Back-Up Battery ground (The multi-word answer)
echristley(at)nc.rr.com
PostPosted: Tue Jan 02, 2007 8:53 am    Post subject: Back-Up Battery ground (The multi-word answer) Reply with quote
Robert L. Nuckolls, III wrote:
In other words, if this battery has real value as a backup
energy source, does this not speak poorly of any efforts
to make the additional battery unnecessary in the first place?
Not necessarily. With an electrically dependant, auto-conversion engine
you have ignition, control computers and fuel pumps which must all be
fed a healthy diet of electrons at somewhere around 15A. Even with the
'backup' battery, it would not be possible to burn through all the
usable fuel on board in case of an alternator failure. A 20Ah unit
would be marginal at best. The extra battery capacity in this case
carries very real benefits.
,|"|"|, Ernest Christley |
----===<{{(oQo)}}>===---- Dyke Delta Builder |
o| d |o http://ernest.isa-geek.org |
