AeroElectric-List:
hooverra(at)verizon.net
PostPosted: Tue Dec 19, 2006 4:02 am    Post subject: AeroElectric-List: Reply with quote
26 ga wire in a common sheath, properly routed and supported is plenty
robust. The problems happen at the terminations. I recommend connectors
with properly designed stain relief. I have selected a Switchcraft EN3
series connectors (http://dkc3.digikey.com/PDF/T063/0289.pdf) This is a
small diameter circular connector that is weather tight and strain
relieved. It's more money than a cut-up D connector but it's a reliable
stable connector. I will add a length of plastic tubing where the wire
is routed through the elevator hinge area supported by clamps on both ends.
Ralph
<nuckollsr(at)cox.net>
At 04:45 PM 12/18/2006 -0600, you wrote:
> hi all,
> what are builders doing to connect a trim servo to the cockpit?
> ''ray allen'' servo takes 5 wires . the company can supply a 5 wire
> cable. wires are each 26 ga. is that the way to go or is there a
> better way? 26 ga . seems pretty flimsy. Any input appreciated.
24AWG wire in the airframe is marginal for serviceability,
26AWG wire sucks. Recommend you transition as soon as practical
to 22AWG by means of a connector . . . here's one way to do it.
http://aeroelectric.com/articles/macservo/macservo.html
< with experiment. >
< --Lawrence M. Krauss >
ceengland(at)bellsouth.ne
PostPosted: Sun Dec 31, 2006 10:40 am    Post subject: AeroElectric-List: Reply with quote
bob noffs wrote:
hi all,
what switch has been satisfactory for a push to talk mounted in the
end of the stick? any suggestions appreciated. thanks in advance, bob
noffs
Bob,
Almost any normally open (NO) momentary push button that will mount in
your stick will work fine. The RV-4 I'm flying has around 1,000 hrs on
it & I'm pretty sure the PTT in the stick came from Radio Shack or a
similar supplier. Just find one that fits & has an actuation pressure
you are comfortable with.
If you have a 'real' electronics supply house in your area, tell them
you need a normally open, momentary, single pole push button switch that
mounts in a x/y" diameter hole & that will fit within your stick's
internal diameter. (x/y is the fractional diameter of your mounting
hole.) If you go to RS, they have switches that have as small as 1/4"
bushing diameters. The button is obviously small, but actuation pressure
is low so you don't need a big button. If you fly a plane with light
controls, you don't want switch pressure to be so high that you will be
affecting pitch/roll when you transmit. Smile
Charlie
Charlie
