rene(at)felker.com Guest
Posted: Tue Sep 06, 2016 2:11 pm Post subject: AOG in Michigan |
Things I have used......
Large screw driver boooooo
Large rubber mallet, not bad
Large "C" clamp with small mallet, better
I am overweight and tried jumping on it.....never worked, but was
entertaining.
Rene'
801-721-6080
wgreenley
Joined: 09 Jan 2010 Posts: 100 Location: Dowagiac, MI
For my tractor I have had to drive onto the tire with another tractor to break the bead. Works well.
On Tue, Sep 6, 2016 at 5:57 PM, Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)> wrote:
| Quote: | --> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)>
The beads can get very stuck. I have had times when I could stand on the tire and pop it but after a couple of rough ones I looked at bead breakers online and then built one. I used it in Michigan...yesterday the bead was stuck pretty well.
http://www.myrv10.com/tips/tools/Bead_Breaker/index.html
There's a write up with pics.
Tim
> On Sep 6, 2016, at 4:45 PM, Linn Walters <flying-nut(at)cfl.rr.com (flying-nut(at)cfl.rr.com)> wrote:
> --> RV10-List message posted by: Linn Walters <flying-nut(at)cfl.rr.com (flying-nut(at)cfl.rr.com)>
> If you talc the rims and the tire bead the bead will come off with ease. Standing on the tire might work but if they're relly stuck, (and I hate this but it works) insert a large screwdriver between the tire bead and the wheel rim. Pry towards the tire or you might pry a chunk out of the wheel rim. I also have a large vise that I can put the tire in to squeeze the beads together. Whatever works for you. Prevention with the talc is the best method I use.
> Linn
>> On 9/6/2016 12:17 PM, hotwheels wrote:
>> --> RV10-List message posted by: "hotwheels" <jaybrinkmeyer(at)yahoo.com (jaybrinkmeyer(at)yahoo.com)>
>> Good timing on this post. I've serviced wheels as part of annual this past weekend. I'd not balanced the wheels in the past and all three required balancing. One less mystery causing occasional shimmy during landings. I was unable to split the wheels to rotate main tires. Tim mentioned using a bead breaker but I don't recall using one last time when I was able to get the two sides apart. What do others do to split their wheels?
>> Cheers,
>> Jay
>> N433RV - it's not painted but it flies!
>> http://forums.matronics.com/viewtopic.php?p=460304#460304
WIKI -
gspecketer(at)hotmail.com Guest
Posted: Tue Sep 06, 2016 2:27 pm Post subject: AOG in Michigan |
Lower your hanger door on a block of wood placed on the tire next to the bead
Gary Specketer
entertaining.
Rene'
801-721-6080
