Pre Cover and Finish Thoughts?
Goto page Previous  1, 2
smokey_bear_40220(at)yaho
PostPosted: Sat Jun 30, 2007 7:49 pm    Post subject: Pre Cover and Finish Thoughts? Reply with quote
--- fox5flyer(at)idealwifi.net wrote:
Kurt, I believe the Gray Ghost was our late Mike
Harter with a Model IV/Subaru who lost his life out
west several years ago when he got trapped in a
canyon he couldn't climb out of.
Somebody please correct me if I'm wrong about this.
Deke
S5/NSI Subaru/CAP
Northeast Michigan
That's the one Deke. I was trying not to go any
further with the Ghost name than to tie it to the
color and sound. Mike was always a likeable guy. We
have lost too many from this list already and being
seen is just another way to be a little safer.
I painted my 5 white with red and maroon trim.
I also left the flapperons polished aluminum to flash
in the sun and put mirrored tint on the overhead
glass. Nothing beats a sun reflection.
Kurt Schrader
S-5 NSI turbo
Florida and Panama
Be a better Heartthrob. Get better relationship answers from someone who knows. Yahoo! Answers - Check it out.
http://answers.yahoo.com/dir/?link=list&sid=396545433
Guy Buchanan
PostPosted: Sat Jun 30, 2007 7:54 pm    Post subject: Pre Cover and Finish Thoughts? Reply with quote
At 01:00 PM 6/29/2007, you wrote:
Are there any, &(^%(&^%., I wish I had done
that before I covered, items I need to make sure I have done.
I built a baggage compartment in a completed IV. I also installed all
the electrical, hydraulics, firewall penetrations, much of the
pitot/static, and much of the firewall forward detailing. I sure wish
it had all been done before covering. This lead me to think that,
were I to build from scratch I would complete the plane, 100%, prior
to covering, then disassemble, cover, and paint. More work, but a
much better product. For example:
Fair in the aft edge of the cowl shell.
Weld tabs for the baggage compartment.
Weld structure for electrical components. (E.g. support structure.)
Modify the instrument panel attachments for easy access to the back
side. (E.g. hinges, etc.)
Degauss the forward structure so the compass works perfectly.
Check the avionics, radios, and transponder with the engine running
and re-run any noisy wires.
Add upholstery tabs.
Use blind nuts wherever access is covered. (Already mentioned but so
important as to be mentioned again.)
Weld exhaust supports. (Try to get rid of as many Adel clamps as
possible, everywhere.)
Perfect the cooling system.
Sexy gap seals on elevator and rudder.
The list goes on and on.
Note, however, that you do have to be careful with this method. Some
structure will change when covered. The inboard most ribs, if not
supported adequately, will bow away from the fuselage when the
fabric's tensioned. Buildups on the inboard rib and butt rib can
cause interference if they were closely spaced to begin with. Sloppy
fabric termination can interfere with the wing tips. Fuselage tubes
can bow in, modifying internal structure such as baggage
compartments. (Supports should always be at tube junctions, anyway.)
I give up. . .
Guy Buchanan
San Diego, CA
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
PostPosted: Sat Jun 30, 2007 8:08 pm    Post subject: Pre Cover and Finish Thoughts? Reply with quote
Lowell and Kurt, I think I read somewhere that the US
air force has
decided that black was the best visible colour for an
aircraft during
daytime. Can you confirm that or have I just been
dreaming?
Michel Verheughe
Norway
Kitfox 3 - Jabiru 2200
The best color depends upon where you want to be seen,
or not seen. I always thought it was funny when our
airforce painted their planes green. Didn't they
expect to be flying when trouble came? Now many are
gray, but some are black. I think the black is for
radiation absorption against IR weapons, better hiding
at night and better hiding up high. But I think they
stand out when looking down on them in daylight.
Years ago before the KitFox was introduced, I was
considering another plane and wanted to paint it green
and brown. Looked good on trees! Then I thought
about how anyone would find me if I went down in the
trees.
I once saw an army helo with one white blade and one
black blade on top. You couldn't miss it from above!
