john(at)vormbaum.com Guest
Posted: Mon Mar 13, 2006 9:56 am Post subject: AGING AIRCRAFT |
Quote: | John V.....
At one time I thought "Mr. RPM had a maint Facility in Costa Rica doing
Twin Commander wing spar caps at a bargain price (relatively speaking).
Hi Milt,
I think there is still a "bargain spar cap replacement deal", but the
bargain is right around $60k. I'm really hoping that won't be necessary
until 35,000 hours or so.
| - The Matronics Commander-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Commander-List |
YOURTCFG(at)aol.com Guest
Posted: Mon Mar 13, 2006 10:04 am Post subject: AGING AIRCRAFT |
In a message dated 3/13/2006 9:40:27 A.M. Pacific Standard Time,
cschuerm(at)cox.net writes:
I believe should be uncovered and
inspected every decade or so. The vertical hangars behind the firewall
on the front of the spar - for example - have probably never been looked
at on most Commanders.
Thanks Chris Another area is the flap/aileron/rudder and elevator hangars.
The aileron hangars have been problematic for some years, the rest need a
good look. I did an appraisal on an 840 Commander in Cartrgena Columbia. The
aileron hangars had corroded clear off and the ailerons were laying on the
ground right were they had fallen off!! jb
Posted: Mon Mar 13, 2006 10:19 am Post subject: AGING AIRCRAFT |
Yet more proof that regardless of how robust an aircraft is, some people
just shouldn't be pilots!!!
/John
Posted: Mon Mar 13, 2006 10:20 am Post subject: AGING AIRCRAFT |
I hate hearing that. As a certifiable Tool Nut, it breaks my heart to hear
about good tools being abused in that fashion.
/John
cschuerm(at)cox.net Guest
Posted: Mon Mar 13, 2006 10:22 am Post subject: AGING AIRCRAFT |
YOURTCFG(at)aol.com wrote:
Quote: | Thanks Chris Another area is the flap/aileron/rudder and elevator hangars.
Wow - just fell right off? Sounds like that would have been a good
subject airplane for overall damage investigation.
Interesting that there's no AD on the flap hangars isn't it? Seems like
almost every other airplane has some form of "inspect for
cracks/damage/etc" in this area (my Aztec included). Just another one
of those alloy plate/extrusion areas with a high load and subject to water.
chris
wjrhamilton(at)optusnet.c Guest
Posted: Mon Mar 13, 2006 1:19 pm Post subject: AGING AIRCRAFT |
Folks,
Re. Richard's 680E, at least he has the luxury of an aircraft
corrosion proofed "to MilSpec" standards, the 680Es bought by the old
Australian Department of Civil Aviation were all corrosion proofed
during manufacture, and it shows. Lucky chap !! The contrast sits
right behind him, my 500A, " corrosion proofed" after manufacture, I
suspect well after.
My Commander experience says ( amongst other things) that every lap
joint is suspect ( as well as the other comments so far). I am also
having to replace a number of fluted skins on aileron/flaps and
horizontal stab/elevators.
In my opinion you have to be very careful about the Australian
approach to " hard" fatigue lives, "they got religion".
But having said that, there are some really serious problems with
C400 series, and various Beech, particularly Barons, all a
combination of a hard life, corrosion and cracking. An emerging story
is serious cracking in pressure cracking in a number of Kingairs,
several here are probably headed for the scrap heap. On one recent
402B, just about every fastener hole around the engine/undercarriage
mounts and spar structure had to be reworked, and there was much
replacing of various bits of the structure. The same aeroplane had
extensive corrosion for most of the length ( height) in the fin.
We are also seeing VERY serious corrosion in some strutted Cessna, if
I was to buy a C172/182, having seen what I have seen, I would factor
in stripping down both wings, it is the sandwich spar from the root
to just outboard of the fuel tank, and one aircraft that had to be
rebuilt was an ex-USAF version of the 172, that had spent most of its
life in the dry reaches of inland Texas.
An entirely subjective comment ( a personal opinion, no science
behind it) is that the bigger Pipers seem to throw up fewer
unexpected horror stories.
An interesting issue arises about inspection techniques, many of the
FAA " GA approved" inspection techniques are about a generation out
of date, compared to Boeing/Airbus "manufacturer's maintenance
manual" techniques, which causes us quite a few problems, as some
CASA individuals ( inspectors) are in the habit of demanding
compliance with FAA/SID in detail, including use of ultrasonic crack
detection that has been superseded by equipment that does not require
every fastener to be removed. Needless to say, the practitioners of
the black magic of ultrasonic and eddy current crack detection have
long since junked their superseded equipment.
