bushpilot(at)optonline.ne Guest
Posted: Sun Dec 17, 2006 11:17 am Post subject: Fuse Link At Battery |
I am building a Glastar that will have and IO-320 with an Aerosance FADEC. The electrical design is the Z-14 Dual Battery, Dual Alternator, Split Bus. The batteries will be located behind bulk head "A" which is at the back of the baggage area. From each battery there will be a 10 Awg wire feeding the main and aux battery bus respectively. The 10 Awg wires will run from batteries at the back up to the panel in the front.
Where the 10 Awg wire connects to the battery, I would like to provide some type of wire short protection. Currently, I am planning on installing a 14 Awg fuse link. Any thoughts, suggestions or better recommendations?
Johnathan
bobf(at)feldtman.com Guest
Posted: Sun Dec 17, 2006 3:43 pm Post subject: Fuse Link At Battery |
On Sunday 17 December 2006 13:14, JOHNATHAN MACY wrote:
Iid suggest 4 AWG welding cables. I have a glastar and it needs minimal
voltage drop. I have a LOM engine and even with that having good cranking
voltage. 10 AWG is not big enouf I'd say
bobf
N125GS
Quote: | I am building a Glastar that will have and IO-320 with an Aerosance FADEC.
Johnathan
nuckollsr(at)cox.net Guest
Posted: Mon Dec 18, 2006 6:41 am Post subject: Fuse Link At Battery |
This is generally not done in the TC aircraft world. BATTERY
busses are located at the battery and the relatively short lead
between contactor and bus does not call for protection.
The general rule of thumb for always-hot wires in the airframe
is that they be breakers of 5A or less . . . this would apply
to your too-long bus feeder as well. Note the (*) on the wires
between battery contactor and battery bus on all diagrams. This
indicates that this wire's length should be minimized as much
as practical.
< with experiment. >
< --Lawrence M. Krauss >
Posted: Mon Dec 18, 2006 6:47 am Post subject: Fuse Link At Battery |
10AWG would be plenty big enough for a battery bus feeder.
Battery busses drive only those devices that need to be operable
when the battery master and alternator switches are OFF. This
includes things like hobbs meter, clocks, courtesy lights, electrically
dependent engine accessories, etc. It's doubtful that such loads would
total more than 10A and 10AWG is fine.
As cited in the earlier post, the battery bus feeder is always hot
and it's length should be minimized. This places the battery bus
AT the battery location and further suggests that all feeders from
the bus be breakered at 5A or less (fused at 7A or less). If something
really needs to be protected at higher levels (like a ECFI pump) then
that accessory should be fitted with a "mini contactor" at the bus, not
unlike the fat feeder to an e-bus illustrated in figure Z-32 of
http://aeroelectric.com/articles/Rev11/AppZ_R11J.pdf
Posted: Tue Dec 19, 2006 5:43 pm Post subject: Fuse Link At Battery |
The authority rests with experiment.
Thanks for the follow up and feedback. The need to experiment at the wrong time has been averted.
I appreciate it. Happy holidays to you and yours.
Johnathan
Posted: Sat Dec 23, 2006 8:31 am Post subject: Fuse Link At Battery |
Johnathan
Thanks to yourself and others for the kind words. I'll
endeavor to remain worthy of them.
I've been off line for a few days. Seems the flu bug came
to visit and I've been tethered to the commode on a very
short leash for the first two days. Dr. Dee and I are going
to go for a walk in the park this morning to try and stir up
some muscles and circulatory systems that have been setting
idle too long!
