Tom Jones
Joined: 12 Mar 2006 Posts: 752 Location: Ellensburg, WA
Posted: Mon Feb 09, 2009 6:19 pm Post subject: Re: Problem with FLUTTER ? ! ? ! |
| Quote: | I just never
heard of this device called a spherical "bolt"...which, of course, it
is not...a "bolt" that is. |
Lynn, you have to of been around helicopters to get the lingo.
_________________ Tom Jones
Classic IV
Ellensburg, WA |
Lynn Matteson
Posted: Mon Feb 09, 2009 7:00 pm Post subject: Problem with FLUTTER ? ! ? ! |
That must be it....around 'copters, I'm clueless.
Lynn Matteson
Jabiru 2200, #2062, 605 hrs
Sensenich 62x46
New skis done and flying
On Feb 9, 2009, at 9:19 PM, Tom Jones wrote:
> I just never
Tom Jones
Classic IV
Ellensburg, WA
http://forums.matronics.com/viewtopic.php?p 29467#229467
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
helili(at)chahtatushka.ne Guest
Posted: Tue Feb 10, 2009 4:42 am Post subject: Problem with FLUTTER ? ! ? ! |
Well, I spent 26 years as a military helicopter pilot and maintenance
officer and haven't heard rod end bearings referred to as anything other
than rod end bearings on a helicopter.
John Hart
KF IV, NSI Subaru
Wilburton, OK
WurlyBird
Joined: 16 May 2008 Posts: 207 Location: North Pole, Alaska
Posted: Tue Feb 10, 2009 6:44 am Post subject: Re: Problem with FLUTTER ? ! ? ! |
Sorry about the bolt mixup. Our tail rotors have very similar looking parts and I have a tendency to make my words only accurate enough to get people to understand me. So yeah, rod ends. And here is what I have going on.
Some of the rod ends were able to slide back and forth on the bolt which held it in place. This was some of the slop that I found, I put washers in to keep the rod end from slipping.
There are a few locations where the bolt holding the rod end is able to wiggle a little in the outer holes. So even if it had a nice new snug rod end there would be some play. So what is the solution for an area like this?
_________________ James
Kitfox 3 / 582 / 70" IVO 2 blade GA
50 hrs on the 582 swapping for HKS 700E and Avid Cowl. |
Lynn Matteson
Posted: Tue Feb 10, 2009 7:24 am Post subject: Problem with FLUTTER ? ! ? ! |
I have a tendency to use MORE words than is necessary, so we ought to
be able to come to a good understandable average. : )
When you say "There are a few locations where the bolt holding the
rod end is able to wiggle a little in the outer holes." I assume by
"the bolt holding the rod end" you mean the bolt that goes through
the spherical bearing in the rod end, correct? Let's call that the
"cross bolt" or a "pivot bolt" to differentiate it from the threaded
end of the linkage that the rod end bearing screws onto. Now when you
say "wiggle a little in the outer holes"...where are these "outer
holes" you refer to? I'm looking at my builder's manual, and I'm not
seeing any "outer holes", so I think we need to get to the heart of
the matter here first. Unless I'm missing something, there are no
outer holes...which might suggest selectable holes...in my manual, or
on my plane, so I'm trying to find out where these holes are that you
refer to. I'm starting to imagine that maybe a builder had drilled
some extra holes into certain parts to modify the control surfaces,
and if so, you might want to think again about buying this plane.
Can you take pictures of the parts in question...from various angles?
Don't spare the words...or the pictures in this case. People need to
see exactly what parts you are talking about so they can help you
decide whether this plane has been altered, and if so, if it is safe
to continue on with it....my opinion only.
Looking back over your previous posts, it sounds like the builder
"reamed every single hole over size."...your words. I'm starting to
get very nervous about this build, and I think you should too.
Lynn Matteson
Sensenich 62x46
On Feb 10, 2009, at 9:44 AM, WurlyBird wrote:
<james.t.trizzino(at)us.army.mil>
Prospective Kitfox buyer
Here for information on airframes and engines
http://forums.matronics.com/viewtopic.php?p 29530#229530
N369LM |
akflyer
Posted: Tue Feb 10, 2009 8:21 am Post subject: Re: Problem with FLUTTER ? ! ? ! |
Lynn, I am just gonna toss a little snake oil out here....
