flier(at)sbcglobal.net Guest
Posted: Fri Oct 20, 2006 12:56 am Post subject: Cargo pods.... |
Ok, I got you. You've apparently got a custom scoop. The pod mount is made
such that the rear mount is captive while the front mount 'rocks' on the two
eyebolts to give some play when attaching the pod. Don't know exactly where
your radiator is but you might be able to use the brackets -- just through
the scoop if you don't want to go all the way to building custom brackets.
Five holes through the scoop with the brackets inside? Depends on the depth
of the scoop.
Ted
cliffh(at)outdrs.net Guest
Posted: Fri Oct 20, 2006 5:53 am Post subject: Cargo pods.... |
When I open the door on the back of the scoop and look inside, there are no
attachment visible. From where the front brackets would attach, I would have
to remove the scoop to get to the bottom of the airframe.
Floran H.
FLIER(at)sbcglobal.net Guest
Posted: Fri Oct 20, 2006 7:10 am Post subject: Cargo pods.... |
I'm not sure if you built or purchased your Fox
Floran but someone else may have removed those tab
weldments before covering thinking they'd never use
them -- particularly since the extended scoop was
added.
--- Original Message ---
Subject: Re: Cargo pods....
<cliffh(at)outdrs.net>
| Quote: | attachment visible. From where the front brackets
| Quote: | to remove the scoop to get to the bottom of the
airframe.
Floran H.
