Cam Lobe wear
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Engines-List
drogers(at)maf.org
PostPosted: Sun Feb 11, 2007 11:30 am    Post subject: Cam Lobe wear Reply with quote
Hi Gary,
Some long time ago, you wrote the quote below.
I am trying to find the cause of rough running in a Lyc O360A4M that has
good compression, good mags, good timing. It has about 1400 smoh over
about 12 years. There were times during those years in which it sat for
over a year at a time. Also, for most of that time, the oil cooler
hoses were connected wrong so the oil ran quite hot.
How can I prove that there is or isn't excessive cam lobe wear without
tearing it all down??
Dan
Gary Casey wrote:
Often the first sign of cam wear is a rough
engine and inspection will show that the cam lobe is gone. For some
time the engine tolerated that much iron and didn't fail.
Gary Casey
- The Matronics Engines-List Email Forum -
http://www.matronics.com/Navigator?Engines-List
glcasey(at)adelphia.net
PostPosted: Mon Feb 12, 2007 5:59 am    Post subject: Cam Lobe wear Reply with quote
Dan,
Yes, a compression test will not indicate that you have a problem
with the cam. If it is really bad a cranking compression
("differential" compression test) might show the problem. Crank the
engine with the mags and fuel off and note the difference between
compression strokes - it is quite easy to tell if one cylinder is
really low. You can pull the valve covers and measure the valve lift
and that is one way to get a reasonable picture of cam lobe wear.
You have to be careful about the hydraulic lifters as if one is
collapsed you won't get an accurate measurement, but I don't know how
to accommodate that, I'm afraid. From what I've heard, by the time
the engine is running rough and is low on power the lobe will be
essentially wiped off, making this method very effective - and it
only takes a few minutes. I've used a simple steel scale, but a dial
indicator would be more accurate. However, if you want to get a real
look at the cam lobes the only way is to remove a cylinder - I'm told
that on a 4-cylinder you can remove just one and get a peak at all
the lobes, but I've never tried. Removing a cylinder isn't a huge
deal, but it is a pain. It might take a day's labor to get it apart,
inspected and put all back together. If the engine had no symptoms
and looking in the valve covers showed no obvious problem, but showed
metal in the filter then one has to look inside. With metal in the
filter something is going to have to come apart anyway.
Gary Casey
Hi Gary,
that has
sat for
Dan
esmith6(at)satx.rr.com
PostPosted: Mon Feb 12, 2007 11:09 am    Post subject: Cam Lobe wear Reply with quote
Yes, remove a cylinder and use a strong bright light and look up in
there...I removed #2, and you can see the lobes...The other choice (and the
best) is to buy one of the oil analysis kits (around $10) and send off a
sample of your oil, and through a Spectroanalysis system (S.O.A.P.) they can
tell you which component is wearing excessively by the type and amount of
metal in your oil...As you know the different internal parts of your engine
has a different type of metal...i.e: bearings, crankshaft journals, valve
guides, cam lobes and etc.
Interesting thing here as to the importance of this test, the USAF takes a
S.O.A.P. sample after each flight of a Jet Fighter, (esp. if it is single
engine) and the aircraft will not be released for the next mission until the
analysis is complete and deemed safe......................Hope this
helps...Good luck.............................CHEERS!!!!
Gene Smith
RV-4
drogers(at)maf.org
PostPosted: Mon Feb 12, 2007 11:51 am    Post subject: Cam Lobe wear Reply with quote
Thanks to Gary, Jim, Aaron,and Gene.
Actually, I already have one cyl off for other reasons and didn't even
think to try and look inside!!! The only real symptom right now casting
a question on the cam is roughness that is not explained by anything
else. We did and oil analysis about 8 hours ago and some metals were
high but not real bad. There has not been any visible metal in the filter.
Thanks again, everybody,
Dan
Dan Rogers wrote:
Hi Gary,
Dan
Gary Casey wrote:
> Often the first sign of cam wear is a rough engine and inspection
> will show that the cam lobe is gone. For some time the engine
> tolerated that much iron and didn't fail. Gary Casey
apilot2(at)gmail.com
PostPosted: Mon Feb 12, 2007 1:24 pm    Post subject: Cam Lobe wear Reply with quote
Disagree on the oil analysis. Cam and lifters spall off relatively
large chunks of metal, that are not microscopic and never burned in
the spectrograph. You may see slightly elevated iron, but nothing
startling, but you will see specks of iron in the oil filter. Went
through this on my own IO-360 in 2001.