Your mind knows it can't fly with one blade and you
are immediately drawn to it. I was impressed with how
well it stood out even from miles away. Still
couldn't bring myself to paint one wing white and the
other black....
Kurt Schrader
S-5 NSI/turbo
Florida and Panama
Shape Yahoo! in your own image. Join our Network Research Panel today! http://surveylink.yahoo.com/gmrs/yahoo_panel_invite.asp?a=7
Float Flyr
PostPosted: Sun Jul 01, 2007 5:01 am    Post subject: Pre Cover and Finish Thoughts? Reply with quote
I've been following this thread with a bit of interest. What I get is simply, see and be seen.
Lowell had made a lot of practical observations in paint schemes. The use of the colour black was mentioned that it could cause the top of the wing to change shape (due to shrinkage) on a hot summer day.
My own plane is white with, would you believe it, navy blue and Day-glo orange stripes. The very first time I saw it I thought to myself if it ever goes down it will be easy to find even in snow. The guy who built the plane had a number of other aircraft over the years most of which had very similar paint schemes. One thing to keep in consideration if going with the Day-Glo is it will fade pretty quickly.
Thanks to whoever started the discussion on colours.
I'm going to include a couple of reduced pics of the plane which only flies day VFR.
[img]cid:400545812(at)01072007-29BF[/img]
[img]cid:400545812(at)01072007-29C6[/img]
Noel
[quote] --
 Filesize:  27.13 KB
 Viewed:  468 Time(s)
 Filesize:  53.29 KB
 Viewed:  507 Time(s)
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
fly2wb(at)dishmail.net
PostPosted: Sun Jul 01, 2007 5:27 am    Post subject: Pre Cover and Finish Thoughts? Reply with quote
Would you happen to be going to Oshkosh Andy? They have a great covering
class that includes a seminar that explains the process in detail with
many tips to get your plane finished. Then they will take you over to the
workshop were you will be able to cover a rudder complete with tapes.
I actually went through the class twice and went home with a newfound
confidence---it was easy!
Brad
Wichita Kansas
5--Lyc 0-235
Thanks guys for the many comments and suggestions you have offered. I
THINK
I have done about all I can do in preparation for the covering process. I
have one more wire to run and everything I can think of has at least been
prefit and removed or left in place if it won't interfere with the
covering.
I do believe I have about run out of excuses to go ahead and get it done.
If anything else comes to mind I'm still listening. Thanks again.
Andy Fultz
Michel
PostPosted: Sun Jul 01, 2007 2:03 pm    Post subject: Pre Cover and Finish Thoughts? Reply with quote
On Jul 1, 2007, at 2:30 AM, Lowell Fitt wrote:
When flying in a group some sort of second color highlight is helpful.
You have a lot more experience in formation flying than me, Lowell, so
your comment on this would be most appreciated:
From the little experience I have in re-grouping in the sky, and
together with my fellow pilots in the club, we have found out that if a
meeting is arranged, one aircraft has to turn around a known
geographical feature 500 feet above the other. It is then the lowest
plane that has to spot the highest one and manoeuvre to come behind
him. The reason being: It is much easier to see an aircraft against the
sky than against the ground. Do you agree or do you know of another
procedure?
This was again proved to me today when I flew with another aircraft to
a nearby airfield. Since the other aircraft was an instructor with a
student, they wanted to do a few touch and go before leaving for the
return journey. I was to take off when they were on the downwind leg of
their last traffic pattern; we were to fly to the reporting point
exiting the airfield CTR zone go go further in G zone. Since I was
ahead of the other guy, I flew slow to give him a chance to catch up.
As we arrived at the reporting point, I saw him passing maybe 200 feet
above me and ... he never saw me! Once on a unicom frequency, he called
me to ask where I was and I answered: Behind you!
Okay, my colours are silver and dark blue with red nose and red wing
tips. But he didn't see me on the background of the Norwegian forested
mountains.
