SL-30 Intercom
Speedy11(at)aol.com
PostPosted: Sun Jan 29, 2006 7:35 am    Post subject: SL-30 Intercom Reply with quote
Listers,
Is anyone with the Garmin SL-30 nav-comm using the built-in intercom?
If so, is it acceptable? Or do you recommend buying a separate intercom?
Is squelch a problem? Do you have control over squelch? Is there a means to
input music? Is there a muting function?
All advice appreciated.
Stan Sutterfield
www.rv-8a.net
aadamson(at)highrf.com
PostPosted: Sun Jan 29, 2006 8:04 am    Post subject: SL-30 Intercom Reply with quote
Stan, this was discussed at length over on the RV forums
(www.vansairforce.net). From all accounts, it useable, but the first time
you experience a *real* intercomm, you'll want one. Smile...
Depends on what you want for features, aux inputs, quality, conveniences
(like squelch, etc). For the little extra money, it sure seems most suggest
to put in a dedicated intercomm. But I'd suggest you go read the comments
over there.
I will have an SL-30, but I'm also going to put in a dedicated audio
panel/intercomm.
Alan
jclarkmail(at)gmail.com
PostPosted: Sun Jan 29, 2006 8:40 am    Post subject: SL-30 Intercom Reply with quote
Short answer ...
Get the intercom and make sure it is stereo with a music input.
Lots of reason covered in archives.
James
SL30 w/DRE44e
On 1/29/06, Speedy11(at)aol.com <Speedy11(at)aol.com> wrote:
Listers,
to
Stan Sutterfield
www.rv-8a.net
This is an alternate email. Please continue to email me at
james(at)nextupventures.com .
brian
PostPosted: Sun Jan 29, 2006 11:28 am    Post subject: SL-30 Intercom Reply with quote
Speedy11(at)aol.com wrote:
Listers,
I went separate because I want to be able to easily adjust level and
squelch. Getting to these parameters in in the SL-30 set-up screen is an
annoyance.
Brian Lloyd 361 Catterline Way
brian-yak at lloyd dot com Folsom, CA 95630
- Antoine de Saint-Exupery
Brian Lloyd
ornerycuss2001(at)yahoo.c
PostPosted: Mon Jan 30, 2006 1:11 pm    Post subject: SL-30 Intercom Reply with quote
Stan,
I use the SL-30 intercom and it's acceptable with my Bose and David Clark headsets. Doesn't work at all well with the LightSpeed ANR headset that my buddy has though.
Someone mentioned that it's tough to control volume and squelch. True because those items are buried a few menu levels "down" from the main screen.
There is no music function and no muting function.
I eventually plan to get an intercom.
Greg
Listers,
Stan Sutterfield
www.rv-8a.net
Bring words and photos together (easily) with
