aviateer
Posted: Mon Dec 29, 2008 7:53 am Post subject: skis |
Hello Fellow Snowfoxers,
Attached are a few more pictures of my skis for those of you that are interested. My memory is a little flawed. Earlier I stated that my skis are 12" wide. After I took these pictures a couple days ago, I checked and in fact they are only 10" wide. My bad. I think the "sometimers" is setting in.
Kirk
On Wed, Dec 24, 2008 at 9:11 AM, fox5flyer <fox5flyer(at)idealwifi.net (fox5flyer(at)idealwifi.net)> wrote:
[quote] Great commentary, Kirk. Thanks for sharing. A lot of the folks on this list never see snow and have little use for this ski stuff, but for those of us that do, I'm finding it a treasure of information. I have a set of Federal 1500s for my S5, but I think I can do much better. All it takes is a little bit of information here, a little there, some inspiration, tinkering, and away we go. I don't think there is any big mystery or magic about making a good set of skis. Just some imagination, common sense, some work, and the fun begins.
Awaiting those photos.
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 402+ TT
- Joseph Joubert
134.4 KB |
490 Time(s) |
164.22 KB |
505 Time(s) |
135.3 KB |
497 Time(s) |
infow(at)mts.net Guest
Posted: Tue Dec 30, 2008 6:31 pm Post subject: skis |
Neat Skis Kirk...
What is the frame made out off, looks like 1/4 plate?
Ron
[quote] Hello Fellow Snowfoxers,
Kirk
> Deke Morisse
> Mikado Michigan
> progress." - Joseph Joubert
> do not archive
aviateer
Posted: Tue Dec 30, 2008 6:41 pm Post subject: skis |
Thanks Ron.
The frame is made from .125" 6061 T6 aluminum plate. I made 4 revisions to the prototype before I got the design right. It still may not be right, but they seem to work.
Kirk
On Tue, Dec 30, 2008 at 8:29 PM, R.D.(Ron) Leclerc <infow(at)mts.net (infow(at)mts.net)> wrote:
[quote]--> Kitfox-List message posted by: "R.D.(Ron) Leclerc" <infow(at)mts.net (infow(at)mts.net)>
Neat Skis Kirk...
Ron
| Quote: | Hello Fellow Snowfoxers,
| Quote: | the "sometimers" is setting in.
Kirk
> wrote:
| Quote: | > think I can do much better. All it takes is a little bit of
| Quote: | > about making a good set of skis. Just some imagination, common
>> Deke Morisse
| Quote: | > Mikado Michigan
>> do not archive
[quote]>
Posted: Tue Dec 30, 2008 7:01 pm Post subject: skis |
Thanks Kirk
What did you use to get the curved up front of the ski... and how high does it come up? Looks like it is 2-3" only... seems kind of low!
Ron
[quote] Thanks Ron.
Kirk
wrote:
> Neat Skis Kirk...
> Ron
>> Kirk
>>> begins. Awaiting those photos. Deke Morisse Mikado Michigan
>>> but progress." - Joseph Joubert
>>> do not archive
aviateer
Posted: Tue Dec 30, 2008 7:31 pm Post subject: skis |
It is only about 3" high.
I used a garbage can lid to trace an arc to a piece of wood that looked about right. I then took the wooden template and traced it to one side of a piece of aluminum angle that is the ski portion of the frame. I cut the piece out, then bent the bottom of the angle to match the arc and welded it. It could be low, but other store bought skis are about the same. I then cut the scrap off, and welded a cross piece in.
Kirk
On Tue, Dec 30, 2008 at 9:00 PM, R.D.(Ron) Leclerc <infow(at)mts.net (infow(at)mts.net)> wrote:
[quote] --> Kitfox-List message posted by: "R.D.(Ron) Leclerc" <infow(at)mts.net (infow(at)mts.net)>
Thanks Kirk
Ron
| Quote: | Thanks Ron.
Kirk
> wrote:
>> Neat Skis Kirk...
| Quote: | >
> Ron
| Quote: | >> that are interested. My memory is a little flawed. Earlier I
| Quote: | >> My bad. I think the "sometimers" is setting in.
>> Kirk
| Quote: | >>
| Quote: | >>> treasure of information. I have a set of Federal 1500s for
| Quote: | >>> inspiration, tinkering, and away we go. I don't think there
| Quote: | >>> begins. Awaiting those photos. Deke Morisse Mikado Michigan
[quote]>>>
>>> do not archive
Posted: Wed Dec 31, 2008 3:20 pm Post subject: skis |
Thanks Kirk...
What size is the angle... looks quite heavy? Do you have any more photos?
Thanks... Ron
| Quote: | It is only about 3" high.
Kirk
wrote:
Thanks Kirk
low!
Ron
> Thanks Ron.
> Kirk
