Rex Hefferan
Joined: 10 Jan 2006 Posts: 147 Location: Olney Springs, Colorado USA "NOT a Kitpig"
Posted: Tue Mar 25, 2008 12:14 pm Post subject: skis |
The point that you can interpret the FAA regs to favor your desires, if
possible seemed to be the way I was taught in Flight School.
Rex Hefferan
SE Colorado / K-II / 582-C / still waiting repairs
84KF wrote:
| Quote: | Look at it this way:
The aircraft configuration */is /* intended for use on land, and IAW
the regs, landing gear */IS/* fixed....Nothing in the regs say the
skis cannot used, or that said skis cannot be retractable.
As always, we must not make things seem worse by ASSUMING the FAA says
something, when in reality, they haven't.
Steve
84KF
_________________ Rex
N740GP - M2/582
Colorado |
Michel
Posted: Tue Mar 25, 2008 12:34 pm Post subject: skis |
| Quote: | From: Lynn Matteson [lynnmatt(at)jps.net]
Just to keep me from getting a swelled head, it wasn't my idea for
the "L" shape...I'm just seeing what others have built and borrowing
their ideas.
I know, Lynn, those already exist, like here:
http://www.lightsportaircraft.ca/sun-n-fun2006/fbi-accessories.html
But I didn't think about their advantage before you mentioned the drag og the 'open hole' type as I remember how much snow was getting on the top of my skis right behind the wheel.
Michel Verheughe
Norway
Kitfox 3 - Jabiru 2200
_________________ Kitfox 3 - Jabiru 2200 |
akflyer
Posted: Tue Mar 25, 2008 2:20 pm Post subject: Re: skis |
I just did some checking on those skis. The look great and apparently worked killer on a kit fox, but were never offered to the public. Only one set was ever produced, they were shown to see what kind of interest would be generated.
I would like to know if anyone on the list would buy a set and if so, what would you realistically be willing to spend for them. It may be worth it to get the molds and put them into production as right now it is a pretty much build your own for our size planes.
Let me know if there is any interest.
_________________ DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
I would rather die trying to live, than to live trying not to die.... |
Lynn Matteson
Posted: Tue Mar 25, 2008 4:05 pm Post subject: skis |
Ahhhh.....good idea, L. Sort of like a valve head-to-seat fit with
the tapered plate, eh? This of course would require a much less wheel
penetration than the 2" that I built into mine, and a tire pump. I
landed in about 9" of snow a few weeks ago, and the resultant later
takeoff required about 400' of an almost porpoising takeoff run.
Excellent idea! I've heard of the drop-the-air pressure trick with a
filler board of some sort, but the tapered fit just fine-tunes it.
Leave it to the guys who have to, to come up with the best ideas.
Something about Mothers and Inventions and Necessity.....: )
What about a subsequent landing on a paved strip? Hafta find a less
deep snow-strip nearby, and go back to tires penetrating, then head
for the hard stuff, I'd guess.
Lynn Matteson
flying w/480+ hrs/down for annual
On Mar 25, 2008, at 4:11 PM, akflyer wrote:
Lynn, that is correct that John sent the drawings I think, also
correct he is my brother.
One trick we use is to have a plate that covers the hole in the ski
so when we get out in the back country, and find ourselves in deep
snow, you let the air out of the tire, roll the plate between the
ski and tire then put enough air back in the tire to hold it. This
will make a virtually impossible takeoff very easy. I know guys
that landed just fine but there was too much drag for them to be
able to take off again with wheel penetration skis. The spent alot
of time on snowshoes packing a runway.
The best way I have seen to make this plate it to make your cut out
in the ski at a bevel not a straight cut. Then you cut out your
plate on a bevel so it will drop in flush with the cut out. You
have then made a set of normal straight skis with very little drag
in the snow.
Steve, a VERY valid point. the wheels would remain fixed therefor
the primary gear is fixed, not retractable... very good point, i
would argue that one all day long too, but then again, I just love
to argue, especially with an official.
DO NOT ARCHIVE
Leonard Perry
Soldotna AK
Avid "C" / Mk IV
582 IVO IFA
Full Lotus 1260
95% complete
http://forums.matronics.com/viewtopic.php?p=172610#172610
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Lynn Matteson
Posted: Tue Mar 25, 2008 4:12 pm Post subject: skis |
Man, oh man, I sure hope looking at those skis doesn't influence my
thinking! : )
Thanks for the tip, Michel.
Lynn Matteson
On Mar 25, 2008, at 4:27 PM, Michel Verheughe wrote:
| Quote: | > From: Lynn Matteson [lynnmatt(at)jps.net]
> their ideas.
