What's advantage of conductive fuel hose?
nuckollsr(at)cox.net
PostPosted: Thu Jan 25, 2007 4:23 am    Post subject: What's advantage of conductive fuel hose? Reply with quote
Dunno . . . I'll ask around the power-plant and fuel systems
guys today.
At 07:33 PM 1/24/2007 +0000, you wrote:
I am working on final plumbing of Europa / Rotax 914 fuel system.
The system is a plastic rotomolded fuel tank, mostly rubber automotive
5/16" fuel injector hose, 2 vane style electric fuel pumps.
I have plumbing completed to 2 Flowscan 201B fuel flow sensors (add flow
in, and subtract return to tank).
I want to use Aeroquip 666 to run from the 201B through firewall to the
fuel pressure regulator, and then from the fuel pressure regulator return,
through the firewall to the return 201B.
I read somewhere that the 666 hose has stainless braid on the outside,
Teflon hose on the inside and it is electrical conductive. Didn't think
much about it, I just assumed that they were talking about the braid.
After getting a sample of the hose, I see that they have the internal wall
of the hose coated with a black substance that is probably;y electrical
conductive.
2 Questions:
1) Why would you want the internal wall of a hose electrical conductive?
I read 43.13 and they really don't tell much as to why. If it is static
discharge, is that really important? There are plenty of cars on the road
with rubber fuel lines?
Perhaps for lightening strike??
If I use this hose in my system (approx 4 feet in and 4 feet out) am I
creating any problems? Aeroquip makes very close to the same hose for Auto
racing guys without the black conductive coating. You see this as a more
appropriate hose for my system/plane?
2) More of a concern I think is there is this thin black coating inside a
Teflon tube. If it begins to flake off, it could cause much problems.
Has anyone had any flaking problems?? I can easily see causing an upset to
this coating when installing hose ends.
Thx.
Ron Parigoris
10:31 PM
-- incoming mail is certified Virus Free.
Checked by AVG.
( IF one aspires to be "world class", )
( what ever you do must be exercised )
( EVERY day . . . )
( R. L. Nuckolls III )
Bill McMullen
PostPosted: Thu Jan 25, 2007 10:16 am    Post subject: Re: What's advantage of conductive fuel hose? Reply with quote
I think this article gives a good start for answering this question ... basically the conductive liner is preventing static sparks between the inside of the hose and the braid.
http://www.sacskyranch.com/statichose.htm
rparigor(at)SUFFOLK.LIB.N
PostPosted: Thu Jan 25, 2007 11:11 am    Post subject: What's advantage of conductive fuel hose? Reply with quote
Hello Bob
Will appreciate what you find.
"> Dunno . . . I'll ask around the power-plant and fuel systems
guys today."
I uncovered an article:
http://www.tc.gc.ca/civilaviation/systemsafety/newsletters/tp3658/PDF/4_2004.pdf
That talks about a few helicopter fuel systems "expanding very rapid".
Ultimate question, on our plastic Europa, would it be a worthwhile
exercise to run anything that conducts to the negative side of the battery
that would in essence connect all of them together? If the answer is yes,
would it be advisable to run all of these pieces to a single point ground
(make a separate single point ground and run it direct to battery that is
always connected)?
Bits and pieces that could be connected:
aluminium fuel cap receptacle
aluminium fuel elbow between filler and tank (~1 foot long)
2 aluminium fuel outlets from plastic tank that have 1 foot copper tubes
for water draining
Brass barb fittings
2 flowscan 201B fuel flow senders
2 lengths of Aeroquip 666 hose
2 aluminium water drain connectors
The things that can not be grounded
Plastic Rotomolded fuel filler
Rotomolded fuel tank
5/16" fuel injector hose, and plenty of it (don't think it conducts very
well?)
Very sketchy tale I heard about a Europa lost in a fire when refueling??
From a hands on Europa Guru, said just wipe fuel filler area with a water
damp cloth rag before refueling and don't worry bout it, been refueling
plastic aeroplanes and boats for years without a problem.
Ron Parigoris
rtitsworth
PostPosted: Thu Jan 25, 2007 5:30 pm    Post subject: What's advantage of conductive fuel hose? Reply with quote
I believe non-conductive fuel hose lining builds up static electricity as
the fluid flows through it. Then, the static electricity eventually
discharges (sparks) out to the exterior braid and thus burns a small hole in
the lining (bad).