KM,
A&P/IA
Gene Smith
RV-4
PostPosted: Mon Feb 12, 2007 4:52 pm    Post subject: Cam Lobe wear Reply with quote
Kelly,
You seem like you have experience in this area and are knowledgeable about
the subject....Educate me about this, if an engine sets up unpickled for a
year, I understand from friends of mine that rust forms on the lobes, and
when started again, rust flakes off and contaminates the oil system, then
acts as pumice...Does this rust not show up on a spectrograph sample?..One
Tripacer owner neglected to change oil very often (if at all) and complained
of the engine not running right...I later saw the camshaft and there was
only "nubbins" left...I don't see how the valves functioned at all...I've
said this before, so will use this opportunity to mention it again, the
cheapest thing you can buy for your engine is OIL, and change it often...I
know the book says change at 50 hours, but I take a good look at mine at 25
hours and if it exhibits the slightest darkness, then out it goes...One step
further, I use a 50/50 mix of Aeroshell and Mobil-I 15/w50, and after 1500
hours, have had no problems at all...I do not advocate any of you out there
to use this mixture, especially certified aircraft...It is a personal thing
with me..........Kelly, thanks for your inputs...............CHEERS!!!!
Gene Smith
RV-4
PostPosted: Mon Feb 12, 2007 5:47 pm    Post subject: Cam Lobe wear Reply with quote
What happens is a bit of rust or imperfection in the nitride layer
causes a breakthrough to softer metal, on either cam or follower or
both. Once that happens metal comes off quickly in relatively large
particles..ones you can see. Oil analysis only detects metals at the
microscopic size, that are vaporized in the spectrograph. Larger
particles don't make it from the bottom of the sump, typically. My cam
disintegrated, and luckily I was cutting the filter and saw the metal,
and had to pull the oil pump for the AD on that and found it badly
scored from the metal, so it was tear down time. I kept the cam and
lifters as examples. I got to buy a replacement crank, new cam and
lifters, and a new prop hub out of that episode...not all because of
the cam, but from what I found on teardown. The good part is new prop
hub I bought in 2002 is exempt from the current AD just issued this
year. One gets very intimate with the details when you are building an
engine for a type certified plane that you plan to fly, and may
eventually sell to someone else, who will have your name in the
logbooks as the mechanic that authorized its return to service, and
may sue you 20 years later because it quit on them, even though they
are 8 years and who knows how many hours past TBO.
Kelly,
Gene Smith
RV-4
wbecker(at)centurytel.net
PostPosted: Mon Feb 12, 2007 7:20 pm    Post subject: Cam Lobe wear Reply with quote
Why not just use Aeroshell 15/50, which is 50% synthetic ? Bill B
PostPosted: Mon Feb 12, 2007 8:48 pm    Post subject: Cam Lobe wear Reply with quote
Bill B.,
I am not familiar with that oil, and did not know it was 50% synthetic, but
thanks for the info, I certainly will investigate the Aeroshell...I get the
Mobil I for $4.00 a quart...Is there a significant difference in price, not
that it makes much difference when you are dealing with an aircraft engine,
you always want the best...I am reluctant to say this, but with all the
fraud and lying going on in almost all aspects of our lives now days, I know
for sure I'm getting 50% synthetic when I measure and mix it myself...In no
way am I accusing Shell or any other aspect of aviation of wrong doing...I
run Mobil I in everything I have, including the lawn mower...I have one auto
that the manufacturer requires it...Another reason I use the Aeroshell in
the aircraft mixture is because I'm not sure Mobil I has enough detergent,
otherwise, I would use 100% Mobil I which is 100% synthetic..That is one
slick stuff.......Thanks for the info......................CHEERS!!!!
PostPosted: Mon Feb 12, 2007 9:29 pm    Post subject: Cam Lobe wear Reply with quote
Don't let that Mobil 1 get anywhere near the airport. There was a big
class action and AD against Mobil 1 aircraft oil, lots of folks didn't
get the full cost of repairing damage that oil caused to engines,
props, governors. Exxon Elite or AeroShell 15-50 are both semi
synthetic. Both around 50-55 a case on sale. Exxon does on-line sale
for every major aviation event like SnF and OSH and AOPA Expo with
rebate of some sort to reach that price. They pay shipping(drop
shipped from closest distributor).
Bill B.,
PostPosted: Tue Feb 13, 2007 1:26 am    Post subject: Cam Lobe wear Reply with quote
Kelly.......... Guess there is no end to this...Those so called damaged
engines were all replaced by Mobil...It was a sludge problem so the
operators said...They were all very large engines and commercial operators
in Ca...Mobil was going to fight it, but because of Barrister costs and
dragging it through the courts they decided it was cheaper to settle it by
replacing the engines, and settling down time...They then removed the
aviation oil from the market because they said they weren't making any money
off it, but were just doing it for the convenience of general aviation, so
it was removed...(Now Exxon and Shell are making 50% synthetic, is their
syn. any better than Mobil's?)..Mobil then came out with the 15W50, but for
autos only...I used the Mobil 1 Aviation Oil for years in a C-150 and never
had any sludge problem...The engine went over 2000 hours before each of two
overhauls and the inside of the case and moving parts were golden, not even
black, and obviously no sludge...I now have an RV-4 with a Lycoming
0320(160HP) with 1500 hours using the synthetic as mentioned in the earlier
thread...I popped a cylinder to see what was going on, and inside it was
just as golden as the Cessna...I know because you are an A&P/IA you are
concerned about certified aircraft owners using it...I advocate none of that
at all...Remember, I am EXPERIMENTAL, and operate under different rules.