Michel Verheughe
Norway
List">http://www.matronics.com/Navigator?Kitfox-List</a>
forums.matronics.com</a>
www.matronics.com/contribution</a>
</b></font></pre>
N369LM |
Lynn Matteson
Posted: Tue Mar 25, 2008 4:24 pm Post subject: skis |
I'd be interested, but I'd be hard pressed put a price on what I'd
pay. When I think about parting with dollars, I start thinking about
what fun it'd be to build. But if you get some offers and start to
manufacture, let it be known and maybe the price would cause me to
rethink my frugalness.
Lynn Matteson
On Mar 25, 2008, at 6:20 PM, akflyer wrote:
DO NOT ARCHIVE
Leonard Perry
Soldotna AK
Avid "C" / Mk IV
582 IVO IFA
Full Lotus 1260
95% complete
http://forums.matronics.com/viewtopic.php?p=172638#172638
N369LM |
Float Flyr
Float Flyr
Posted: Tue Mar 25, 2008 5:01 pm Post subject: skis |
Ponds work pretty good for taking the plates out.
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
eskflyer
Posted: Tue Mar 25, 2008 7:55 pm Post subject: Re: skis |
OK guys and gals here is a site to take you to some great pics of Alaska and flying in a fox . Click on the pics when the page loads and check them out . the last several pages have the fox on FROZEN water flyin on floats . Who needs skis with full lotus . Skis are great I would get a little more top speed out of her but heck this is what she is built for .
www.myspace.com/eskflyer
_________________ FLY FUN FLY LOW FLY SLOW
John Perry
Kitfox 2 N718PD
582 cbox 2:62-1 IVO IFA
1220 Full Lotus |
akflyer
msm_9949(at)yahoo.com Guest
Posted: Wed Mar 26, 2008 7:37 am Post subject: skis |
I'd buy a set too Leni, if the price isn't too steep. I'd rather be flying than building skis. But first I need cabin heat. How about manufacturing a heat muff assembly for the 582?
Lynn Matteson <lynnmatt(at)jps.net> wrote:
[quote]--> Kitfox-List message posted by: Lynn Matteson
Lynn Matteson
[quote] --> Kitfox-List message posted by: "akflyer"
DO NOT ARCHIVE
Leonard Perry
Soldotna AK
Avid "C" / Mk IV
582 IVO IFA
Full Lotus 1260
95% complete
Read this topic online [quote][b]
akflyer
Posted: Wed Mar 26, 2008 11:29 am Post subject: Re: skis |
I am checking into production costs, but I would think a target price of 650-750 would not be out of line. It may very well be a tad cheaper but if they came in at anything above that I doubt too many would buy them.
Also would think about making straight ski's too a little cheaper.
Just food for thought
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
Float Flyr
Posted: Wed Mar 26, 2008 1:16 pm Post subject: skis |
Lynn:
Have you ever seen the hydraulic skis they use on certified planes? The weight of the hydraulic system is surprisingly low especially if you can find the aluminium rams. They have two channels in the top of the ski that go past and in front of the wheel hole then a double action rams push a slides under each main wheel. The rams are operated by a hand pump in the cabin. The skis usually have springs which allow the ski to be pushed down a little bit as the slide covers the wheel but I’m sure low pressure tires would do the same thing.
As for flying LSA on penetration skis there are two things to consider 1. There is no reconfiguration in the air and 2. The plane is still described as a land plane. If I was going to use them I’d talk to the FAA first.
I think the spirit of the LSA is offer flight without complexity i.e. forgetting to put your gear down before landing. Float planes will land pretty well on runways...Taking off again though is another matter. They don’t want to allow the planes to get too big, too complex or for that matter too fast so that is the reason for no IFA props. And they don’t want anyone to come up with arguments like, “I wasn’t using the IFA capability of the prop”, or the A&P was supposed to take that prop off before the plane was registered, etc.
These are only opinions and as such may not be worth the paper they are not printed on.
Noel Loveys
Campbellton, NL, Canada
CDN AME intern, PP-Rec
C-FINB, Kitfox III-A
582 B box, Ivo IFA, Aerocet 1100 floats
[url=noelloveys(at)yahoo.ca]noelloveys(at)yahoo.ca[/url]
7.29 KB |
14325 Time(s) |
Kitfox III-A
patreilly43(at)hotmail.co Guest
Posted: Wed Mar 26, 2008 2:32 pm Post subject: skis |
Your 582 is water cooled. Get a Fiero heater core, $30 on e-bay, a Radio Shack computer cooling fan, $15 (they are 12 volt), mount and plumb it. Forget about heater muffs. They are for aircooled engines. You have hot water, It is a better method of heating, use it.
