Any hot start problems with fuel injection?
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> M14PEngines-List
loray(at)compuserve.com
PostPosted: Thu Feb 08, 2007 12:52 am    Post subject: Any hot start problems with fuel injection? Reply with quote
Hi Milt:
Have you experienced any hot start problems with the fuel injection
system?
Loray
myhosting.com - Premium Microsoft® Windows® and Linux web and application
hosting - http://link.myhosting.com/myhosting
- The Matronics M14PEngines-List Email Forum -
http://www.matronics.com/Navigator?M14PEngines-List
n395v
PostPosted: Thu Feb 08, 2007 5:49 am    Post subject: Re: Any hot start problems with fuel injection? Reply with quote
Not as yet but I have to qualify that with the fact that I first flew in November and haven't really had a warm day yet where I have shut down and restarted while the engine was still hot. On a couple of flights I stopped for fuel and got going again in 20-30" but it was less than 20degF outside so I am sure the engine and compartmentt cooled fairly rapidly.
I have a temp sensor in the aft engine compt and I have never seen it above 150degF.
For 1st start of the day I turn the boost on with mixture full rich and give it 2-3seconds of prime (boost pump puts out almost 30psi) for later starts that day I just bump the primer. Never see more than 3 blades before it fires.
Only start trouble I have had was 2 weeks ago it was 6 deg F outside. Using my normal methods it would kick over but wouldn't stay running.
So I just started increasing my prime 1 second at a time.
Ended up flooding it and started a fire on the ground. Not really sure what technique to use in really cold other than probably pre heat.
It really starts and acts pretty much like the pressure carb does as best I can tell.
I did also recently experience the momentary stumble with rapid throttle advancement that others have experienced with the carb. This had not occured in the past. Talked to Don Rivera at AFP about this and it seems I needed to increase pressure from the engine driven fuel pump.
I've made the adjustment but haven't flown yet.
Milt
db2005(at)2wings.com
PostPosted: Thu Feb 08, 2007 8:30 am    Post subject: Any hot start problems with fuel injection? Reply with quote
Milt,
I would be very curious to see what your hottest aft engine compartment
temps run in the summertime. On the pitts 12, we normally run an aluminum
CO2 bottle for air, but awhile back I picked up one of those super light 3lb
firefighter backup bottles. Its a very thin aluminum bottle wrapped in
carbon/fiberglass rated to 2216 psi, but should be kept below 160 deg F. At
180 deg F the resin starts to transition, although at our pressures the
bottle won't burst since its operating at 38% rated pressure. Does anybody
have an idea what temp the air going INTO the bottle might be?
Also when have you seen 150 on your sensor, inflight or on the ground after
shutdown?
Darin Bishop
Pitts 12
www.2wings.com
george(at)gesoco.com
PostPosted: Thu Feb 08, 2007 2:08 pm    Post subject: Any hot start problems with fuel injection? Reply with quote
Hey Guys, My guess you are confusing a port type injection system with the
type on Milt's aircraft. The port type on the big Lycoming are a pain to
start hot as we all know. The system Milt has is a throttle body type of
injection that is very similar to the pressure carb that is already standard
on the M14P. Furthermore, I expect there is a vapor return system on Milt's
instigation like all the Russian planes use.
n395v
PostPosted: Thu Feb 08, 2007 2:17 pm    Post subject: Re: Any hot start problems with fuel injection? Reply with quote
George is correct. I do not have multiport fuel injection. It is an AFP throttle body that bolts directly to the carb anchor bolts. It functions similiar to the pressure carb except for manual control of mixture.
While I plumbed for a fuel return line on the plane I did not utilize it. The fuel runs to the Throttle body and primer are so short direct and uphill that i did not think vapor would be an issue. So far this has turned out to be correct.
I think George (correct me if I am wrong) is developing a full blown multiport FI system that should be just awesome.
George,
How about an update on te FI system, electronic ignition, parts availability and whats going on in Russia/Romania.
Milt
n395v
PostPosted: Thu Feb 08, 2007 2:23 pm    Post subject: Re: Any hot start problems with fuel injection? Reply with quote
shutdown?
Darin,
Highest temps have been on the ground shortly after shutdown but they decrease rapidly. I have an electric start so the airbottle is not an issue for me.
Milt
dsavarese(at)elmore.rr.co
PostPosted: Thu Feb 08, 2007 3:41 pm    Post subject: Any hot start problems with fuel injection? Reply with quote
ELECTRIC start!!!??? On a 52TW we call them "sissy Yak's". Smile So I guess
we'll have to start calling your Rocket a "sissy Rocket". Smile Only kidding
with you of course, Milt.
Dennis
n395v
PostPosted: Thu Feb 08, 2007 4:11 pm    Post subject: Re: Any hot start problems with fuel injection? Reply with quote
Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing
donot archive
Milt
n395v
PostPosted: Fri Feb 09, 2007 5:02 am    Post subject: Re: Any hot start problems with fuel injection? Reply with quote
Dennis
My "Sissy" Rocket" Very Happy
Milt
PostPosted: Fri Feb 09, 2007 5:19 am    Post subject: Any hot start problems with fuel injection? Reply with quote
We are using a variation of ECI fuel injection. We are still in the
development stage. We have one version now running on our R-263 engine. The
factory is gaining experience with this system. It will be early next year
before we have a fully tested system. I am also half heartedly playing with
an electronic fuel injection as it has a lot of advantages in fuel delivery
control.
George
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> M14PEngines-List All times are GMT - 8 Hours
