Powerplant Choices
Goto page Previous  1, 2
planecrazydld(at)yahoo.co
PostPosted: Mon Nov 12, 2007 1:01 pm    Post subject: Powerplant Choices Reply with quote
seems like it might make it harder to ham-hand as well.
ashontz <ashontz(at)nbme.org> wrote: [quote]--> Zenith-List message posted by: "ashontz"
Does 20hp really make that much of a difference? The 601HD was originally designed for 65hp if I'm not mistaken.
I've heard that it takes 25% more power to go 10% faster. Personally, I'd guess that an 80hp engine, even on a 601XL is sufficient.
Just an analogy here. I used to have a 18' aluminum starcraft boat. Originally it had a 140hp engine on it, It did about 48mph with that arrangement, maybe 50 tops. I took that off and mounted a 70hp evinrude. With the 70hp engine, the boat went a solid 36mph, or about a 25% reduction in speed for a 50% reduction in power, there was no major noticable difference in getting it up on plane either. From everything everyone is [quote][b]
d.goddard(at)ns.sympatico
PostPosted: Mon Nov 12, 2007 1:18 pm    Post subject: Powerplant Choices Reply with quote
An 80 HP 912 should be more than enough. That doesn't mean it's enough for
everyone, there is a LARGE segment of aviation who adhere to the more is
always better philosophy. IF they could mount 200hp on a 601, they would. My
old BMW motorcycle has a thirty something HP engine, the same frame was
available with engines up to 2/3 larger. There are a lot of people trying to
extract more HP from that larger engine in the belief that they don't have
enough power. If you simply want to fly a relaxing and enjoyable plane 80 is
enough, if you want to hit pattern altitude before you have used up a 1000
ft runway, you'll need more.
zodierocket(at)hsfx.ca
PostPosted: Mon Nov 12, 2007 4:33 pm    Post subject: Powerplant Choices Reply with quote
I love this conversation, when is enough , enough? Well never, but when
is enough adequate, that is the question. Lets look at the 701 she will
happily put along on 60hp shes will have adequate stol performance and
cruise at an appreciable 70 mph. But no one installs a 582 anymore,
everyone installs a Rotax 912, this is a great performer and your plane
will cruise at a robust 90 mph with some clean up, stol performance will
be enviable to everyone. If you are buying a used 912 and getting a
great deal then you have the perfect engine, but if your buying new then
the 912S is typically only $1,500 dollars more. SO for that extra cash
which in the whole cost isn't that much, you have a plane that can
cruise at 95-105 mph, STOL is sickening to anyone's stomach and it
climbs vertically. DO we need this? Not for most of us, but lets look at
the 100 deg day at 5000 ft strip. Would the engine that didn't cost much
extra, uses little more in fuel burn and weighs the same as the lower hp
motor not make more sense? 20 hp makes a big difference if it isn't a
big difference in the pocket book. Now lets look at the 914, here is
another 15 hp above the 912S we cannot cruise any faster because we are
already close to Vne we won't notice the climb rate unless we are at
high altitude. Plus the engine is $14,000 more then the 100hp this is
the value that does not make sense. The engine will not do anything more
for us, but it will cost us a hell of a lot more. We will not realize
value for performance. Both the 912 and 912S are capable of the same
slow flight cost is of little difference when new, so in this case the
extra 20 hp are desirable.
In the 601HD she will happily put along on 70hp, but at that fly-in that
you landed at first thing this morning and the heat when crazy will I
have enough runway to take off? Having more HP is not just for flying
faster, it is for the ability to use the resources we want to. A short
strip on a very hot day may be too much for a low powered plane. That
extra 20hp may make the difference. The problem is to know when airframe
gain is eclipsed by pocketbook drain.
IF you can afford a 70 hp motor, but the 90 hp is less then a couple
thousand it is sometimes better to wait that little extra, remember your
going to have this plane a long time as a rule. But if were looking at a
huge difference in cost then 70 hp is adequate and you will still have a
fun plane. Though you will also be aware that some runways and
situations may not be advisable for you. Heat and altitude conditions
are more critical.
There is always a limit. More is not always better, but if it is within
reason to costs and airframe then more may be desirable.
When it comes down to a Rotax 912 over the 912S, in Canada the cost
difference is less then $1,500.00 for this amount I can never recommend
the straight 912 unless you are able to find a half time one for a good
cost. Only then do you have a reasonable value for HP output.
Look over your options, Look over your abilities, look at your mission.
These things will dictate which each of us will desire, not the other
fellow that may fly a different mission.
Mark Townsend
Can-Zac Aviation Ltd.
president(at)can-zacaviation.com
www.can-zacaviation.com
zenith601xl(at)gmail.com
PostPosted: Tue Nov 13, 2007 6:00 am    Post subject: Powerplant Choices Reply with quote
There is one advantage for the 912 over the S. It runs on regular
auto gas, the S needs premium, so the cost of operation is less. I am
building a 601XL with Jabiru 3300 so the whole discussion is academic
but interesting.
Dennis Shoup
N601JJ
are more critical.
Mark Townsend
Page 2 of 2