I am thinking (that gets me into alot of trouble) that the outer hole whurlygigahelichopter is referring to would be the "fork" that the bolt goes through in which the heim joint is captured. Say the flaperon mixer for instance. On the back side of the flap handle, under the seat the handle has a fork in which the rod end bolts through. Whurly gig a guy is saying that the forks were reamed out to big so now the bolt hole has slop in it. The only answer to that is new parts, weld build up and reaming to he proper size, or is there is enough "meat" you could drill oversize for a bushing.
snakeman.... out
EDIT to add the PDF file for a picture of what the bad word we are talking about
whurlygigahelichopter clarification.PDF |
35.89 KB |
533 Time(s) |
_________________ DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
I would rather die trying to live, than to live trying not to die.... |
Guy Buchanan
Posted: Tue Feb 10, 2009 9:39 am Post subject: Problem with FLUTTER ? ! ? ! |
At 06:44 AM 2/10/2009, you wrote:
| Quote: | Some of the rod ends were able to slide back and forth on the bolt which held it in place. This was some of the slop that I found, I put washers in to keep the rod end from slipping.
There are a few locations where the bolt holding the rod end is able to wiggle a little in the outer holes. So even if it had a nice new snug rod end there would be some play. So what is the solution for an area like this? |
James,
(I hope it's James. I do wish you'd put your name, location, and aircraft type / status in your signature.) With a rod end you're expected to torque the bolt through the ball to maximum. This helps prevent any slop between the bolt and ball and between the bolt and clevis. (The outer holes.) It's particularly useful in low-load implementations like control systems. The only slop you should have should be in the rod end itself, and that should be negligible. Of course you'll have to make sure the rod end fits the clevis closely before you torque so you don't bend the clevis, but it sounds like you've already done that by adding washers. Above all, keep asking the questions. The web is a horrible medium for fixing problems but it seems like we nearly always get there eventually. (Also, if you put your location in your signature, many times a nearby "expert" pipes up and offers to help in-person.)
Respectfully,
Guy Buchanan, Kitfox List Moderator
San Diego, CA
K-IV 1200 / 582-C / Warp / 100% done, thanks mostly to Bob Ducar. [quote][b]
_________________ Guy Buchanan
Deceased K-IV 1200
A glider pilot too. |
Lynn Matteson
Posted: Tue Feb 10, 2009 10:13 am Post subject: Problem with FLUTTER ? ! ? ! |
I got rather confused with the early reports of "30+ spherical bolts"
and "every single spherical bolt in the system, there is about 16 per
side I think", and didn't pay this thread too much attention,
thinking we had a person who...pardon my straight-forward
analysis...didn't know what he was talking about or didn't/couldn't
explain himself, but now I'm intrigued, and would like to get to the
bottom of the problem.
I'm also a bit nervous for this new owner AND the flight instructor
who went up with him, if all these holes are as bad as he says they are.
Lynn Matteson
Sensenich 62x46
On Feb 10, 2009, at 11:21 AM, akflyer wrote:
snakeman.... out
DO NOT ARCHIVE
Soldotna AK
Avid "C" / Mk IV
582 IVO IFA
Full Lotus 1260
hander outer of humorless darwin awards
http://forums.matronics.com/viewtopic.php?p 29547#229547
N369LM |
Float Flyr
Posted: Tue Feb 10, 2009 3:19 pm Post subject: Problem with FLUTTER ? ! ? ! |
.001 brass shimstock??
Noel
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Guy Buchanan
Sent: Tuesday, February 10, 2009 2:01 PM
Subject: Re: Re: Problem with FLUTTER ? ! ? !
James,
Respectfully,
San Diego, CA
K-IV 1200 / 582-C / Warp / 100% done, thanks mostly to Bob Ducar. | Quote: | | http://www.matronics.com/Navigator?Kitfox-List | 0123456789
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
WurlyBird
Posted: Fri Feb 13, 2009 9:33 am Post subject: Re: Problem with FLUTTER ? ! ? ! |
Guy, I updated my info for ya. I was waiting until I was back in the States and then forgot.
From here on out if I am going to post to this board I will make sure to be as absolutely specific about everything I mention so as not to offend anybody who wishes to not talk in laymen's terms, as this obviously degrades us all. Furthermore, I will be sure to read and familiarize myself with all applicable manuals and publications before posting a query to assure that I use only the most accurate nomenclature since clearly anyone who refers to a rod end bearing as anything but is not intelligent enough to be a pilot. I offer my sincerest apologies for any harm my poor selection of words and and the unprepared nature of my post may have caused. And to anybody who feels this apology is directed at YOU . . . Get Bent!
Float Flyer, what is shim stock? I am imagining a little brass "top hat" shaped washer or bushing that would change the ID of a hole. Am I close? Where could I get something like that?
AKFlyer, thanks for clarifying for me. Good looking out.
To those who responded off line, thanks for the in depth help.
