Secure connection to a diode? (CORRECTED LINK)
nuckollsr(at)cox.net
PostPosted: Fri Jan 12, 2007 4:03 pm    Post subject: Secure connection to a diode? (CORRECTED LINK) Reply with quote
At 02:30 PM 1/11/2007 -0600, you wrote:
<nuckollsr(at)cox.net>
At 11:50 AM 1/11/2007 -0500, you wrote:
><dennis.glaeser(at)eds.com>
>When I have multiple wires at one Faston connection, I use the
>appropriate (bigger) size and put both (or all 3) wires in the connector
>and crimp them all together. B&C does that for the diodes they install
>on their contactors, so I figured it must be OK. I think Bob even has a
>cartoon on how to do that on his website.
Yes. See . . .
http://www.aeroelectric.com/Pictures/Wiring_Technique/Wire_treatment_3.jpg
>If the pin connectors are big enough (i.e. Molex) you could do that as
>well, but D-Sub size pins are too small - you'd have to join the wires
>with a faston size splice with the multiple wires in one end and a
>single wire (maybe doubled over) out to the pin.
I've not had very good luck with multiple wires into
anything except the old MS3100 series solder-pot connectors.
Crimping multiple wires into connector pins is problematic.
>I've got 3 individual diodes that have to be wired between micro
>switches and pin connectors and the gear switch and valves with
>fast-ons, etc.
>How do you connect the ends coming out of each side of the diode
>to 20 AWG wire? Is there a connector out there for that? Two
>of the diodes have multiple (2) connections on each end.
>Needless to say.I'm a wiring newbie!
Jon it's not clear from your text as to the exact
nature of your task. Can you scan a sketch of the wiring
diagram and attach it to a reply? I 'think' I know
what you're dealing with but a schematic would help
me be more specific and useful.
< with experiment. >
< --Lawrence M. Krauss >
