Antennas
TSaccio(at)aol.com
PostPosted: Thu Feb 08, 2007 1:04 pm    Post subject: Antennas Reply with quote
My names Tom Saccio and I have a question about antennas. When my panel was built the Avionics shop ran RG 400 cable from the instrument panel. All of the antennas that I installed are RG 58. The leads coming from the panel are only about 3' long. My question is do I run the RG 58 to the panel and connect to the short RG 400 or can I add on to the RG 400 and connect them to the RG 58 in the rear of the plane as I would like to do. The RG 58 that I hooked up is long enough to reach the panel without additional connectors. Any responses to this question would be greatly appreciated. The plane that this is going in is a Seawind.
Thank you,
Tom Saccio
tsaccio(at)aol.com (tsaccio(at)aol.com)
