Header Tank Venting
Goto page Previous  1, 2
pwmac(at)sisna.com
PostPosted: Fri Oct 17, 2008 4:33 pm    Post subject: Header Tank Venting Reply with quote
Lots of examples Just do your homework
Agree. Asymmetrical fuel flow from the tanks has nothing to do with starvation. Fixes for it are not necessary. Just follow the details on the install and the issue will go away. Nice fat lines are also good and no restrictions in any of the lines are also good. No filter or other components in the header to tank lines helps that situation.
Paul
At 09:26 AM 10/17/2008, you wrote:
[quote]If as you suggest the header tank vent was OFF then in Lowell's example or other similar scenario the automatic refilling of the header tank would be prevented and air/fuel blockages of the two feed lines from the wing tanks WOULD likely slow or prevent flow to the header tank and encourage fuel starvation with adequate fuel remaining in the wings.
Add my name to the many with asymetrical fuel flow from the tanks but no evidence of the header tank being deprived. I don't have a low fuel warning but there are many out there to monitor the possiblity of starvation. Were there any warnings that were triggered as a result of the asymetrical draw. What are the specifics of the "many crashes due to fuel starvation"? Sounds like urban myth to me.
John Kerr
Classic IV, 912ul, 780 hours.
Logan UT
====== UOTE>< /body>
Kitfox-List Email Forum -
- MATRONICS WEB FORUMS -
http://forums.matronics.com
- List Contribution Web Site -
[/b]
Michael Logan
PostPosted: Sat Oct 18, 2008 4:57 am    Post subject: Header Tank Venting Reply with quote
Also, don't fly with your flaps down for very long. Even at half full
tanks, you will run out of fuel and the engine will quit. Don't ask me how
I know.
Mike Logan
Series 5
Mike Logan
Fredericksburg, VA
Float Flyr
PostPosted: Sat Oct 18, 2008 5:31 am    Post subject: Header Tank Venting Reply with quote
To keep it short... Follow the plans and vent the header tank! Forget
about valves and breathers. Venting to both tanks sounds interesting but
will accomplish nothing except an increase in weight and complexity.
Noel Loveys
AME Intern, RPP
Kitfox III-A
Ivo IFA, Aerocet 1100 floats
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Float Flyr
IMHO most fuel starvation will come from blocked cap breathers on the left tank.
Noel Loveys
Campbellton, NL, Canada
CDN AME intern, PP-Rec
C-FINB, Kitfox III-A
[url=noelloveys(at)yahoo.ca]noelloveys(at)yahoo.ca[/url]
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of paul wilson
Sent: Friday, October 17, 2008 9:55 PM
Subject: Re: Re: Header Tank Venting
Paul
John Kerr
Logan UT
Kitfox-List Email Forum -http://www.matronics.com/Navigator?Kitfox-List- MATRONICS WEB FORUMS -http://forums.matronics.com- List Contribution Web Site --Matt Dralle, List Admin.
5
6
7
8
9
 Filesize:  7.29 KB
 Viewed:  2709 Time(s)
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
JetPilot
PostPosted: Sat Oct 18, 2008 3:47 pm    Post subject: Re: Header Tank Venting Reply with quote
Andy Is Correct,
Putting valves and closing the vent on the header tank is just plain dangerous and dumb. Someone is giving out very bad and dangerous advice. There are things that this " Bad Advice " person did not take into consideration. It would take a lot of research and evidence before I would even think about changing the Kitfox design. EAA has people very well versed in fuel systems, I would at least talk to some real experts before I changed a good and proven design.
Mike
Kolb MK-III Xtra, 912-S
Page 2 of 2
