John Vormbaum
Joined: 21 Aug 2006 Posts: 273 Location: SF Bay Area, CA
Posted: Fri Oct 10, 2008 4:17 pm Post subject: HHO |
Cool!
In the 80's I imagine he didn't need a helicopter, as he was generally
very "high" for most of that decade from what I remember.
Tom Fisher wrote:
<tfisher(at)commandergroup.bc.ca>
Back in the early 70's I used to fly John Delorean around in
helicopters at his plant in Fredericton, New Brunswick, Canada.
Tom
C-GISS
| | - The Matronics Commander-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Commander-List |
wjrhamilton(at)optusnet.c Guest
Posted: Sat Oct 11, 2008 7:24 pm Post subject: HHO |
Folks,
A friend of mine is involved in development testing with Mercedes.
Their new engine lines with direct petrol injection are producing efficiencies that that translate into big sedans with plenty of performance, ie the same power/weight ration as now, but reducing fuel consumption from 12/16 lt:100km, down to 5/8 lt.:100km, ie fuel consumption in already reasonably efficient engines reduced by half.
It’s all about increasing compression ratios, but chamber/injector design reducing/eliminating pre ignition or detonation.
These engines will equal or better automotive diesels.
Bill Hamilton.
If you want to do the maths, approx. 4 lt= 1 US Gallon, 1 km approx. Equals 5/8 of a statute mile.
From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of willis robison
Sent: Saturday, October 11, 2008 7:44 AM
Subject: Re: HHO
From an engineering and Thermodynamics standpoint, the internal combustion engine (at least the Otto Cycle) is pretty maxed out. For regular piston-gasoline pushrod or overhead cam engines the total efficiency is dictated by the maximum pressure you can obtain. Lately, higher compression and higher temperatures have pushed the efficiency to the limits obtainable with current materials (aluminum blocks, nitrided steel cylinders etc). computer control of the mixture took it to another level, but noone will allow a micro controller on an AC without going through an extensive Qual process.
Newer High Temperature materials may increase this but absolute "e" is still = [T(high) - T(low)]/T(low).
Diesel's are less dependent on T(high) but are still dependent on the Max pressure. Thats why they are so good at being turbocharged at high altitude. Same goes for Brayton cycle engines (jets). in that case the limits are [P(high) - P(low)]P(low).
Now you know why those old---GSO-480's are still popular. Lots of juice and still efficient at high altitude if you roll back on the throttles. (but who would?)
bud
--- On Fri, 10/10/08, Chris <cschuerm(at)cox.net> wrote:
Subject: Re: HHO
Date: Friday, October 10, 2008, 12:18 PM | Quote: | | --> Commander-List message posted by: Chris <cschuerm(at)cox.net> Don wrote:> I try and keep and open mind, one day I firmly believe, a > revolutionary change will happen to greatly improve our internal > combustions engine. Well Don, I applaud your positive outlook. From a purely scientific perspective, there are very few areas to improve a traditional Otto cycle engine. Even if some new miracle material were to arrive that | 01234567890123456 |
789 | Quote: | | > I try and keep and open mind, one day I firmly believe, a | 0 | Quote: | | > I try and keep and open mind, one day I firmly believe, a | 1 | Quote: | | > I try and keep and open mind, one day I firmly believe, a | 2 | Quote: | | > I try and keep and open mind, one day I firmly believe, a | 3 | Quote: | | > I try and keep and open mind, one day I firmly believe, a | 4 | Quote: | | > I try and keep and open mind, one day I firmly believe, a | 5 | Quote: | | > I try and keep and open mind, one day I firmly believe, a | 6 | Quote: | | > I try and keep and open mind, one day I firmly believe, a | 7 | Quote: | | > I try and keep and open mind, one day I firmly believe, a | 8 | Quote: | | > I try and keep and open mind, one day I firmly believe, a | 9 | Quote: | | > revolutionary change will happen to greatly improve our internal | 0 | Quote: | | > revolutionary change will happen to greatly improve our internal | 1 | Quote: | | > revolutionary change will happen to greatly improve our internal | 2 | Quote: | | > revolutionary change will happen to greatly improve our internal | 3 | Quote: | | > revolutionary change will happen to greatly improve our internal | 4 | Quote: | | > revolutionary change will happen to greatly improve our internal | 5 | Quote: | | > revolutionary change will happen to greatly improve our internal | 6
dongirod
Posted: Sun Oct 12, 2008 7:19 pm Post subject: HHO |
Bill.
