smokey_bear_40220(at)yaho Guest
dan(at)azshowersolutions. Guest
Posted: Mon Jun 26, 2006 7:37 pm Post subject: The "Claw" tie down |
Randy,
The first post of this thread indicated 3 out of 7 planes that were using the Claw failed. Significant in my book...however, in reading all of these posts one can get a flavor for what works...etc. The nature of the ground plays a big part.
Dan
Randy Daughenbaugh <rjdaugh(at)rapidnet.com> wrote:
| Quote: | David, (Or others),
The data point that is missing here is how many planes were tied down with the Claw? If there were three, the failure rate was 100%. If there were 6 the failure rate drops to 50% - Still not good! If over half the planes there were using the “Claw”, the failure rate drops to a much more reasonable 3%.
Because the claw is relatively new, I suspect that not very many were using it. Can anybody provide some insight here? My first impression of the claw, based on advertisements, was good. But I think I like Lowell’s design better.
Sorry to be so late coming to this thread.
Randy
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of David McCormick
Sent: Sunday, June 25, 2006 12:17 PM
Subject: The "Claw" tie down
On Thursday at the Sentemental Journey Fly-In at LockHaven, Pennsylvania ( LHV ) we had a severe thunderstorm and at the time there were around 180 lite aircraft tied down on the airfield. 3 of the 7 airplanes that had damaged were tied down with the " Claw " One of the claw arms that was holding a J-3 Cub broke, and the other calw tiedowns came out of the ground. Mabee I was just lucky but my Kitfox was tied down with screw in type tie downs.
clemwehner(at)sbcglobal.n Guest
Posted: Mon Jun 26, 2006 9:18 pm Post subject: The "Claw" tie down |
Here's something to think about. Consider how much lift our wings can produce. In a 40 mph wind the wings can easily generate 600 lbs of lift, likely a lot more if the angle of attack is high, or the winds are higher.
I remember when I was a USAF C-141 pilot (4-engine jet transport). At our base here in Oklahoma with storms coming with expected straight line winds of 85-90 mph, maintenance tied down each aircraft with six 10,000 lb strength tie-down chains, thinking that should do it. The winds came and some of the aircraft snapped all the chains and got moved around the ramp. In retrospect, the C-141 rotates at 90 knots and lifts off at a little over 100. At that speed it can lift 160,000 lbs of it's own weight and almost 200,000 lbs of cargo. So 60,000 lbs of chain strength wasn't even close to enough.
If the wind direction is from the aircraft's front, the wings can generate an enormous amount of lift, even in a Kitfox. Imagine how much lift could be generated with 60-70 MPH winds across the wings at the high angle of attack presented to the wind when the tail is on the ground.
Might take a LOT of stakes in the ground and some hefty rope!
Clem
Lawton, OK
KFIV-912
janderson412(at)hotmail.c Guest
Posted: Tue Jun 27, 2006 12:01 am Post subject: The "Claw" tie down |
Tape a 2x4 to the top of the wings...kill that lift..someone mentioned this some time back. ~j~
[quote] Here's something to think about. Consider how much lift our wings can produce. In a 40 mph wind the wings can easily generate 600 lbs of lift, likely a lot more if the angle of attack is high, or the winds are higher.
Clem
Lawton, OK
KFIV-912
dave(at)cfisher.com Guest
Posted: Tue Jun 27, 2006 3:03 am Post subject: The "Claw" tie down |
Hey guys,
I did a little search for these items that are talked about and here they
are.
http://www.airtimemfg.com/
The "Kit" (recommended) is $10 more ($90.00) (plus $5 shipping) (kits
consist of the "set", plus three 5/16" high quality 8' ropes, and a storage
bag
The Claw
http://www.tagpilotsupply.com/index.asp?PageAction=VIEWPROD&ProdID=940
$92.97
a.. Compact storage bag and contents weigh only 8 pounds
a.. These Airplane Tie Downs Anchor System includes: Bag that is easy to
carry and store that contains: 3 Anchors; 9 spikes; 1 hammer; 20-ft rope
Now here is what some use on the grass strip here, these are very simular to
the ones we buy at our local farm store for about 5$ each.
http://www.karlkuemmerling.com/prod15.htm
That chart should holding power of up to 4000 lbs each. I think if one was
to use a lighter material llike Titanium or the 5052 alum that might be an
option ? even a better option for us float flyers is too beach your plane
and fill the floats with water.
The screw in ones like for dogs etc I think just break off to easy although
better than nothing. I would suggest that the end be welded so that it
cannot stretch out the triangular handle. Plus i have seen them pull out of
ground when it gets wet as they only sink in about a foot or so.
