161 hp @ 2700 rpm 0200
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Engines-List
timwarlick(at)bellsouth.n
PostPosted: Fri Jan 19, 2007 4:11 pm    Post subject: 161 hp @ 2700 rpm 0200 Reply with quote
Ok Archie, how did you increase the bhp from 100 to 161? If you turbocharged it you should call it a TS0200.
Mobile, AL
- The Matronics Engines-List Email Forum -
http://www.matronics.com/Navigator?Engines-List
archie97(at)earthlink.net
PostPosted: Fri Jan 19, 2007 4:51 pm    Post subject: 161 hp @ 2700 rpm 0200 Reply with quote
That would be cheating. Both engines were normally aspirated.
jrccea(at)bellsouth.net
PostPosted: Fri Jan 19, 2007 5:07 pm    Post subject: 161 hp @ 2700 rpm 0200 Reply with quote
He increased the compression, increased the intake velocity, reduced the exhaust backpressure, and jacked the rpm way up.
JimC
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Engines-List All times are GMT - 8 Hours
