Downside to powering headsets with ships power?
rparigor(at)SUFFOLK.LIB.N
PostPosted: Mon Jan 30, 2006 7:44 am    Post subject: Downside to powering headsets with ships power? Reply with quote
I have 2 Lightspeed headsets will be using on our Europa.
Is there any downside using regulated ships power to run them?
Thx.
Sincerely
Ron Parigoris
mlas(at)cox.net
PostPosted: Tue Jan 31, 2006 4:43 am    Post subject: Downside to powering headsets with ships power? Reply with quote
No, not really. The only draw back is if the passive (power off, not
active) noise canceling of the headset is poor like the Bose X in which
case you have very little effect from the headset without power for the
active system. If the headset is able to control the background noise
with the power off, then that is what will happen if you should lose
power to your headset.
Mike
