S704 Relay Wire Sizing
piavis(at)comcast.net
PostPosted: Thu Dec 21, 2006 6:47 pm    Post subject: S704 Relay Wire Sizing Reply with quote
In sizing wires per the Z-13 diagram on the S704 relay for the SD-8, most of the wires supporting the SD-8 are 12AWG. For the jumper from the + side of the contactor on the relay, to the COM tab, can I use something as low as an 18 or 20 AWG wire for this, I’m not sure of the current flow through this. Based on other posts on the subject, there’s only about .1A on the line from the contactor ground tab through to the breaker and switch, so I should be able to go to a much smaller wire here.
Jim
-7
Redmond, WA [quote][b]
klehman(at)albedo.net
PostPosted: Fri Dec 22, 2006 6:50 pm    Post subject: S704 Relay Wire Sizing Reply with quote
Hi Jim
Yes I agree with you. Since the coil circuit has a 5 amp CB in it I
think you could go all the way down to 22awg if you wanted.
I also think that 12awg is appropriate for the 20 amp alternator but
overkill for an 8 amp unit.
Ken
something as low as an 18 or 20 AWG wire for this, Im not sure of the
theres only about .1A on the line from the contactor ground tab
smaller wire here.
Jim
-7
Redmond, WA
PostPosted: Mon Dec 25, 2006 9:06 pm    Post subject: S704 Relay Wire Sizing Reply with quote
Thanks Ken, That’s what I had figured but can’t find any concrete info in the archives. I was hoping to get a reading from Bob on this one. I’ve noticed a lot of questions on the S704 in the archives but nothing indicating wire sizing as used with the SD-8. Jim Hi JimYes I agree with you. Since the coil circuit has a 5 amp CB in it I think you could go all the way down to 22awg if you wanted.I also think that 12awg is appropriate for the 20 amp alternator but
5
6
7
8
9