Did I do the math right, that is almost 100 mpg?
Don
dongirod
Posted: Sun Oct 12, 2008 7:22 pm Post subject: HHO |
Bill
Did you mean 5/8 liter or was it 5 to 8 liters per 100 km?
I think that was my error.
Don
steve2(at)sover.net Guest
Posted: Mon Oct 13, 2008 4:55 am Post subject: HHO |
Hey, I'm supposed to be the environmental wacko on this list. I'm gone for a
couple days and look what happens. You guys start splitting molecules and
running engines on water. Quit moving in on my territory. I've got a
reputation to think about.
Anybody remember the magnetic gizmos they used to sell to strap to fuel
lines that 'aligned the ions' or some some such thing......
I'm still pretty amazed at how efficient ancient aircraft engines are at
doing the job they were designed for. Especially at lean of peak. I can't
find the reference anymore, but there was a good (now dated) piece kicking
around discussing how a lot of the modern advances in automobile powerplants
didn't translate as well to slow turning aircraft engines. Multi-valve
technology, the frictional losses of geared drivetrains, and frictional
losses of double and higher RPM's.
Better and more efficient fuel delivery seems to be an area that could still
use improvement, and better management of when you really need the extra
rich mixture.
Got to go out and stack some more firewood.
Steve
dowens(at)aerialviewpoint Guest
Posted: Tue Oct 14, 2008 3:23 am Post subject: HHO |
Don,
Sorry for any confusion, 5 to 8 litres per 100 km ---- In an almost 3 ton car. By 5 to 8 lt/100 km, I am referring to standard city cycle ( and country cycle (5) tests. Small European cars that do 80 mpg ( Imperial) are common, but the latest developments are really something, with petrol catching up with diesel.
Mind you, they (Benz) have been working on direct injection since the 1930’s, maybe earlier, remember the Me 109.
Bill Hamilton
From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Don
Sent: Monday, October 13, 2008 2:19 PM
Subject: Re: HHO
Bill.
Don
----- Original Message -----
From: Bill Hamilton (wjrhamilton(at)optusnet.com.au)
To: commander-list(at)matronics.com (commander-list(at)matronics.com)
Sent: Saturday, October 11, 2008 11:24 PM
Subject: RE: Commander-List: HHO
Folks,
Bill Hamilton.
Subject: Re: HHO
bud
Subject: Re: HHO
- Release Date: 10/8/2008 7:19 PM > I try and keep and open mind, one day I firmly believe, a | 8 | Quote: | | > I try and keep and open mind, one day I firmly believe, a | 9 | Quote: | | > revolutionary change will happen to greatly improve our internal | 0 | Quote: | | > revolutionary change will happen to greatly improve our internal | 1 | Quote: | | > revolutionary change will happen to greatly improve our internal | 2 | Quote: | | > revolutionary change will happen to greatly improve our internal | 3 | Quote: | | > revolutionary change will happen to greatly improve our internal | 4 | Quote: | | > revolutionary change will happen to greatly improve our internal | 5 | Quote: | | > revolutionary change will happen to greatly improve our internal | 6 | Quote: | | > revolutionary change will happen to greatly improve our internal | 7 | Quote: | | > revolutionary change will happen to greatly improve our internal | 8 | Quote: | | > revolutionary change will happen to greatly improve our internal | 9 | Quote: | | > combustions engine. | 0 | Quote: | | > combustions engine. | 1 | Quote: | | > combustions engine. | 2 | Quote: | | > combustions engine. | 3 | Quote: | | > combustions engine. | 4 | Quote: | | > combustions engine. | 5 | Quote: | | > combustions engine. | 6 | Quote: | | > combustions engine. | 7
Posted: Tue Oct 14, 2008 4:15 am Post subject: HHO |
Pretty sure GM is deep into direct injection now also, even for North America.
I'll have to look that up.
Steve
