Flyinisfun(at)aol.com Guest
Posted: Fri Oct 01, 2010 5:31 pm Post subject: Throttle Quadrant control |
Sorry to send this again but I didn't spell check it and some of the words might not be understood.
Hi Al,
The real questions to me would be, "Do you want to control the stick with your right hand or your left hand?" If you were thinking about putting a throttle quadrant in the center or making a console to put it in, "DON'T" and here is the reasoning for that. Inevitable you will be getting under the instrument panel to work on the brake peddles or something near the fire wall. If you put anything in the center and block off your access to the front, you will forever regret it. It's hard enough to crawl under there as it is. Now, if you put in a throttle quadrant on the left side, on the fuselage you will fly with your right hand but you now need to put a control of some sort on the right side in case the pilot becomes incapacitated and the passenger has to take over.
My thoughts, Jesse Wright
That's like asking "should I marry this woman or that woman". Choose the one that feels best.
Al
Quote: | Subject: KIS-List: Throttle controls
Hi All,
Should I use push pull controls or install a Quadrant
Mike
| - The Matronics KIS-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