Bill Hamilton
At 23:26 13/03/2006, you wrote:
<barry.collman(at)air-britain.co.uk>
Hi John,
Nope, I'm sorry, but I don't have the parts count for a Commander.
But, if you bring yours to the next Fly-In, we could strip it down
and find out!
Maybe 'down-under' Richard has an 'ball-park' figure after his extensive
restoration of a 680E?
Best Regards,
Barry
barry.collman(at)air-brit Guest
Posted: Mon Mar 13, 2006 1:25 pm Post subject: AGING AIRCRAFT |
Just JimBob keeping abreast of the situation.
Then, we're fortunate that he's so up-front about everything.
Seriously though, this once again emphasises the need for owners to join the
Flight Group. The more Members we have, the more the FAA are likely to take
notice of us.
It also emphasises, yet again, that we have a Leader who is truly looking after
your interests.
Once again, as WinG Commander Gordon said, we have to say a big "Thank You" to
Jim.
Best Regards,
Barry
Posted: Mon Mar 13, 2006 1:49 pm Post subject: AGING AIRCRAFT |
W J R HAMILTON wrote:
during manufacture
That's an interesting bit of trivia that I was unaware of. Thanks!
Quote: | We are also seeing VERY serious corrosion in some strutted Cessna
I've seen some pretty serious corrosion here in the midwest lately on
Cessnas as well. Cessna did virtually nothing for corrosion-proofing
except on the few birds set up for float ops. Amazing how much
corrosion I've seen inside the wings of Cessnas that have been hangared
in Oklahoma their entire lives. Just condensation will do it.
That's been my observation as well Bill. Piper did a pretty darn good
job of slathering zinc chromate all over in many of their models. I
havn't found any corossion at all in my '65 Aztruk even after a total
tear-down restoration. Pitty that everybody didn't do the same.
chris
WINGFLYER1(at)aol.com Guest
Posted: Mon Mar 13, 2006 3:57 pm Post subject: AGING AIRCRAFT |
Just want you guys to know,as a new owner I appreciate learning about my 680
and other commanders as well. I appreciate the opportunity to read your
comments Again,many thanks.Gil Walker .
nico(at)cybersuperstore.c Guest
Posted: Mon Mar 13, 2006 4:16 pm Post subject: AGING AIRCRAFT |
Gil,
You're not scared stiff yet?
Posted: Mon Mar 13, 2006 6:36 pm Post subject: AGING AIRCRAFT |
In a message dated 3/13/2006 1:27:36 PM Pacific Standard Time,
barry.collman(at)air-britain.co.uk writes:
to
Jim.
Thanks guys. jb
Posted: Mon Mar 13, 2006 7:53 pm Post subject: AGING AIRCRAFT |
I've stopped laughing now. Oh, the depth of the intellect in this group.
Posted: Mon Mar 13, 2006 8:51 pm Post subject: AGING AIRCRAFT |
I hear you, Nico....but do you think that Principal Fatigue Engineers ever
have this much fun?
Posted: Mon Mar 13, 2006 10:57 pm Post subject: AGING AIRCRAFT |
As much as I admire WCG, I have to give credit where it's due. Sir Barry, in
his typical British fashion, capitalized on that typo with exceptionally
droll doublespeak, nearly knocking me off my chair.
Sir Barry, you're the best!
/John
Posted: Tue Mar 14, 2006 10:00 am Post subject: AGING AIRCRAFT |
In a message dated 3/13/2006 10:58:28 PM Pacific Standard Time,
john(at)vormbaum.com writes:
WHHHAT TYPOR>?/?
Posted: Tue Mar 14, 2006 10:05 am Post subject: AGING AIRCRAFT |
Pesronally JmiBob, I dno'nt fink your Speel-chequer is wurking coorektly.
Try re-boobing your machine.
Best Regards,
Barry
Barshalom(at)aol.com Guest
Posted: Tue Mar 14, 2006 7:45 pm Post subject: AGING AIRCRAFT |
In a message dated 3/14/2006 10:06:14 AM Pacific Standard Time,
Try re-boobing
MY MACHINEE DOENT HAUV ANY BOOBS!! I guiess i need to upgraid. jb
