pcondon(at)mitre.org Guest
Posted: Tue Mar 21, 2006 6:11 am Post subject: O-540 / IO-540 Crank AD Excerpts |
Front part of the AD. The next 60 pages are the list of S/N effected
engines.
DATE: February 21, 2006 Service Bulletin No. 569
SUBJECT: Crankshaft Retirement for Certain Lycoming Engines
MODELS AFFECTED: Any Lycoming engine model specified below
manufactured, rebuilt,
overhauled, or repaired after March 1, 1997:
Lycoming counterweighted (L)O-360, (L)IO-360, HIO-360 and AEIO-
360 engines described in Section 1.
Lycoming IO-390 and AEIO-390 engines described in Section 2.
Lycoming O-540, IO-540, AEIO-540 and (L)TIO-540 engines described
in Section 3.
Lycoming IO-580 and AEIO-580 engines described in Section 4.
Lycoming IO-720 engines described in Section 5.
Lycoming crankshafts with a crankshaft serial number listed in Table 5
shipped as a spare after March 1, 1997. These crankshafts may have been
installed in any of the engine models listed above.
NOTE
1. Engines that have complied with Service Bulletin No. 552,
Service Bulletin No. 553, Service Bulletin No. 566, or
Supplement No. 1 to Service Bulletin No. 566 that have not
had a crankshaft replaced in the field after compliance with
one of the above Service Bulletins, are not affected by this
Service Bulletin.
2. Any new, rebuilt, overhauled, or repaired (example: prop
strike) engines received from Lycoming after July 11, 2005
(logbook date of manufacture) that have not had a
crankshaft replaced in the field are not affected by this
Service Bulletin.
TIME OF COMPLIANCE: At the crankcase separation or at next overhaul,
whichever occurs first, not to
exceed three years from the date of this Service Bulletin; therefore
affected
crankshafts must be retired by February 21, 2009.
Lycoming has continued to analyze crankshafts in service. While there
have been no failures in the
crankshafts which are the subject of this Service Bulletin, as part of
our commitment to quality, Lycoming is
initiating a crankshaft retirement program. This crankshaft retirement
program requires the removal of the
subject crankshafts when the crankcase is separated or at overhaul,
whichever occurs first, not to exceed
three calendar years from the date of this Service Bulletin, no later
than February 21, 2009.
Page 1 of 56
(c)2006 by Lycoming "All Rights Reserved'
A crankshaft kit will be provided at a price of $2000 (US). The kit
includes the appropriate crankshaft and
the following additional parts:
Main bearings Piston ring sets Connecting rod bearings
Piston pin plugs Connecting rod bolts and nuts Counterweight washers
Crankshaft gear bolt Counterweight snap rings Seal and gasket set
Lockwashers
The crankshaft part number and serial number are marked on the O.D. of
the propeller mounting flange.
Both will be required to determine effectivity.
NOTE
1. The engine model, engine serial number, and date of engine
manufacture, can be found in
the engine logbook. This information will be required to determine if
your engine is
affected.
2. Lycoming crankshaft part number formats that are affected by this
Service Bulletin
include the following:
a. The number "13" followed by a letter, then by the number "27",
followed by 3 digits
(example: 13x27###).
b. The number "13" followed by a letter, then by the number "37",
(example: 13x37###).
3. If your crankshaft part number is in the format shown in either Note
2.a. or 2.b., then go
to Table 5 to determine whether your crankshaft serial number is
affected by this Service
Bulletin. Lycoming crankshaft serial number formats that are affected
by this Service
Bulletin include the following:
a. "V5379" followed by 4 or 5 digits.
b. A "V" followed by 5 digits.
c. An "I" followed by 5 digits.
CAUTION
SOME AFFECTED SERIAL NUMBERS BEGIN WITH THE LETTER "I". THIS "I" MAY
BE MISINTERPRETED AS THE NUMBER ONE.