I flew again yesterday after having tightened up as many of the rod end through bolts as possible, as well as adding washers where possible to keep the bearing from sliding on the through bolt, and there were no issues during the flight. I still need to go flying with a GPS because I still feel that the ASI is not accurate all the time. It is odd because it seems to be on at some times and way high at others. I think it is indicating about 95 when I am actually doing about 75. In any case I am keeping it below Vne indicated and will work the bugs out as I go. Thanks for the help guys.
akflyer
Posted: Fri Feb 13, 2009 11:12 am Post subject: Re: Problem with FLUTTER ? ! ? ! |
Whurly,
Mine does the same thing.. just remember winds aloft. You have to use the GPS and either fly in absolutely no wind or fly a grid to plot out true results.
Many times my airspeed is 95-100 with a ground speed of 40-45. The airframe only cares what the airspeed says.
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
Lynn Matteson
Posted: Fri Feb 13, 2009 12:14 pm Post subject: Problem with FLUTTER ? ! ? ! |
Or the other end of the spectrum.....45 mph airspeed, 9 mph ground
speed (GPS) OR 110 mph airspeed, and 170 mph ground speed.
Lynn Matteson
Sensenich 62x46
On Feb 13, 2009, at 2:12 PM, akflyer wrote:
Whurly,
DO NOT ARCHIVE
Soldotna AK
Avid "C" / Mk IV
582 IVO IFA
Full Lotus 1260
N369LM |
Float Flyr
Posted: Fri Feb 13, 2009 12:25 pm Post subject: Problem with FLUTTER ? ! ? ! |
Shim stock is simply a small sheet of brass rolled to specific thicknesses,
usually in thousands of an inch. It is quite malleable so you can form it
easily around loose bolts etc. I think the thinnest shim stock you can get
is around 0.0005"
Noel
Kitfox III-A
WurlyBird
Posted: Fri Feb 13, 2009 7:34 pm Post subject: Re: Problem with FLUTTER ? ! ? ! |
My concern with the ASI is that it is not accurate at the high end and that is limiting me a bit. On climb out it seems pretty accurate, bear with me as this is all based on "feel"; Doing slow flight, perhaps even on the back side of the power curve, rpm about 5000, jury struts indicating about 8-10 AOA, 40 mph indicated with 2 on board, she stalled the INSTANT I throttled back. It all adds up to very accurate slow flight. Full throttle, nice climb established, stick pulled back a little bit and feeling a little, just a little mushy. ASI indicates 55ish so this all seems to fit. Get up to pattern altitude and bring the throttle back to about 5500-5700, level off and the ASI quickly starts reporting 80-90mph. It is not hard to say that it is probably a little optimistic. Now here is my concern with it, I can easily remain within the aircraft's speed limits while cruising around if the ASI is reading high at the high end but when I hit a little lift and I am almost immediately pushing Vne I get a little concerned. So the plan is to go out first thing in the morning, once my GPS makes it home, and try to calibrate the ASI. I realize that DA has to be taken into account as well as winds. I will probably fly a course and a back course and compare the difference of the errors to determine the true inaccuracy. Here is the question, is there a way to calibrate the ASI besides simply bending the pitot so it is not as directly into the wind? What is the RIGHT way to do this?
Float Flyr
Posted: Fri Feb 13, 2009 8:04 pm Post subject: Problem with FLUTTER ? ! ? ! |
This is starting to sound like a problem with the static port. Best to have
one static port on each side of the plane, tied together with the lines for
your altimeter, VSI and ASI teed into it.
You definitely have a problem there albeit a minor one because you are used
to the way your plane flies.
Noel
Kitfox III-A
Float Flyr
Missed again!
The ASI can be tested and calibrated using a Barfield tester it won't be
cheap! Unless you know someone who has one sitting on their bench. Even
with a properly calibrated ASI you can still have problems due to the
positioning of the pitot and the static ports. This is nothing to be
passive about as in the past number of years at least one jetliner has
crashed because static ports were covered for painting and afterward the
tape covering the port was not removed. Of course for guys who only foy
instruments this is a real nightmare. For the rest of us...it becomes an
inconvenience.
Noel
Kitfox III-A
Float Flyr
Michael Logan
Posted: Sat Feb 14, 2009 5:55 am Post subject: Problem with FLUTTER ? ! ? ! |
No need to pay a lot for the Barfield tester, Jim Weir showed how to make
one cheaply in Kitplanes a couple of months back.
Mike
Series 5
_________________ Mike Logan
Fredericksburg, VA |
jcorner(at)shaw.ca Guest
Posted: Sat Feb 14, 2009 8:38 am Post subject: Problem with FLUTTER ? ! ? ! |
Mikes note reminded me of a web bookmark on ASI Calibration.
Try http://www.iflyez.com/manometer.shtml
Jim Corner
Model 2, 582,. Ivo med !FA, 1100 hrs
Model 5, 0-235 40 hrs
Calgary, AB
On 14-Feb-09, at 6:55 AM, Michael Logan wrote:
