Tachometer Generator Wiring
Goto page Previous  1, 2
PostPosted: Thu Sep 29, 2011 6:46 pm    Post subject: Tachometer Generator Wiring Reply with quote
At 11:01 AM 9/29/2011, you wrote:
To Bob and All,
At my age, I know it is only a matter of time before I forget to
latch the canopy before takeoff on a hot sunny day.My plan is to use
a PIC12F509 microprocessor that will monitor the limit switch and
also count the engine RPM.
Is this a Dynon sensor? Call the factory and see
what the characteristics of this signal are. It
may already be a 5 or 12v square wave. If so,
you can tie it to a PIC input through a suitable
series resistor, a capacitor and perhaps a clamp diode.
Use one of edge sensitive inputs. But the first
question to answer is what does the signal look
like? If you can run the engine now, the a 'scope
would get you this information too.
I have a little "do everything" board and enclosure
that might be suited to your task. See:
http://aeroelectric.com/Pictures/Schematics/Do-Much_Board.pdf
http://www.aeroelectric.com/Catalog/AEC/9011/A15_Package.jpg
Depending on what parts are installed on the board, what
parts are left off, and what code goes into the
8-pin PIC, you can do a whole lot of neat things.
mrspudandcompany(at)veriz
PostPosted: Fri Sep 30, 2011 3:55 am    Post subject: Tachometer Generator Wiring Reply with quote
I noticed that this was just posted yesterday on your
website. Is there any documentation available? What things do you
anticipate it to be used for?
Roger
winmail.dat
 Filename:  winmail.dat
 Filesize:  3.6 KB
 Downloaded:  444 Time(s)
PostPosted: Fri Sep 30, 2011 6:10 am    Post subject: Tachometer Generator Wiring Reply with quote
It's the core board for about a dozen different
products with the notion of having 90% common bill
of materials and differing only by what software
is installed. AEC9011 is but one example.
Roger
PostPosted: Fri Sep 30, 2011 8:35 am    Post subject: Re: Tachometer Generator Wiring Reply with quote
Thanks for the response Bob N.
This is an RV-12. The RPM sensor is part of the Rotax 912 engine. The tach trigger coil sends a small AC voltage signal to the tach once every revolution of the crankshaft, according to page 8 of this document: http://flymall.org/aircraft/docs/FAQs-on-Rotax.pdf
I do not have a portable scope. But my Fluke meter shows an AC voltage.
Does your "do everything" board come with ASM code for the various functions or do we have to write our own?
Thanks, Joe
Joe Gores
PostPosted: Sat Oct 01, 2011 9:16 pm    Post subject: Tachometer Generator Wiring Reply with quote
Hmmmm . . . once per revolution makes for a challenging
tachometer design. We still need to know if the transducer
is a hall effect device or a inductive pickup. In any case,
the output is a very low duty cycle pulse. At 5500 cruise
you'll have 91 Hz tach signals the drop to about 1/5th that
for idle or 18 Hz. It would be very helpful to know the
style of transducer along with the amplitude and duration
of output pulse.
You gotta do your own code and your own components
selection tailored to the task. Not all components
shown in the schematic are installed together for
a single project. But with the layout shown, values
of parts put in and parts left off offer a huge combination
of options for inputs, outputs and tasks.
(o o)
===========o00o=(_)=o00o=========
< Go ahead, make my day . . . >
< show me where I'm wrong. >
Page 2 of 2