4. Some field repair stations mark their own identification (numbers
and/or letters) on the
propeller flange O.D. These numbers are not related to any Lycoming
information.
MODEL DESCRIPTIONS:
SECTION 1
Any Lycoming counterweighted (L)O-360, (L)IO-360, HIO-360 and AEIO-360
engines manufactured,
rebuilt, overhauled or repaired by Lycoming after March 1, 1997 and
with serial numbers listed in Table 1.
Any field overhauled or repaired Lycoming counterweighted (L)O-360,
(L)IO-360, HIO-360 or AEIO-360
series engine that has had a crankshaft replaced after March 1, 1997
Table 5.
NOTE
The counterweighted 360 engines can be identified by the numeral 6 as
the 4th suffix
character in the engine model (Example: IO-360-A1B6).
Page 2 of 56
SECTION 2
Any Lycoming IO-390 and AEIO-390 engines manufactured, rebuilt,
overhauled or repaired after April 1,
2002.
Any field overhauled or repaired Lycoming IO-390 or AEIO-390 series
replaced after April 1, 2002 with a crankshaft serial number listed in
Table 5.
SECTION 3
Any Lycoming O-540, IO-540, AEIO-540 and (L)TIO-540 engines
manufactured, rebuilt, overhauled or
repaired by Lycoming after March 1, 1997 and with serial numbers listed
in Table 2.
Any field overhauled or repaired Lycoming O-540, IO-540, AEIO-540 or
(L)TIO-540 series engine that has
a crankshaft replaced after March 1, 1997 with a crankshaft serial
number listed in Table 5.
SECTION 4
Any Lycoming IO-580 and AEIO-580 engines manufactured, rebuilt,
after March 1, 1997 and with serial numbers listed in Table 3.
Any field overhauled or repaired Lycoming IO-580 or AEIO-580 series
replaced after March 1, 1997 with a crankshaft serial number listed in
Table 5.
SECTION 5
Any Lycoming IO-720 engines manufactured, rebuilt, overhauled or
1997 and with serial numbers listed in Table 4.
Any field overhauled or repaired Lycoming IO-720 series engine that has
March 1, 1997 with a crankshaft serial number listed in Table 5.
INSTRUCTIONS FOR COMPLIANCE:
1. If your Lycoming engine serial number is listed in the Table for
your engine model (Table 1, 2, 3 or 4),
and the crankshaft serial number is in Table 5, then at next engine
overhaul, or when the crankcase is
separated or within three calendar years from the date of this Service
Bulletin, whichever occurs first,
contact Lycoming by phone at 570-323-6181 for information required to
obtain the appropriate
replacement crankshaft kit at a price of $2000 (US). This price is only
valid when complying with this
Service Bulletin and when the affected crankshaft is returned to
Lycoming.
2. If your engine model was overhauled, repaired, or had the crankshaft
replaced after March 1, 1997,
verify the crankshaft serial number through pertinent aircraft/engine
documentation or
overhaul/maintenance facility records. The engine logbook may contain
crankshaft replacement and
serial number information. If your crankshaft serial number is listed
in Table 5, contact Lycoming by
phone at 570-323-6181 to obtain the appropriate replacement crankshaft
This price is only valid when complying with this Service Bulletin and
returned to Lycoming. If your crankshaft serial number cannot be
verified through engine records,
contact Lycoming.
3. Crankshafts listed in Table 5 must be returned to Lycoming and must
not be reused to assemble any
engine. Check any uninstalled crankshaft against Table 5. If a subject
crankshaft is found, contact
Lycoming by phone at 570-323-6181.
4. After you determine that your engine and crankshaft are not affected
by this Service Bulletin, make
appropriate logbook entries.
5. Factory replacement crankshaft kits can be determined from the Table
in Appendix 1.
Page 3 of 56
dlm46007(at)cox.net Guest
Posted: Tue Mar 21, 2006 7:16 am Post subject: O-540 / IO-540 Crank AD Excerpts |
I believe this is a Service Bulletin and is not an Airworthiness directive.
Kellym
Posted: Tue Mar 21, 2006 7:26 am Post subject: O-540 / IO-540 Crank AD Excerpts |
You might want to reset your computer clock to the correct month.
Yes it is an SB. However, if you wait for it to be an AD, it will cost
a lot more money, as Lyc. will have stopped any warranty consideration
by then.
Quoting David McNeill <dlm46007(at)cox.net>:
KCHD |
Posted: Tue Mar 21, 2006 7:35 am Post subject: O-540 / IO-540 Crank AD Excerpts |
It also depends whether you have a data plate on the engine. If so then
certified and must comply with ADs
brinker(at)cox-internet.c Guest
Posted: Tue Mar 21, 2006 11:06 am Post subject: O-540 / IO-540 Crank AD Excerpts |
Even if it's an experimental aircraft ?
Randy
Posted: Tue Mar 21, 2006 2:20 pm Post subject: O-540 / IO-540 Crank AD Excerpts |
If the Lycoming data plate is there then it is still considered a certified
engine and ADs must be performed; even if the aircraft itself is
experimental. Of course if engine was experimental to start, then you can
ignore the ADs.
Kellym
Posted: Tue Mar 21, 2006 2:48 pm Post subject: O-540 / IO-540 Crank AD Excerpts |
Legalities aside, do you really want to fly behind an engine with a
crankshaft with known flawed metalurgy? Several of these cranks have
failed in six cyl Lycomings. How much do you really want to rationalize
this away? Why not get Lycoming's assistance in replacing the suspect
crank with a new crank?
certified engine and ADs must be performed; even if the aircraft
itself is experimental. Of course if engine was experimental to
start, then you can ignore the ADs.
KCHD |
Posted: Tue Mar 21, 2006 2:50 pm Post subject: O-540 / IO-540 Crank AD Excerpts |
Hey guys, this is getting scary. If there's an AD on something (in this
discussion, it's the crank) I think that ignoring it for any reason is
not conducive to a long flying career. It really doesn't matter whether
the crank is in an experimental engine or in a certified engine when the
sucker fails. That crank doesn't take the time to look and see if
there's a data plate or not because it doesn't really care! Ignore the
ADs???? Poor advice IMHO.
Linn ...... two off-field landings already.
itself is experimental. Of course if engine was experimental to start,
Posted: Tue Mar 21, 2006 3:03 pm Post subject: O-540 / IO-540 Crank AD Excerpts |
I'm just the devils advocate as I have a Van's IO540 to which the SB does
not apply.
speckter(at)comcast.net Guest
Posted: Tue Mar 21, 2006 5:11 pm Post subject: O-540 / IO-540 Crank AD Excerpts |
My understanding is that any engine or prop installed into an experimental
automatically decertifies it. To be reinstalled into a certified aircraft
it would need to go through reinspection/certification by an authorized
repair station.
No I do not have the FAR's to back this up so don't flame me, I burn easily
Gary Specketer
Tech Councilor
40274
deej(at)deej.net Guest
Posted: Tue Mar 21, 2006 5:33 pm Post subject: O-540 / IO-540 Crank AD Excerpts |
Gary Specketer wrote:
repair station.
I think it depends on which FSDO you ask. We had a gentleman
from the Portland, ME FSDO give a presentation to our local EAA chapter.
According to him, if the engine started out as "certified", you had to
comply with ADs even if the data plate were removed and it was installed
in an experimental aircraft. Go figure...
It would be nice to get something in writing from the FAA about
this. Anyone care to inquire to EAA if they have something like this?
-Dj
dmasys(at)cox.net Guest
Posted: Tue Mar 21, 2006 5:44 pm Post subject: O-540 / IO-540 Crank AD Excerpts |
Yep. That's what the FSDO guy who signed off on my repairman's certificate paperwork said also. Makes you think twice about the premium to be paid for using a new certified engine.
-Dan Masys
#40448 wings N104LD reserved
N747DL -7A flying with IO-360A1A with new ECI crankshaft in it. Dodged that particular Lycoming SB bullet!
LloydDR(at)wernerco.com Guest
Posted: Tue Mar 21, 2006 6:10 pm Post subject: O-540 / IO-540 Crank AD Excerpts |
Well you can think about it this way, the only one who can do Annual
condition inspections on a certified aircraft is an A&P, and the only
one who can tear down and rebuild a certified engine, and return it to
service is an A&P or a certified repair facility, right?
So when we as the repairmen certificate holder for the aircraft we
built, tear down and rebuild an engine with a data plate that engine is
no longer certified, because we do not hold an A&P license to be able to
return that engine to service on anything other than our experimental
aircraft. That is not to say the engine can't be inspected by an A&P and
found to comply with all AD's, and returned to certified service, just
that you as a home builder are not authorized to do this. I am in the
Northern Pittsburgh area and our local FSDO was at Greenville, and we
had a discussion on this topic today. Seems to me there is not
consistency on this topic even from the Fed's.
By the way in my opinion it is a mute point to not comply with a
crankshaft AD.
Just my .02 and as usual it is worth what you paid.
Dan Lloyd
40269
LIKE2LOOP(at)aol.com Guest
Posted: Tue Mar 21, 2006 6:48 pm Post subject: O-540 / IO-540 Crank AD Excerpts |
If one owns a certified engine (in an experimental) and wishes to replace
a cylinder or do any work (overhaul), what does it take to officially make the
engine experimental? As in, not needing an A&P sign off???
Do not archive ....the question.
Steve
Port St. Lucie, FL
772-475-5556
Sent from my Treo 600
johnwcox(at)pacificnw.com Guest
Posted: Tue Mar 21, 2006 7:31 pm Post subject: O-540 / IO-540 Crank AD Excerpts |
In a vacuum the rumors can sure abound. As it pertains to Experimental
Owner Built aircraft, one individual is entitled to declare themselves
as the builder. The certificate issued is separate from the
Airworthiness issued by the DAR. With a certified statement from the
one builder, the FAA will grant a Repairman Certificate for that one
individual to maintain that exact aircraft through its entire life.
Sell it and the next owner must seek out an A & P willing to stretch
their neck to complete a Conditional. The "Repairman" builder has all
of the rights of an A & P with IA designation as it pertains to
maintaining said aircraft - An annual Condition Inspection. To that end,
every FSDO marches the same tune. It is consistent as the sun setting
each day.
Certified Production Aircraft do not get Conditional Inspections. They
get Annual Inspections some even get 100 hour inspections. And only an
A & P with IA designation can do the annual inspection. Period...
Any A & P and the Repairman (builder) of the specific Experimental
Amateur built aircraft they built, can do the Conditional. It is not an
Annual. It just has to be done each year.
John - KUAO
Posted: Tue Mar 21, 2006 7:51 pm Post subject: O-540 / IO-540 Crank AD Excerpts |
Certificated engines when coupled with certificated propellers are most
often found in certificated mass produced civil production aircraft.
When that combination is installed in an Owner Built Amateur Aircraft
they do not loose their certification or the requirement for routine and
reoccurring maintenance just by being in the Kitplane. The
Annual/Conditional, just needs to be done by a current A & P with IA
designation.
When said combination is used in an Experimental built RV-10 the DAR is
granted the latitude to reduce the initial built fly-off period from 40
to 25 hours around the home patch. Change one of the two mated
certificated components or go with an esoteric auto conversion and the
rule reverts to 40 hours. The perception is that the risk goes up.
