Anyone out there
>> >> >> >> with
>> >> someone
factory?
>> I'm
>> >> >> >> From: Matt Dralle
some
>> *will
>> >> >> >> need*
color
>> >> coding
you
>> >> have.
>> >> >> >> The
>> >> >> >> you n
>> >> >> >> little
little
>> >> >> >> different.
>> using
>> >> xdp-4000x.
>> >> PhatManager).
>> >> >> >> Matt Dralle
>> >> >> >> &g
>> >> >> >> t;
>> when:
>> connect
>> >> a
wires. I
>> >> have
>> >> >> >> (SonyCable5.pdf).
on
>> the
>> >> >> >> PhatBox connector.
unit.
cable
>> will
>> >> >> >> work
>> >> >> >> igurat
>> >> >> >> ions.
used
>> for
>> signal
>> when
>> >> is
>> >> >> >> the
>> >> PhatBox
>> listen
>> >> to
C90.
>> >> >> >> Regards,
>> >> >> >> Mike"
as
>> >> >> suggested
in
>> my
>> >> >> 4000x
>> >> Phatbox.
>> 4.7k
>> >> >> since
>> willing
>> >> to
>> >> someone
factory?
>> I'm
>> >> >> >> From: Matt
>> >> >> >> Drall
some
>> *will
>> >> >> >> need*
color
>> >> coding
you
>> >> have.
>> >> >> >> The
interpolate
>> a
>> >> >> >> little
>> >> >> >> What Phatbox Said:
>> >> >> >> http://www.m
>> >> >> >> atroni
>> >> >> >> cs.com/xdp
>> >> >> >> 4000x/
>> >> >> >> SonyCable5.pdf
little
>> >> >> >> different.
>> using
>> >> xdp-4000x.
>> >> PhatManager).
>> >> >> >> Matt Dralle
>> when:
>> connect
>> >> a
wires. I
>> >> have
>> >> >> >> y conn
>> >> >> >> PhatBox connector.
unit.
cable
>> will
>> >> >> >> work
used
>> for
>> signal
>> when
>> >> is
>> >> >> >> the
>> >> PhatBox
>> >> >> >> sho
>> >> >> >> uld th
C90.
>> >> >> >> Regards,
>> >> >> >> Mike"
>> >> >> >> BR
>> >> >> >> &g
>> >> >> >> t;
is
>> the
>> >> themodification
unit
>> for
>> >> me
>> >> working:
>> the
>> >> job
that
>> in
>> >> the
>> >> because
not
>> sure
>> >> if
>> >> directly
reset
Phatbox
>> is
>> whenever
>> >> >> it's
and
>> the
>> >> >> > From: Matt Dralle
>> >> >> > he Son
>> >> >> >y Phatbox firmware?
>> >> >> > Matt
>> >> >> > suggested
in
>> my
>> >> >> > 4000x
>> >> >> Phatbox.
4.7k
>> >> >> since
willing
>> to
>> someone
>> I'm
>> >> >> > From: Matt Dralle
some
>> *will
>> >> >> > need*
color
>> >> >> > coding
>> have.
>> >> >> > The
interpolate
>> a
>> >> >> > little
>> >> >> > Wha
>> >> >> > t Matt
>> >> >> > Found on his cable:
>> >> >> > different.
>> using
>> xdp-4000x.
>> PhatManager).
>> >> >> > Matt Dralle
>> >> >> > from M
>> connect
>> >> >> > a
I
>> >> >> > have
>> >> >> > (SonyCable5.pdf).
on
>> the
>> >> >> > PhatBox connector.
unit.
>> will
>> >> >> > work
>> >> >> > &g
>> for
>> signal
when
>> is
>> >> >> > the
>> PhatBox
>> listen
>> >> >> > to
>> >> >> > Regards,
>> >> >> > Mike"
>> >> >> > Matt G Drall
>> >> >> > e | Ma
>> >> >> > suggested
in
>> my
>> >> >> > 4000x
>> >> Phatbox.
4.7k
>> >> >> since
willing
>> to
>> someone
factory?
>> >> I'm
some
>> *will
>> >> >> > need*
color
>> >> >> > coding
>> have.
>> >> >> > The
interpolate
>> a
>> >> >> > little
>> >> >> > numbe
>> >> >> >rs and what not:
Posted: Wed Apr 19, 2006 7:46 pm Post subject: Phatnoise Connection Problem - Help?! |
At 02:50 PM 4/19/2006 Wednesday, you wrote:
Well, it seems as if I maybe spoke too soon. My 4000x stops accepting audio from the PB as soon as the source is changed (i.e. whenever the Tuner or in dash CD is selected). As soon as I go back to the PB as a source, it comes up but analog audio will not be played back again unless a different source is plugged into the Changer Input of the 4000x. I guess I'm going to have to try installing my XA-C30 after all, and see if this fixes the problem... And the frustration quickly returns. Grrr!
Well, that's a bummer... For the record, on my installation I am using the C30's to switch the Unilink, but I've connected the Phatbox directly up to the Changer Analog inputs on the 4000x.
While this might not be related to your problem, I found that there is a huge problem with grounding loops between the PB and the 4000x/C90. I had hard mounted everything floor pan of my 1998 Chevy truck, and found that the squeal from the alternator unbearable. Finally, I mounted the PB to my backbone behind the rear seat (wood) with short screws so that it was isolated from the truck's chassis and the alternator wine went completely away. FYI.
Also, I found that the PB seems really sensitive to line level cable load especially when connected to the 4000x. Possibly because the 4000x has 4 volt line level inputs and the PB doesn't? Don't know about that for sure. In any case, I used super short (1 meter) top of the line Monster line level cables between the PB and the 4k and have had good success. There is still a slight attenuation on the bass from the PB, but its not bad. This is detected by playing a song from a CD using the Optic output CD Changer into the Optic input on the 4x vs. playing the same song through the PB to the 4k using the Analog inputs. There is definitely bass roll off with the PB.
Matt
