docyukon(at)ptcnet.net Guest
Posted: Wed Jan 03, 2007 8:14 am Post subject: filter cap |
Can anyone give me a part # and mfgr. for a 22000MFD 25v 105c filter cap? or what ever is better. ( Must have screw terminals.) Thanks Bill S.
mprather(at)spro.net Guest
Posted: Wed Jan 03, 2007 8:58 am Post subject: filter cap |
Screw terminals are generally a pain. But... 338-1252-ND from digikey
gets everything you want except the temperature spec - 95C instead of
105C. If you aren't installing it in a certified harsh environment 95C
might be fine.
Matt-
Quote: | Can anyone give me a part # and mfgr. for a 22000MFD 25v 105c filter
Thanks Bill S.
nuckollsr(at)cox.net Guest
Posted: Wed Jan 03, 2007 9:40 am Post subject: filter cap |
might be fine.
I agree. This part number will be fine. However, avoid
any ideas about substituting a wired device of the same
ratings over the screw-terminal devices. Their internal
construction is not as well suited for high-ripple current
filtering that we're looking for in this application.
It's that "computer grade" thing that makes the difference
and all these puppies come with 10-32 screw terminals.
Posted: Wed Jan 03, 2007 3:24 pm Post subject: filter cap |
Matt Thanks for the quick reply. What do you mean by, generally a
pain? What problems can I expect to incounter with screw terminals? Bill
S.
Gilles.Thesee(at)ac-greno Guest
Posted: Wed Jan 03, 2007 3:32 pm Post subject: filter cap |
Quote: | What do you mean by, generally a pain? What problems can I expect
Bill, Matt and all,
FWIW, I installed such a screw terminal capacitor in our airplane three
years ago, and we have been flying for two years now, without any problem.
Gilles Thesee
Grenoble, France
http://contrails.free.fr
Posted: Wed Jan 03, 2007 4:14 pm Post subject: filter cap |
Ahhh.. I just gripe because screw terminals seem unnecessairly fiddly.
Electrical components are often mounted in places where access/vision is
limited. Threading small screws through lugs crimped to springy wire can
be a test of dexterity and patience. No big deal, but I like to have
things built for quick serviceability.
As a possible alternative, I remember seeing threaded lug to spade
adapters on the tops of the older Bosch (at least) automotive ignition
coils. A threaded stud sticks out of the top of the coil. Captured by a
nut threaded onto the stud is a piece of tinned metal. The end of that
piece of metal is properly sized/formed to accept female spade terminals.
I did a quick online search and couldn't find what I was looking for...
Maybe somebody knows what these things are actually called..
What I am talking about is depicted here:
http://content.answers.com/main/content/wp/en/thumb/2/27/200px-Igncoil.jpg
or here:
http://images.google.com/imgres?imgurl=http://specialtauto.com/delorean-parts/images/ignition-coil-blaster_small.jpg&imgrefurl=http://specialtauto.com/delorean-parts/engine-tuneup.html&h=155&w=150&sz=3&hl=en&sig2=JP9z4J26Tyw9NHdBBJn8jw&start=64&tbnid=M4N61qRrCiDkHM:&tbnh=97&tbnw=94&ei=_0WcRYWOL8zI6gH2pM3dDA&prev=/images%3Fq%3Dignition%2Bcoil%26start%3D60%26ndsp%3D20%26svnum%3D10%26hl%3Den%26lr%3D%26safe%3Dactive%26sa%3DN
or here:
http://content.performanceproducts.com/main/101089/boschigcoil.jpg
It should be pretty easy to make such a thing.
Matt-
<docyukon(at)ptcnet.net>
S.
dsvs(at)ca.rr.com Guest
Posted: Wed Jan 03, 2007 5:11 pm Post subject: filter cap |
Steinair has faston adapters for use on terminal strips that could be cut in half and used. Don
or here:
or here:
Matt-
> Bill
> S.
Posted: Thu Jan 04, 2007 7:34 am Post subject: filter cap |
Why drive up parts count? What advantage is gained by placing an
adapter on a threaded stud to accommodate a fast-on terminal when
a simple ring terminal to the same stud will suffice? If you have
concerns about maintaining joint integrity in the threaded fastener,
those concerns don't go away just because you've turned a fast-on
terminal into a ring-terminal with an adapter.
Posted: Thu Jan 04, 2007 7:53 am Post subject: filter cap |
This was in response to Matt's comment about not wanting to use screw terminals becausr of the difficulty in doing maintenance later on in blind spots or difficult to reach spots. He said that he preferred fast on type hook ups. This was a way that faston type could be used with existing screw type caps.
Posted: Thu Jan 04, 2007 8:05 am Post subject: filter cap |
Hey Bob,
I think I started this twist... I just don't like ring terminals when
trying to make a connection in the blind. I wasn't concerned about joint
integrity. I agree with your point about parts count..
Matt-
Quote: |
<nuckollsr(at)cox.net>