Questions for you...Does a certified aircraft and engine have to use an
"approved" oil like Exxon and Shell, or can they use any oil of their
choice?..I know break-in oil is straight mineral oil, correct?..Why is this
necessary for break-in?
Enjoyed discussing this with you, and wish you all the luck in the
world...Thanks for all your info and time, you are very knowledgeable, and
informative...........CHEERS!!!!
Gene Smith
RV-4
PostPosted: Tue Feb 13, 2007 4:42 am    Post subject: Cam Lobe wear Reply with quote
First, the Mobil 1 problem was not isolated to large engines. There
were a lot of private, non-commercial operators. A friend had a
Continental TSIO360 damaged. Mobil fought every claim through
so-called court "masters". A lot of owners suffered uncompensated
losses.
The problem is that synthetic oil does not hold sludge in suspension
the way mineral oil does. That sludge centrifuges out in the worst
places like prop hubs, bottom and top end of the engine, sticking
valves, etc. That is why the approved oils are at least 50% mineral
oil. Whether break-in oil is needed or not is a separate subject.
While you can use what you want in an experimental engine, keep in
mind that a lot of experimentals are flying behind certified engines,
and a lot of evidence supports sticking with approved oils. The
technology for air-cooled aircraft engines hasn't changed in 50 years,
even if you have a few ignition or fuel system improvements. Unless
you are burning true unleaded auto fuel, pure synthetic oil is an
unnecessary risk, in my opinion. The only "aircraft" engine approved
for use of Mobil 1 was the Porsche PFM engine, and it had a lot of
automotive features, since that was its origin. All the other
aircraft use of that oil was by STC approval, which has been revoked.
Certified aircraft must use manufacturer approved oil or STC approved oil.
Gene Smith
RV-4
MONTY(at)bpaengines.com
PostPosted: Tue Feb 13, 2007 8:33 am    Post subject: Cam Lobe wear Reply with quote
Sorry, Guys. Camshafts in Lycomings anc Continentals are NOT nitrided.
The Lycoming is AISI 8620 and is carborized, about .030 deep.
Don't know what the material is in TCM but it looks like and acts like a
1080 forging in which case it has enough carbon to harden without
carborizing.
Monty Barrett
BPE, Inc.
PostPosted: Tue Feb 13, 2007 11:53 am    Post subject: Cam Lobe wear Reply with quote
Gene,
I'm no oil expert by any means, but I read a column by Ben Visser in
General Aviation News www.generalaviationnews.com , he is an oil and fuel
expert. Ben says that automotive oils use detergents and aviation oils use
ashless dispersants. Both are for keeping the engine clean, but the
detergents can cause carbon in aircraft engines, which could cause
preignition. Might be a reason not to use an automotive oil, even a great
one like Mobile 1 in aircraft. You can email Ben, maybe he could give his
opinion,
visser(at)GeneralAviationNews.com
By the way I used the aircraft Mobile 1 for years in a banner tow aircraft,
and it went past TBO, never had a cylinder off. Now I use AeroShell 15/50
semisynthetic
Bill Becker.
jfs(at)wildblue.net
PostPosted: Tue Feb 13, 2007 12:48 pm    Post subject: Cam Lobe wear Reply with quote
I asked my lil' brother for his take on this thread. His response follows:
"Some of these guys are really misguided on many things, and some of them
appear to be playing alchemist by mixing on their own volition. This is a
strict no-no for many reasons. No time this morning for a full response,
but a few points:
Mobil 1 is an automotive oil, not approved for any Lyc or Continental
as every other automotive oil is not... they contain detergents which
can foul spark plugs in aircraft engines, particularly. the bottom plug.
This is why only ashless oils are recommended, like Exxon Elite or the
Aeroshell M/G. There is only one exception I can think of where Mobil 1
is used, in fact the only oil recommended... the Mooney Porsche, which
the Germans at Porsche recommended only 1 oil for... 2 different
viscosities of M1 depending on the ambient temp. I have heard of folks
using M1 or someone else's auto oil in a Lycoming or Continental... all
I can say is that they are fools and in violation of the OEM's, all of
whom recommend only aviation oils. Aircraft engines are run under
relatively slow speed, steady speed conditions for hours at a time...
perfect conditions for deposits to form on spark plugs, Using detergent
auto oils is therefore a safety of flight issue, and therefore the
reason only ashless dispersant oils are approved.
