Back-Up Battery ground
trigo(at)mail.telepac.pt
PostPosted: Sun Dec 24, 2006 1:14 pm    Post subject: Back-Up Battery ground Reply with quote
Since I will have to put some wheight in the tail of my RV-9A because of W&B
issues, I am planning to install a small battery (probably around 4.5Ah,
depending on its own wheight) to act as a back-up battery for some avionics
(EFIS and Auto-pilot).
For the (+) terminal of that future battery, I already passed a AWG#14
tefzel wire all the way from the tail to the back of instrument pannel, but
for the (-) wire, I am thinking that I could attach it to a ground lug that
I already have in the tail, which is directly connected to the "Main"
battery (-) terminal, and where are also connected the ground wires from the
tail light, the tail strobe beacon and the elevator trim motor.
Can I connect that battery's (-) terminal to the tail ground lug ?
Is there a possibility for ground loop ?
Carlos
tompkinsl(at)integra.net
PostPosted: Tue Dec 26, 2006 11:05 am    Post subject: Back-Up Battery ground Reply with quote
Why not just carry a small amount of ballast in the baggage compartment that you can trade for cargo when the need arises? I think it's the simplest solution and gives you the oppportunity to maximize cargo capacity.
Larry
bicyclop(at)pacbell.net
PostPosted: Tue Dec 26, 2006 11:47 am    Post subject: Back-Up Battery ground Reply with quote
Toolkit for instance. Survival supplies good too.
Pax,
Ed
nuckollsr(at)cox.net
PostPosted: Tue Dec 26, 2006 12:01 pm    Post subject: Back-Up Battery ground Reply with quote
Larry
An astute question sir. A Bonanza I used to rent had 6 plastic jugs
in the baggage compartment with a tiedown net. If one anticipated
lightly loaded flights, the jugs are filled with water to keep
the balance in range. If one were going to use the baggage compartment
both ways, then the net was used to wrap up jugs and hang them on
the hangar wall before departure. If you needed the weight only
one way, the jugs could be filled/emptied as needed for up to 50
pounds of aft ballast adjustment.
If I wanted to have adjustable balance while minimizing weight,
how about a plastic tank as far aft as possible with external
filler/drain access. Fill or empty as needed. Obviously, changes
could be accomplished only at temperatures above 32 degrees!
Sailplanes use water as a dynamic ballasting medium, don't
see why Haulplanes couldn't do it too.
< What is so wonderful about scientific truth...is that >
< the authority which determines whether there can be >
< debate or not does not reside in some fraternity of >
< scientists; nor is it divine. The authority rests >
< with experiment. >
< --Lawrence M. Krauss >
PostPosted: Tue Dec 26, 2006 12:25 pm    Post subject: Back-Up Battery ground Reply with quote
Bob, Larry et all
Please forget the reason why I may want to put the Avionics Back-Up battery
in the tail, and please answer the electric questions:
- Can I connect the (-) terminal of that battery to the tail's ground lug,
which is isolated from the fuselage and is directly connected to the (-)
terminal of the "Main" battery ?
- Can I continue to use that same ground lug to connect the other grounds
( from the tail light, the strobe beacon, and the elevator trim motor)
there?
- Isn't there any possibility of "ground loop"?
Carlos
BobsV35B(at)aol.com
PostPosted: Tue Dec 26, 2006 12:27 pm    Post subject: Back-Up Battery ground Reply with quote
In a message dated 12/26/2006 2:03:20 P.M. Central Standard Time, nuckollsr(at)cox.net writes:
in the baggage compartment with a tie down net. If one anticipated
Good Afternoon Bob,
Just for a statistical data point, in the days of the DC-3, all airlines used canvas bags with lead shot as ballast. They had canvas handles and each weighed fifty pounds.
A baggage a cart full of ballast bags was maintained at each station. The bags would be thrown in the aft baggage compartment of the DC-3 so as to maintain a reasonable CG. If any one station got a little low on bags or a little heavy on bags, a message would be sent and bags would be moved from the 'Heavy' stations to the 'Light' stations.
If I Recall Correctly, for an empty airplane, we needed around five hundred pounds of ballast in the aft compartment. I could be off by a couple of hundred pounds on that though.
Worked well for a stable airline.
The idea of hauling ballast has a long history with sailing ships. They would unload paying cargo in the New World and load up on rocks and stones to get reasonable stability for the trip home. A major effort was made to load up stones that may have some value when the ship reached a port that had better paying cargo available.
Nothing much new under the sun is there?
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
Stearman N3977A
Brookeridge Air Park LL22
Downers Grove, IL 60516
630 985-8503
PostPosted: Tue Dec 26, 2006 6:11 pm    Post subject: Back-Up Battery ground Reply with quote
At 08:24 PM 12/26/2006 +0000, you wrote:
<trigo(at)mail.telepac.pt>
Bob, Larry et all
battery in the tail, and please answer the electric questions:
Can't imagine what you're describing here. Ground the
battery to local structure.
there?
Ground these devices to local structure. You don't
need a "tail ground" in a metal airplane for items
located in the tail.
No.
Do you plan a "mini battery contactor" for this "mini-battery"?
Even thought it's a relatively small battery compared to
the ship's battery, it is capable of significant fault currents
and should be treated like any other battery with respect to
positive disconnection via local contactor.
It would be helpful if you could publish sketches of your
proposed wiring.
PostPosted: Tue Dec 26, 2006 6:12 pm    Post subject: Back-Up Battery ground Reply with quote
Good Afternoon Bob,
Puts a whole new twist on the term "dead heading" . . . nothing
deader than a rock!
Speedy11(at)aol.com
PostPosted: Wed Dec 27, 2006 6:44 pm    Post subject: Back-Up Battery ground Reply with quote
Carlos,
Good luck getting a helpful answer on this list. You can normally get little more than criticism and ridicule.
It sounds as though you have a ground wire running from your main battery to the aft portion of the fuselage and you want to know if connecting your back-up battery in the aft fuselage to that same ground wire will cause any problems. Is that correct?
Stan Sutterfield
there?
Carlos
PostPosted: Thu Dec 28, 2006 3:05 am    Post subject: Back-Up Battery ground Reply with quote
Yeah
Some times on this list, if you ask apples you get an answer in oranges Smile
I also hate that particular facet of this group, and I'm waiting for the time when someone asks if he can connect a red ground wire to some device, and he will get the answer that he should not use red on that wire! Smile.
Well, but most of the times, this forum is useful, so I keep trying.
Stan
That's exactly what I was asking.
Carlos
mlas(at)cox.net
PostPosted: Thu Dec 28, 2006 7:30 am    Post subject: Back-Up Battery ground Reply with quote
            Ask a better question (more complete), get a better answer.  Or you could just bring it over and will fix it.
Just helping the sarcasm along!
Mike Larkin
pats4p(at)sbcglobal.net
PostPosted: Fri Dec 29, 2006 3:44 pm    Post subject: Back-Up Battery ground Reply with quote
Touche' [quote][b]
