George McNutt
Posted: Sun Feb 26, 2006 10:57 pm Post subject: Fuel tank bulletin |
Hi Donald
Thanks for sharing that information.
Reading about pipe flares today and found that over tightening can cause
damage to the tube possibly causing failure, also cracks and deformities
in a flare are not acceptable.
Two questions for you - did the investigation find that the AN 818 nut
came completely off the bulkhead fitting allowing the pickup tube to
drop off, or had the nut just loosened allowing the fuel pump to suck air?
Was there any previous symptom of a fuel flow problem?
George in Langley BC
There have been at least 2 accidents due to the loose flare nut fitting. I
totaled my RV-6 31/2 years ago due to this problem. There was 6.5 gallons
left in the tank, not 3.5. I informed Vans about it and never received a
reply. There was a short note in the RVator 2-3 years ago addressing this
problem. It was done by a contributor, not Van's staff. I prosealed the nuts
on my current RV-9.
Don Piermattei
RV-9 90411
Ed Anderson
Posted: Mon Feb 27, 2006 5:01 am Post subject: Fuel tank bulletin |
Yes, when I informed them of my finding the Flop Tube having fallen off -
they really did not seem interested. I presume this comes from the fact
that there are hundreds/thousands of Rv's who have never had the problem (at
least - not yet). Did you have extended fuel capacity in your Rv-6? I
drained the tank immediately after the incident (within 30 minutes) and the
fuel remaining was 3.5 gallons in my case (Rv-6A).
Ed
Ed Anderson
Rv-6A N494BW Rotary Powered
Matthews, NC
eanderson(at)carolina.rr.com
<dlpier(at)lamar.colostate.edu>
I
nuts
on my current RV-9.
Don Piermattei
RV-9 90411
Donald L. Piermattei DVM, PhD
5000 E County Rd 92
Carr, CO 80612
970/568-9047
Fax 970/568-7279
_________________ Ed Anderson
Matthews, NC
eanderson@carolina.rr.com |
khorton01(at)rogers.com Guest
Posted: Mon Feb 27, 2006 10:58 am Post subject: Fuel tank bulletin |
The flare nut for the regular fuel pickup is higher than the one for
the inverted fuel pickup. So it is reasonable to assume that fuel
remaining after the failure would be greater.
Kevin Horton
On 27 Feb 2006, at 07:41, Ed Anderson wrote:
<eanderson(at)carolina.rr.com>
fallen off -
fact
problem (at
Rv-6? I
and the
Ed
Ed Anderson
Matthews, NC
> fitting.
> I
> gallons
> received a
> addressing this
> prosealed the
> nuts
> on my current RV-9.
> Don Piermattei
> RV-9 90411
dlpier(at)lamar.colostate Guest
Posted: Mon Feb 27, 2006 11:44 am Post subject: Fuel tank bulletin |
Hi Donald
damage to the tube possibly causing failure, also cracks and deformities in a
Two questions for you - did the investigation find that the AN 818 nut came
completely off the bulkhead fitting allowing the pickup tube to drop off, or
The pick up tube was completely loose. There were no previous indications as I
apparently had never let that tank get that low in 175 hours of operation.
5000 E County Rd 92
Carr, CO 80612
970/568-9047
Fax 970/568-7279