I think someone mentioned the 2 x 4 on wing. I have done that and that
works well but you cannot always have 2x 4s in your fox unless you stap then
on top of your floats
Dave
noelloveys(at)yahoo.ca Guest
Posted: Tue Jun 27, 2006 4:16 am Post subject: The "Claw" tie down |
I think there is something here I'm missing. With the kitfox why not just
fold the wings and wrap the plane in a light weight tarp?? Would be
cheaper for the field too.
Noel
[quote] --
lcfitt(at)sbcglobal.net Guest
Posted: Tue Jun 27, 2006 5:51 am Post subject: The "Claw" tie down |
Kurt,
I always check the tent stakes at REI when I am there. They are light
weight, but usually only 8 or so inches long. That has never satisfied me
enough to try them.
Lowell
Posted: Tue Jun 27, 2006 5:59 am Post subject: The "Claw" tie down |
Clem,
This is good insight. It is my understanding that many Alaska pilots will
tie down the wings and allow the tail to fly - essentially reducing lift. I
don't know how they anticipate the wind direction, though.
Lowell
Posted: Tue Jun 27, 2006 6:40 am Post subject: The "Claw" tie down |
Lowell,
That's an interesting twist concerning the Alaska pilots. If that's true, I guess they are figuring it's easier to replace the empenage vs. the wings? Common sence to me says tie the thing down tight all the way around. This has been a good thread to establish things that may or may not work...personally I will take many of the suggestions and draw my own conclusions (as we all should), but to leave the tail flopping in the breeze???
Dan
Lowell Fitt <lcfitt(at)sbcglobal.net> wrote:
[quote]--> Kitfox-List message posted by: "Lowell Fitt"
Clem,
Lowell
Posted: Tue Jun 27, 2006 6:42 am Post subject: The "Claw" tie down |
Lots of good ideas and sources coming out!
I don't have any for my plane yet, so I am interested
too. My cargo straps double as tiedowns at airports
that have rings installed. Haven't left it out at any
others yet to need my own stakes. These straps are
not really sufficient for this anyway. No load rating
on them. Maybe 700-1000 lbs each. Just what I have
for now.
I had a screw in type used for tying down mobile homes
years ago. Used it for my german shepard. He bent it
right over on a side pull. These are only good for
straight pulls like the tree stakes from the farm
place. Some require side pull (with nails) and others
require straight pull (screw in).
Some farm types are never meant to be removed - be
careful.
Seems you almost need 2 different sets to handle the
soil types, soft or hard.
I saw a ship in Adak Alaska break twenty 8" ropes in a
strong wind once..... They had off loaded and were
high in the water. Imagine the force required to
break even one 8" line.
Like the 141's mentioned, we can generate a good deal
of lift in normal storm winds. An empty Fox might
lift off at 20-25 knots for you light builders.
Especially the taildraggers. Any wind above enough to
lift the weight is all against the ropes. Don't have
my calculator here, but enough wind to give you 3 G's
in a turn would put 2 G's worth on the ropes. That
could be 2-3000 lbs for us.
The wing wedges would help. 2x4's are hard to carry,
unless you use them when home.
I wonder if inflatable wedges tied to the wings every
2 feet would kill enough lift to make a good product?
If the wind is from the rear, your wing struts better
be stiff. Some in the north use 2x4's to brace the
struts for snow/wind loads.
We CAP prop guys have to tie down the prop too.
Anyone with a clutch that lets it free wheel has to.
Seat belts on the controls too?
Still listening.... So far I like the "airtime" ones
or some of your homebuilts better.
Kurt S. S-5/NSI turbo
--- Dave <dave(at)cfisher.com> wrote:
| Quote: | $92.97
pounds
Bag that is easy to
each.
welded so that it
foot or so.
Dave
Posted: Tue Jun 27, 2006 6:49 am Post subject: The "Claw" tie down |
Thanks Lowell! I thought maybe the bigger tents might
do, but never looked for that purpose. Trying to save
a $ ya' know. Doesn't help if you have to buy 20 of
them and a lot of rope....
Kurt S.
--- Lowell Fitt <lcfitt(at)sbcglobal.net> wrote:
| Quote: | Kurt,
has never satisfied me enough to try them.
Lowell
Posted: Tue Jun 27, 2006 6:59 am Post subject: The "Claw" tie down |
I agree - good point.
And the wind can change 135 degrees with frontal
passage, so how do they know?
Oh, ask the eskimos..... The dogs lay down.....
I'd put a long rope on the tail and not let it get
above level myself. Then carry a replacement tail
spring???
ponder, ponder.... Still learning.