A certificated engine and prop which was properly maintained in an
experimental can go right back into a certificated production aircraft
with just simple log book entries. As long as the certificated
manufacturer approved the certificated engine and certificated propeller
in the first place. Hence the reason for an aircraft TCDS.
A certified product is one where someone makes a statement - "I
certify", nothing more. That will not be enough to remain certificated.
Each component has its own Engine/Prop/Accessory TCDS. Repairmen are
not authorized to work on certificated engines or propellers unless
under the color of their respective approved repair station. Home
builders with a repairman certificate maintain their own equipment but
it will not comply with maintaining airworthiness for certificated
purposes. To do so revokes the FAA authorization granting certification.
Once the data plate is removed, they can sure be put into OAMA and they
get a 40 hour fly off for being non certificated.
Repair stations are not the only approved means for recertification.
Don't forget the engine/prop/accessory factory and a properly trained
and tooled A & P with IA. Clearly everyone needs to have a better
understanding of the rights and responsibilities of maintenance. I
think the EAA does a pretty good job. If you find dissimilarities with
FSDOs let me know and I will show you the path to their boss's boss.
John - $00.02
Posted: Tue Mar 21, 2006 8:11 pm Post subject: O-540 / IO-540 Crank AD Excerpts |
One comment the 100 hour engine inspection can be done by an A&P. Certified
airplanes require an annual inspection for the airframe by an IA and a 100
hour engine inspection of the powerplant by at least an A&P.
Kellym
Posted: Tue Mar 21, 2006 8:18 pm Post subject: O-540 / IO-540 Crank AD Excerpts |
Not true. On certified aircraft the entire aircraft including the prop
and engine MUST be inspected by A&P WITH IA. Discrepancies can be fixed
by any A&P. The IA is certifying that he inspected the entire aircraft,
not just the airframe. Read the reg..it says each AIRCRAFT shall be
inspected annually.
KM
A&P
Certified airplanes require an annual inspection for the airframe by an
IA and a 100 hour engine inspection of the powerplant by at least an A&P.
KCHD |
Posted: Tue Mar 21, 2006 9:14 pm Post subject: O-540 / IO-540 Crank AD Excerpts |
Annual inspections are required for certified aircraft. 100 hour
inspections are only required if the plane is for hire. Many do both entries at
the annual if they coincide.
Steve
Port St. Lucie, FL
772-475-5556
deruiteraircraftservices( Guest
Posted: Wed Mar 22, 2006 1:33 am Post subject: O-540 / IO-540 Crank AD Excerpts |
hi,
Can anyone explain why an AD or SB does not have to complied with because
the engine is experimental? It is not the certified status of the engine
that dictates issue of an AD or SB, but the parts that have been used to
built the particular engine which dictate the issue of an AD or SB.
I do not believe that Lycoming does this as a money spinner, whomever has
read the SB569 knows that the Crankshaft kit is made available for $2000,
this is not even half the normal list price of a four cylinder crankshaft,
let alone the price for a six cylinder crankshaft. In addition to the
crankshaft itself, the kit comes with bearings, nuts, bolts, etc.
In an ideal world engines are built and run 1000hours past their TBO with
nothing more than a regular oil change. This is fantasy. This little
exercise is costing Lycoming quite a few $$$, and therefore should be
treated a bit more serious than some people seem to suggest on this forum.
The reality is that a lot of the 500 odd builders haven't even got an
engine, and that those who do, have not got to the stage where the engine is
actually mounted. It is not that much work to split the crankcase in the
overall scheme of building a RV10, and the $2000 for a new shaft doesn't
really compare to the investment for the a/c kit and all bits and bobs to be
got to complete the project.
Another thing to consider, in particular for those who haven't got their
engine yet, is to take the SB569 with them when they go and look at an
engine, you know what the pitfalls are when you buy one that's on the list!
Oh, and yes, our engine is effected and the crankkit is on order, good deal
if you ask me, 0 hour overhauled bottom end for $2000..........