Michel Verheughe
Norway
lcfitt(at)sbcglobal.net
PostPosted: Sun Jul 01, 2007 4:40 pm    Post subject: Pre Cover and Finish Thoughts? Reply with quote
Michel, Your exerience is frequent in our group also. Sometimes it takes
some time to form up again after a long segment of flying. We will often
pick ground features to offer position reports. Sometimes it is a quick
find and other times it still takes a while. What is the most likely
scenerio with our flights is that most will fly in visual contact with at
least one other airplane. Often that airplane is in visual with another and
so on. But on occasion when preparing to land as a flight of ##, we have to
consciously reform the group and it is often a challenge. Occasionally the
airplane determined to be the lead airplane will do a steep 360 to show the
motion and broad wing surfaces. I would think that the plan you use -
forming up on the higher airplane - generally wouldn't work for us, because
more times than not, the lead airplanes are down way low which adds to the
challenge of being seen. I have had occasion to following barn roofs in
hilly country thinking that the glare from the roof is the glare from the
top of a wing.
One thing that is important in group flying is ensuring all the airplanes in
the group have their altimiters set to the same barometric pressure. It is
comforting having the unaccouted for airplane at a differnt altitude,
especially when both are reporting over the intersection of the two roads or
over the south shoreline of the lake.
We do talk a lot to each other. One quote from a recent trip. Ken,
"There's nothing down there." Mark, "What are you looking for?" Ken,
"Nothing." Mark, "Then you've found it." Ken, "Yeah, I know, it's down on
my left."
Lowell Fitt
Cameron Park, CA
Model IV-1200 R-912 UL Warp
1998 850 hrs.
kitfoxmike
PostPosted: Sun Jul 01, 2007 4:40 pm    Post subject: Re: Pre Cover and Finish Thoughts? Reply with quote
I want to say that there is no reason for a fox to get trapped in a cove. It will do a 90degree banking turn that will absolutely pull your eyes out and turn you on a dime. Next you can pull up slightly and hit full rudder and with aileron and do a hammer head wing over. I practice both of these and can tell you, at least with a 4, it can be done. I've also used it for a turn back after the engine went to less than 50 percent. I wouldn't do this if you don't know the fox though. Put at least 300 hrs on it before even attempting to try it, and at altitude. I learned the hammer when at a mountain flying class, guy had 20000 hrs, and in a cessna at that.
Lynn Matteson
PostPosted: Sun Jul 01, 2007 5:17 pm    Post subject: Pre Cover and Finish Thoughts? Reply with quote
Andy-
I had another thought about applying the masking tapes...get the
plastic fine-line tapes from your local auto paint store. When using
them don't pull to stretch them, just pull them taut. Use them for
where you are going to have a stripe, or wherever there is a change
of color. Once the fine line tape is down, you can use regular
masking tape (good quality) for applying the masking paper...NOT
newspaper (it bleeds the color through sometimes, because it is
porous)...to the fine line tape. And whenever one tape crosses
another, make SURE you use your fingernail to *absolutely* make sure
that the crossing tape is tight up to the underlying tape, or you'll
get a "blow-under" of paint which you will see when the tape is
removed. Even if you don't have one tape crossing another, this can
happen even where the tape crosses your false ribs, or other hard
edges, and even your finishing tapes. One of my wings shows some of
this behavior, but I got better when I did the second wing.
Lynn Matteson
Grass Lake, Michigan
flying w/350+ hrs
On Jun 30, 2007, at 3:07 PM, Andy Fultz wrote:
<andynfultz(at)bellsouth.net>
offered. I THINK
process. I
least been
covering.
done.
Andy Fultz
Lynn
Kitfox IV-Jabiru 2200
N369LM
Lynn Matteson
PostPosted: Sun Jul 01, 2007 5:28 pm    Post subject: Pre Cover and Finish Thoughts? Reply with quote
Kurt's comments reminded me of something else...make sure that you
put a reinforcing "doily" wherever there is something that might rub
or touch a part of the aircraft. I put one where the attaching nuts
and cotter pins for the flaperon mechanism comes close to touching
the fabric behind the door openings on the sides of the fuselage. I
also put one over the fabric where the wing tank quick-drains were...