And ducking. I am in Brazil. 5 minutes to the big
football game. Horns. Fireworks. Everything shuts
down. Everything! BANG! No sleep for night flyers.
Kurt S.
| Quote: | Clem,
though.
Lowell
rjdaugh(at)rapidnet.com Guest
Posted: Tue Jun 27, 2006 8:33 am Post subject: The "Claw" tie down |
Dan,
That is not the way I read it. David said, (I paste here) “3 of the 7 airplanes that had damaged were tied down with the " Claw "” He doesn’t say how many planes on the field were using the “Claw”.
I don’t believe we yet have any data on the failure rate.
Randy
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Dan Billingsley
Sent: Monday, June 26, 2006 9:37 PM
Subject: RE: The "Claw" tie down
Randy,
Dan
David, (Or others),
Randy
Posted: Tue Jun 27, 2006 9:46 am Post subject: The "Claw" tie down |
Randy,
Perhaps I'm not following what data you are looking for...the whole field? I was simply indicating from the sample of 7 planes we were given.
Dan
| Quote: | Dan,
Randy
Randy,
Dan
Randy
morid(at)northland.lib.mi Guest
Posted: Tue Jun 27, 2006 10:28 am Post subject: The "Claw" tie down |
Randy's probably right. However, the "Claw" people make some pretty boastful claims about their product and I would think that with that, none of them should have pulled out. However, that aside, my biggest balk on them is the weight. Eight pounds is a lot of dead weight to carry around when I'm usually trying to save ounces on other things.
Deke
>From: Randy Daughenbaugh (rjdaugh(at)rapidnet.com)
| Quote: | Sent: Tuesday, June 27, 2006 12:32 PM
Dan,
Randy
From: owner-kitfox-list-server(at)matronics.com (owner-kitfox-list-server(at)matronics.com) [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Dan Billingsley
Randy,
Dan
David, (Or others),
Randy
runwayrex(at)juno.com Guest
Posted: Tue Jun 27, 2006 1:10 pm Post subject: The "Claw" tie down |
Dan,
Randy is correct. You're indicating that ONLY seven planes were using the claw and 3 failed. That's not what the stats were. There may have been hundreds using the claw, but three failed. There's a big difference here.
Rex in Michigan
-- Dan Billingsley <dan(at)azshowersolutions.com> wrote:
Randy,
Dan
| Quote: | Dan,
Randy
Randy,
Dan
Randy
Posted: Tue Jun 27, 2006 1:23 pm Post subject: The "Claw" tie down |
You are right...sorry Randy. Was looking at it sideways I suppose or misunderstood. Brain cramps...gotta love it.
Dan
Rexster <runwayrex(at)juno.com> wrote:
| Quote: | Dan,
Rex in Michigan
Randy,
Dan
| Quote: | Dan,
Randy
Randy,
Dan
Randy
Posted: Tue Jun 27, 2006 2:20 pm Post subject: The "Claw" tie down |
I don't know about failure rates, but, the Claw I saw looked to have cast
aluminum arms - although they may have been forged. The documentation
refers to it as aircraft grade aluminum. I wouldn't trust any part of my
airplane to a casting - engine excepted. One broken arm is the red flag for
me. I pretty much wouldn't care how many Claws were out there, the fact
that one broke definitely gives me pause. Bend - OK, Pulled out - maybe
OK, but broke under a Cub ??? The whole idea of multiple spikes speaks to
an attempt to attach the tiedown firmly to the ground. In my mind that
should be the weak point. If the spikes stay in the ground, but the
attachment to the airplane fails, the tiedown fails. Someone mentioned the
rope / strap and the need for strength there.
The ACS catalogue mentions a "life time guarantee". It makes me wonder what
that is all about. Other sites refer to a "Limited life time warrantee".
My guess is that the Cub owner and maybe others have contacted the Claw
folks to see what the guarantee means.
It is interesting that the manufacturer claims a "combined" 3600 lb holding
power, however Sporty's mentions it was tested to 480 lbs, individually.
Sure makes me wonder?
Lowell
Posted: Tue Jun 27, 2006 4:24 pm Post subject: The "Claw" tie down |
Maybe I missed it. Did they just pull out, or did
they fail and break? Soft earth or weak parts?
I agree with the weight problem and also it looks like
they take up a good bit of room.
Kurt S.
--- Fox5flyer <morid(at)northland.lib.mi.us> wrote:
| Quote: | Randy's probably right. However, the "Claw" people
Deke
asq1(at)adelphia.net Guest
Posted: Tue Jun 27, 2006 4:56 pm Post subject: The "Claw" tie down |
The ones I saw just plucked a disc of dirt out of the wet,soft ground.
Larry
