Chronically low voltage
Randy.McFarland(at)novell
PostPosted: Wed Jan 24, 2007 10:54 am    Post subject: Chronically low voltage Reply with quote
I was really hoping not to have to ask this question, but I'm at the end of
my electron understanding, so...
I have a 2 year old PC680 Battery and a 60amp IR alternator on my 7A. With
Avionics on my Buss voltage is 12.6 or greater as shown on my Engine
montitor. When I add Nav and Strobes I get a fluctuating 12.4 to 12.6 volts
which is just enought to trigger the Lo/Ov module light. Drives me crazy
after awhile. When I add either Landing or Taxi light to the load I get
steady Lo voltage light. Alternator seems to be putting out up to 28 +/-
amps as needed so my guess is that I have not maintained the battery very
well during the 18 months or so it sat in the airplane while installing /
testing the avionics.
What sequence of tests would help me narrow the reasons this may be
happening?
Randy
mprather(at)spro.net
PostPosted: Wed Jan 24, 2007 12:21 pm    Post subject: Chronically low voltage Reply with quote
Hello Randy,
When you observe the problem, is the engine running and if so, at what
RPM? If it's at idle, this might be normal behavior. If the engine is
turned off, what you describe is normal.
If the battery has enough energy to start the engine fairly well, I'd
guess the battery isn't dragging the buss down - the battery is
essentially healthy though maybe having reduced capacity.
How did you deduce that the alternator is putting out "28 +/- amps"? It
seems theoretically possible that the internal regulator has a problem -
regulated voltage too low. Or maybe a diode in the rectifier has gone
bad.
Matt-
<Randy.McFarland(at)novellus.com>
of
volts
happening?
Randy
N1DeltaWhiskey(at)comcast
PostPosted: Wed Jan 24, 2007 12:28 pm    Post subject: Chronically low voltage Reply with quote
Randy,
You left out a lot of info. Is your voltage reading with the engine
(alternator) running or not. IF the alternator is not running, why are you
concerned? Do you normally run those lights with the alternator off? While
running, your alternator should provide around 14v, so the battery does not
come into question until you approach/exceed the alternator output. With
the alternator running, do you have the same problem.
If this is with alternator off, why are your concerned about it? If you
were flying at night and lost the alternator, you would want to switch off
the lights anyway to preserve battery until you can make a field to land as
Bob has suggested many times.
But to your question. E=IR, or voltage = current times resistance. Look at
your circuits - they form a loop from the minus side of the battery to the
plus side. Lights, switches, connectors, connections, wire size, and the
battery itself are all possible points of resistance around the loop.
Check the battery first, with no load, by measuring the voltage at the
battery terminals; then turn on all your loads and repeat the reading - what
do you get? You can calculate the resistance of the battery by R=E/I. This
should be quite small, and should be available from battery performance
charts. Now you know the equivalent resistance of the battery. (Do you
know the load current, or just estimating?)
To calculate other resistances, measure from BAT ground to various points
along the circuit. The resistance can be determined by the delta-V between
the points. Compare the resistance in the wire to theoretical charts to see
if there is something going on there. There will be some resistance across
connectors/connections, but this should be almost none existent, but you can
check one side to the other.
If you really have a problem, this process should be able to identify where
it is at.
Regards, and good hunting,
Doug Windhorn
PostPosted: Wed Jan 24, 2007 1:17 pm    Post subject: Chronically low voltage Reply with quote
Sorry, the Lo V status occurs at cruise power and rpm.
The battery seems to start the engine ok, but I think with electronic
ignition it seems to start much easier than with only the Mag.
I have a Grand Rapids Engine Monitor that shows the current output of the
alternator. This is the 60amp Nippon Denso alternator that has gotten so
much discussion recently. My original 60a alternator failed witnin 20 hours
of operation, so this is a replacement alternator.
Randy
john(at)ballofshame.com
PostPosted: Wed Jan 24, 2007 1:34 pm    Post subject: Chronically low voltage Reply with quote
I'm gonna go out on a limb and say that the 12.4 to 12.6 volts isn't a
real reading. Your battery would practically never charge. Personally,
first thing I would do is whip out a VOM and sanity check the readings.
Maybe they're correct but it seems weird. At least rule that out first.
-John
www.ballofshame.com
hours
Randy
Erich_Weaver(at)URSCorp.c
PostPosted: Wed Jan 24, 2007 2:30 pm    Post subject: Chronically low voltage Reply with quote
Randy:
I note that you refer to both a low/over voltage module and a GRT Engine
Monitor in your previous posts. These seem somewhat redundant since the
EIS indicates voltage and warns you if you are under/over your designated
limits - no separate module is necessary. If the EIS is NOT warning of any
limit exceedance, perhaps something is screwy with the voltage module?
Perhaps Im not understanding this completely.
regards
Erich Weaver
nuckollsr(at)cox.net
PostPosted: Wed Jan 24, 2007 7:44 pm    Post subject: Chronically low voltage Reply with quote
happening?
What architecture are you using? How do you measure alternator
output amps? With voltage readings like that, it sounds like
the alternator is not even coming on line. It the alternator is
working, 14.2 to 14.6 is more normal.
PostPosted: Wed Jan 24, 2007 7:48 pm    Post subject: Chronically low voltage Reply with quote
Randy
Put a battery maintainer or other smart charger on
the battery and wait until its green light comes on
stating that the battery is fully charged.
Start the engine but leave EVERYTHING electrical
turned off except battery and alternator. The engine
monitor should IMMEDIATELY show 14.2 or more volts
and alternator output current should peak up but
come down pretty quickly . . . probably under 10
amps in a minute or so.
If you don't have 14 volts but do have some measurable
output current, the alternator is bad.
khorton01(at)rogers.com
PostPosted: Thu Jan 25, 2007 2:42 am    Post subject: Chronically low voltage Reply with quote
On 24 Jan 2007, at 22:48, Robert L. Nuckolls, III wrote:
<nuckollsr(at)cox.net>
This appears to assume that the engine monitor is on a bus that sees
the full alternator voltage. If the engine monitor is on a bus that
gets its power via a conventional diode, then you can subtract about
0.6 volts from the above values.
Kevin Horton RV-8 (finishing kit)
Ottawa, Canada
http://www.kilohotel.com/rv8
PostPosted: Thu Jan 25, 2007 4:35 am    Post subject: Chronically low voltage Reply with quote
Good put sir! Thanks.
PostPosted: Thu Jan 25, 2007 8:37 am    Post subject: Chronically low voltage Reply with quote
Thanks all. Off to the hangar to measure / test as suggested. Will report
back the results.
R
