Costly mistake
Goto page Previous  1, 2
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Engines-List
frank.hinde(at)hp.com
PostPosted: Fri Feb 16, 2007 9:30 am    Post subject: Costly mistake Reply with quote
Ahh!..It could have significant blowby on the piston rings. What happens is the cylinders are bored and then the heads torqued. this flexes the bore. The solution is to have it bored with a "boring plate" bolted down first. This simulates the torque of the head bolts.
Now of course this is only one possibility and it requires an engine strip to sort it out. The EA 81 is a pretty simple engine to strip and reassemble so its not the end of the world but not something you want to do more than once.
My advice is to speak with the top engine guru as far as EA81's are concerned. That would be Ron Carr at Ram Performance. A number of (so called) rebuilt Soobs had valve giudes dropping out of their heads, mine included. Ron was the only guy that came up with a permanent fix. IF you end up stripping your engine I would have him install the stepped valve guides.
http://www.ramengines.com/
he is exceptionally knowlegable..
And tell him Frank said Hi....
Frank
Zodiac 601HDS 400 hours
RV7a 75 hours.
From: owner-engines-list-server(at)matronics.com [mailto:owner-engines-list-server(at)matronics.com] On Behalf Of Dacha
Sent: Friday, February 16, 2007 8:23 AM
To: engines-list(at)matronics.com
Subject: Re: Costly mistake
It is an EA81. What is the fix?
LeRoy
- The Matronics Engines-List Email Forum -
http://www.matronics.com/Navigator?Engines-List
Float Flyr
PostPosted: Fri Feb 16, 2007 1:02 pm    Post subject: Costly mistake Reply with quote
If all the parts are wet with oil first there is no way for any water to get under the oil. Yes there is no point in oiling an engine that has been immersed in water That is one way that you can get water under the oil. For engines that have been immersed in water the best thing you can do is disassemble the engine to a point that you can dry the engine very quickly then oil for storage.
Noel [quote]
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
purplemoon99(at)bellsouth
PostPosted: Fri Feb 16, 2007 1:26 pm    Post subject: Costly mistake Reply with quote
Lisen to frank about RAM ,RON IS THE BEST.. my little 'ol 601/ E81 goes like the wind ,1800 FPM climb not to bad,wait untill we get her tweeked... Joe N101HD
tstaley(at)centurytel.net
PostPosted: Fri Feb 16, 2007 3:03 pm    Post subject: Costly mistake Reply with quote
Talked to Ram this morning and when I have it overhauled they will be the ones to do it. Sounded very professional and knowledgeable. Not cheap but what is?
LeRoy
Ps. thanks to everyone who responded to my request, great list like to meet the guys sometime.
n801bh(at)netzero.com
PostPosted: Fri Feb 16, 2007 3:36 pm    Post subject: Costly mistake Reply with quote
Sooo.
Lets get back to the original question. Frank and Joe and any other soob flyer. What is your oil consumption???????????????????????
Ben Haas
N801BH
www.haaspowerair.com
PostPosted: Fri Feb 16, 2007 6:12 pm    Post subject: Costly mistake Reply with quote
I don't remember my soob consuming oil after break in.
Frank
From: owner-engines-list-server(at)matronics.com [mailto:owner-engines-list-server(at)matronics.com] On Behalf Of n801bh(at)netzero.com
Sent: Friday, February 16, 2007 3:35 PM
Subject: Re: Engines-List: Costly mistake
Sooo.
Ben Haas
N801BH
PostPosted: Fri Feb 16, 2007 6:14 pm    Post subject: Costly mistake Reply with quote
When your engine literally eats a chunk of valve guide and your convinced it is trying to kill you, cheap is not a consideration....When it does THREE times and the supplier still gives you a bunch of baloney about how it is your fault (namely you get the bill) then you will see that a Ram engine is very good value for money indeed.
Yes Ron is bar far the most knowlegable Ea 81 guy out there.
Frank
Sent: Friday, February 16, 2007 2:57 PM
LeRoy
href="http://www.matronics.com/Navigator?Engines-List">http://www.matronics.com/Navigator?Engines-List
PostPosted: Fri Feb 16, 2007 7:03 pm    Post subject: Costly mistake Reply with quote
My eng was broke in on a dyno. at ram. I've only have 2hr. of test flight on it at this point no oil use at this time,plus the fact i"ve changed it twice already.I've got abit of a cooling problem that we are trying to over come.nothing serious ,just a little warmer that we want it. Joe N101HD
klehman(at)albedo.net
PostPosted: Fri Feb 16, 2007 7:05 pm    Post subject: Costly mistake Reply with quote
Pretty close to nil on my ej22 with psru and an average 4200rpm cruise.
I added a half liter of 5W50 synthetic in the last 40 hours but much of
that was/is a small leak.
Ken
n801bh(at)netzero.com wrote:
Sooo.
PostPosted: Fri Feb 16, 2007 7:14 pm    Post subject: Costly mistake Reply with quote
What kind of synth. are you using? and for how long ? Joe N101HD
PostPosted: Sat Feb 17, 2007 9:33 am    Post subject: Costly mistake Reply with quote
Hi Joe
I suspect that Mobil 1 is no longer a superior product so I use the
cheaper and easier to obtain Castrol Syntec and unleaded fuel. Soob does
specify 50 weight oil for this engine for heavy duty applications and it
works a lot harder than it ever does in a car. My oil pan temp will get
up to 120 C (250 F) on hot weather climbs and the 5W50 is also
comfortable for sub freezing start ups. I only have about 65 hours on
the engine since new but I'm aware of others that have run similar for a
few hundred hours now.
Ken
PostPosted: Sun Feb 18, 2007 4:58 pm    Post subject: Costly mistake Reply with quote
Joe...I may be able to help
Do you know of a Mr Larry Mcfarland?....He hangs out on the Zenith list. He has (like a lot of builders) moved his radiator back about 3 feet from its original location. He also made some very nice radiator air intakes and exhaust louvers that help improve airflow thru the radiator, which is a problem with the standard 601 set up.
Larry will make and sell these to other builders.
Cheers
Frank
From: owner-engines-list-server(at)matronics.com [mailto:owner-engines-list-server(at)matronics.com] On Behalf Of Southern Reflections
Sent: Friday, February 16, 2007 7:03 PM
PostPosted: Sun Feb 18, 2007 6:43 pm    Post subject: Costly mistake Reply with quote
Thanks Frank, I've been contact with Larry,Along those lines. Joe N101HD
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Engines-List All times are GMT - 8 Hours
Page 2 of 2