(I chose not to use the drains, and rely on my header tank for
sumping the fuel for any moisture (haven't found any yet) ). On my
recent trip to CA and back, I noticed that the vibration had worn a
hole through the fabric AND the doily anyway, so I've got a repair to
do.
Lynn Matteson
flying w/350+ hrs
On Jun 30, 2007, at 4:47 PM, kurt schrader wrote:
<smokey_bear_40220(at)yahoo.com>
--- Andy Fultz <andynfultz(at)bellsouth.net> wrote:
> Good afternoon guys. I'm about to embark on what I
> hope to be the final big
> step in the build process. I THINK I'm ready to
> cover and paint my project.......
> Andy Fultz
Hi Andy,
Don't know the particulars of your plane, but make
sure you provide access to everything for maintenance
before you cover.
On my S-5 I missed using blind nuts on a few places
like the baggage floor and rudder peddle mounts. Much
harder to work on once covered. To remove the rudder
peddles, I needed to remove the firewall and
everything on it! Check for stuff like that first.
Not everything is best done by the plans.
Kurt S.
S-5/NSI turbo
Lynn
N369LM
7suds(at)Chartermi.net
PostPosted: Mon Jul 02, 2007 7:12 am    Post subject: Pre Cover and Finish Thoughts? Reply with quote
Andy,
Lynn's comments below reminded me of another painting tip, after you have
taped for your second color shoot the edges of the tape with the base color
first, then if there is "blow-under" it will be the same color and will seal
the holes and edges so when you shoot the 2nd color it will not creep under
the tape. It works, I have used this method.
Lloyd
Model 4 built-flown-sold
Model 5 building 912
UP of Mi
(do not archive)
Float Flyr
PostPosted: Mon Jul 02, 2007 9:26 am    Post subject: Pre Cover and Finish Thoughts? Reply with quote
Next thing to a friket, Eh, Lynn.
Sorry.... One day after Canada day and I still haven't got the Eh out Smile
Noel
[quote] --
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
occom
PostPosted: Mon Jul 02, 2007 12:13 pm    Post subject: Pre Cover and Finish Thoughts? Reply with quote
I'd love to stomp all over this stupid EH thing. I was born in Canada, have
lived here for 54 years and have probably met two people who say EH, at the
end of a sentence. Lets not create anymore stereotypes.
Dave Goddard- Mod IV 1050/582
PostPosted: Mon Jul 02, 2007 2:35 pm    Post subject: Pre Cover and Finish Thoughts? Reply with quote
get trapped in a cove. It will do a 90 degree
and turn you on a dime..........
though....
kitfoxmike
model IV, 1200
speedster
912ul
Just to add on to Mike's comment, it pays to get some
aerobatic, gliding and IFR training under your belt.
You don't have to qualify at them, but get enough
training to be comfortable when exiting a bad
situation.
And you may learn your personal limitations better
making you take the exit strategy sooner rather than
too late. Once you know you are not too good at
hammerhead turns or staying upright in a cloud, you
know better not to go there.
"A man's got to know his limitations."
Kurt Schrader
S-5/NSI turbo
Florida and Panama
Get the Yahoo! toolbar and be alerted to new email wherever you're surfing.
http://new.toolbar.yahoo.com/toolbar/features/mail/index.php
PostPosted: Mon Jul 02, 2007 2:42 pm    Post subject: Pre Cover and Finish Thoughts? Reply with quote
Another one for you Andy,
If you have wires, pitot lines, etc that you have
fastened to the inside of the tubes that will be
against the fabric, don't use plastic ties to hold the
wires. They rub the fabric and the plastic gets
brittle over time and fails.
Instead use stitching line, or pinked tape wrapped and
glued around the tube. I tried all 3 and like the
tape wrap better for saving the fabric touching it.
They just glue together and don't rub at all.
Kurt Schrader
S-5/NSI turbo
Florida and Panama
Got a little couch potato?
Check out fun summer activities for kids.
http://search.yahoo.com/search?fr=oni_on_mail&p=summer+activities+for+kids&cs=bz
Page 2 of 2