There is no better wear protection oil in the marketplace than Mobil
1... one of the reasons it is used by so many NASCAR teams and in F1,
IRL, LeMans and so many other race classes. ExxonMobil has run it a
million miles in a BMW under severe conditions... miniscule wear and an
engine that was super clean at test end.
The Mobil 1 that the writer below is probably referring to was Mobil AV
1, not Mobil 1. It was removed from the market many years ago, but the
press and some of the trade rags got it way overblown w/ mistruths. It
worked wonderfully in Lycomings and most Continentals, but when flown
infrequently in certain big bore Continentals, there were a few ring
sticking incidents. This can occur with all oils when moisture and
infrequent flying get together, esp at altitude where some of the high
flyers have to operate at richer mixtures to keep things cool. Avgas
has a lot of lead, and the extra lead at rich mixture settings, and
moisture get together to form a lead paste. This is the stuff that can
stick ring/s or accumulate in props (which are when you think of it,
perfect centrifuges)
I saw a ton of engines flown to TBO that operated on Mobil AV1... that
thing got real political and emotional. Mobil ended up paying bogus
claims... we saw falsified logbooks etc... it was ugly, what some pilots
will do to get $$$ out of any big pocket supplier. I hate lawyers and
anybody related to one.
There are still a number of pilots using Mobil AV1 with great
satisfaction, altho' it was removed from the market many years ago (some
loaded up on supply near the end) Believe me, when flown under the
right conditions, you can't believe how clean those engines were. Go
into the Smithsonian Air & Space Museum sometime, look up at the Voyager
and notice the Mobil AV 1 decal... that around the world, non-stop
flight used only Mobil AV1. Again, a good oil that got a bad rap...
The reason ExxonMobil and Shell use partial synthetics (again, ashless)
for their premium offerings is that the mineral oil portion has good
natural "solvency" for keeping unwanted material in fine suspension, to
be later drained out during the oil change. The synthetic portion gives
the low temp performance and the high temp thermal and oxidative
stability plus great wear protection... the additives used are key in
enhancing the performance, especially w.r.t. wear & anti-rust
performance
One last comment about the guy who mixes... don't, especially an
automotive with an aircraft oil. Your friends seem to have no idea what
an oil like Exxon Elite has to go through... for starters, a series of
lab tests... if successful (reviewed by the SAE Technical Committee 8
(chaired by the USN)), then a 150 hour endurance test (a real engine (we
ran a Lyc TIO-540J2BD, a Piper Chieftain powerplant), run in a test cell
under a variety of climb. descent and cruise profiles). If you get
through that , you go to a 500 hour flight eval in 2 different engines.
We chose the 2 most difficult, higher temp T/C engines... the Lyc
previously mentioned & for the Continental, the TSIO520-BCE (used in a
Cessna 402). All engines are disassembled and pre-measured for wear,
then flown (both in test cell and on wing), then disassembled again and
inspected/post measured for wear... all oil wetted parts... cams, valve
guides, crank, cylinders, pistons, bearings etc... The engines are also
sludge & deposit rated, so that in addition to wear performance, the oil
needs to demonstrate excellent cleanliness. This rigor of approval is
exactly why ExxonMobil's, Shell's, Phillip's etc stance on using
additives of any kind is the way it is... one simply can't test all the
possible combinations of "mouse milk" additives out there. It is
usually wasted money spent. Stick to a great oil like Elite and be done
with it. We look at a ton of cams that have been flown to TBO, and with
Elite especially they look good with very minimal wear. The key is to
fly as regular as possible, and use an oil with the highest level of
rust protection available... these are most always the multi-grades, and
among those, the Elite really stands out (we designed it that way, as
statistics show that the average pilot in the US flies less than ~50
hours per year. We have a lot of data to back up this claim, both rust
and wear protection is unsurpassed with Elite. You don't need to pass
this along, as in re-reading it sounds like a commercial, but it's my
life, and as an Engineer, I've seen too much data and too many engines.
Can I go to work now?"
Float Flyr
PostPosted: Tue Feb 13, 2007 4:21 pm    Post subject: Cam Lobe wear Reply with quote
I know one guy who drops a bit of Aeroshell semi synthetic into his car a
couple of hundred miles before an oil change. He swears it cleans out any
sludge in his engine.
Noel
[quote] --
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
redswing(at)mcn.org
PostPosted: Tue Feb 13, 2007 9:52 pm    Post subject: Cam Lobe wear Reply with quote
Thanks for the straight scoop Monty.
Red Hamilton
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Engines-List All times are GMT - 8 Hours