Pat Reilly
Mod 3 Rebuild
Rockford, IL
[quote] Date: Wed, 26 Mar 2008 08:32:43 -0700
Subject: Re: Re: skis
| Quote: | --> Kitfox-List message posted by: Lynn Matteson
Lynn Matteson
| Quote: | --> Kitfox-List message posted by: "akflyer"
DO NOT ARCHIVE
Leonard Perry
Soldotna AK
Avid "C" / Mk IV
582 IVO IFA
Full Lotus 1260
95% complete
arget=_blank>http://www.matronics.com/Navigator?Kitfox-List
| [b]
akflyer
Posted: Wed Mar 26, 2008 3:35 pm Post subject: Re: skis |
the heater core will not even come close to putting out the hot air a properly constructed heat muff will.
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
Posted: Wed Mar 26, 2008 7:30 pm Post subject: skis |
I would imagine you are right. But, the question is, will the heater core put out "enough" heat.
Pat Reilly
Mod 3 Rebuild
Rockford, IL
avidfox
Posted: Wed Mar 26, 2008 8:20 pm Post subject: skis |
Pat,
The Series 5 I have is equipped with a heater core. Referring to the original Skystar packing list, dated 01/23/95, it was part of "Heater Kit, Single, 912 #69014.000 ". The "Radiator, Cabin Heater" is part #15044.000. The included fan was a 4"
All other parts and part #'s are included in the list also.
The heater does work. But, you wouldn't know it unless you stick your hand under it.
The total efficiency is going to be determined by actual coolant temps and how air tight you cabin is.
I do not have a thermostat in the system so coolant temps are at the mercy of ambient air temps and my cabin has a lot of drafts so, in my particular plane, it's just about useless. With some work (read $$), maybe.
I'm talking about flying in 35' 'F or less, and when you consider wind chill and any altitude, It gets cold. Gloves were mandatory for me this winter.
I am not saying it couldn't be better... it is all due to the individual construction of the plane, and mine has not been modified from the original design.
Steve
84KF
KF5\912UL
Guy Buchanan
Posted: Wed Mar 26, 2008 9:07 pm Post subject: skis |
At 09:16 PM 3/26/2008, you wrote:
| Quote: | | I do not have a thermostat in the system so coolant temps are at the mercy of ambient air temps and my cabin has a lot of drafts so, in my particular plane, it's just about useless. With some work (read $$), maybe. |
The thermostat is only 135F. Even with it in you're not going to get much heat unless you're running near the 180F max water temp. On my plane that only happens in the summer on climb-out. Not much requirement for a heater then.
Guy Buchanan
San Diego, CA
K-IV 1200 / 582-C / Warp / 100% done, thanks mostly to Bob Ducar. [quote][b]
_________________ Guy Buchanan
Deceased K-IV 1200
A glider pilot too. |
Float Flyr
Posted: Thu Mar 27, 2008 12:04 am Post subject: skis |
I would argue the amphib floats change a seaplane into a land plane and that
is allowed. With penetration or retractable skis on the other hand a land
plane remains a land plane so why shouldn't it also be allowed for the same
reason as amphib floats... It's safer. At least in the winter when there
are large expanses of snow that you can't do a forced approach on. Will
guys who have the skis use them not in forced approaches?? I'd sure hope so.
What happens if you land on a runway with your skis lowered (retractable)...
You go out and buy another set of basses for your skis... You won't be
taking off again unless there is a lot of snow on the runway..
Noel
Kitfox III-A
Float Flyr
Posted: Thu Mar 27, 2008 10:01 am Post subject: skis |
To get the most heat out of a liquid cooling system you need to be able to divert coolant from the radiator to the heater, just as is done in cars. This means another special valve and re-plumbing the cooling system. When that is done there is obviously less cooling area in operation so even in winter the coolant will achieve hotter temperatures and you will get much hotter temperatures in your cockpit. I expect without a thermostat you will be taking a chance on cold shocking your engine if you turn off the interior heat while in flight. Even with a thermostat I’d operate that heat control very slowly, keeping an eye on the temperature gauge. Also put the control on the left side of the cockpit so a passenger won’t have access to it
You can also try plumbing your heater in series with the radiator that way the hottest water, leaving the engine will pass through your heater core before the radiator. Doing that will save weight but you won’t have any control over the heat other than the fan. It will allow the whole system to operate more efficiently but in the summer, more sq inches of radiator in operation, but you may want to fly with the doors left back on the ground.
Noel Loveys
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Guy Buchanan
Sent: Thursday, March 27, 2008 2:33 AM
Guy Buchanan
San Diego, CA
K-IV 1200 / 582-C / Warp / 100% done, thanks mostly to Bob Ducar. | Quote: | | http://www.matronics.com/Navigator?Kitfox-List | 0123456789
7.29 KB |
14322 Time(s) |
Kitfox III-A
